Question about Maytag Washing Machines
My Maytag 3000 Washer does not always empty the water out. Sometimes it even will leak out onto the floor but am unsure where it actually comes from but there is water still in the machine when it is
This is intermittent.
Hi Stephen, Jim here. How old is the machine? Front loader or top loader?
Posted on Nov 26, 2014
  • Stephen Arnold
    Stephen Arnold Nov 26, 2014
    Machine is about 4 years old and is a front loader
  • 58 Answers
SOURCE: GWL11 Machine adds water during spin cycle and leaks on floor
diverter valve is not switching to pump the water out. instead it is resurculating back into the tub.
Posted on Oct 31, 2007
SOURCE: Maytag atlantis washing machine
It will not spin out all of the water out of clothes, spins VERY slow
Posted on Dec 10, 2007
aborcass
  • 2651 Answers
SOURCE: leaks water onto floor in front of washer after spin cycle, help
open the door though, put your hand around the rubber boot assy, run *** all around looking for small tears, and or holes, if so replace it. only other thing to do is remove the lower access panel and watch it spin a load and youll be able to detect where te waters coming from
Posted on Mar 23, 2008
  • 96 Answers
SOURCE: washer leaking water on floor
Need to check drain pump and its hose connections. If its not from the drum seal then that's usually where the leaks occur.
Posted on Mar 31, 2008
jsrock516
  • 5911 Answers
SOURCE: Washer is leaking
Check the rubber bellow (gasket) around the door. This is the symptom of a door gasket that it starting to leak. Pull the rubber folds back and check the area where the gasket attaches to the wash tub. You may have a crack or tear. If the gasket is worn please replay back to this post and I can give you advice on how to replace it and where to get a replacement gasket.
Posted on May 15, 2008
My Maytag Washer model GTW460ASJ4WW empties as soon as water IS INPUT
Is water leaking on the floor? Do you hear it running in the drain? Drain hose should be as high as washer top, otherwise water will siphon out, if pump is running might electical issue. Try that first.
Sep 27, 2017 | Maytag Washing Machines
I have a maytag neptune MAH5500BWW. Everytime the water company shuts off the water to repair a leak, the tub fills with water, sometimes overflows onto the floor. Works just fine when there is pressure...
This is symptomatic of a malfunctioning water control valve- depending on whether it is hot or cold water with which the tub fills.
Sorry but it needs replacing and a service call ;-0(
Good luck,
John C
Mar 27, 2011 | Maytag Neptune MAH5500B Front Load Washer
Water seems to be coming from underneath
Check that your drain hose is fully inserted into the wall/floor drain. then run an empty load with just water and watch it during the drain cycle to see if either the drain is backing up or if it's not fully connected at the back of the washer. if the drain is backing up you can try a drain sn ake available at most hardware stores and that will most likely clear it. If it's leaking at the connection at the back of the washer try to push it in fully or replace the hose altogether. It's not the water inlets because they always have pressure on them and would leak constantly. or you could have a cracked basket in which case you will be better to buy a new machine. cracked baskets don't happen very often though. And once in a blue moon it could be an off balance issue where its actually splashing out. Either way you need to spend some quality time with your washer and see why it's crying =]
May 02, 2010 | Maytag Atlantis MAV6000 Top Load Washer
There is always water in the drum even after a laod but after it sits empty the tub fills with more water
This might be a problem with your locking mechanism which is preventing the washer from actually performing a complete spin cycle. It will drain and appear to function but the high speed spin never actually takes place.
Aug 15, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag PAV2300AWW Washer leaks while filling
Hello
Welcome to Fixya
My name is Huum,
Why did you change the hoses with old ones?
If you are going to change them use new ones!
Sounds like the drain hose connection to the washer is not tight or not secured, or not fitting th connection because it is from a different washing machine.
Or there is a hole in the inner tub and leaking out on the floor.
Do you know the ones that sold it to you?
Thank You For trusting us with your question
Please remember to leave a rating before you leave!
Dec 14, 2008 | Maytag PAV2300 Top Load Washer
In the spin cycle water leaks onto the floor,
If the hoses at the back are not leaking, you need to check the drain hose lines, aksi check that the machine is not dripping from the inlet valve hose, or because of a leak from the door gasket.
Dec 09, 2008 | Maytag PAV3240A Top Load Washer
Our maytag washer won't pump water out
The pump is either jammed or has another issue, such as failures. You might try laying hose down. (WARNING: If tub is full of water, you will get a complete tub full of water onto your floor.)
Take the drain hose off of the pump assembly and peer inside. Sometimes these are jammed with debris, coins, or even small clothing.
See if this works.
May 26, 2008 | Maytag Washing Machines
Maytag top laoder stacked washer LSG1000
If it only leaks in drain it has to be a hole in the drain hose or a plugged up house drain.
Dec 15, 2007 | Maytag LSE7806A Top Load Stacked...
Washing Machines Logo
87 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
