Question about Maytag Refrigerators
If Mr. Goodwin does not know for sure the Maytag Model numbers how do we know his solution to the bottom of the freezer being covered with ice is correct. I also have a Maytag Mode#MF12665XEM7, Seria
Model #MF12665XEM7 Serial # K22409219. I have cleaned the coils under the front and back, took a hair blower to the ice and melted it from the bottom of the freezer. Turned off the icemaker and still the bottom is icing up again. What now.
  • Maytag Master
  • 744 Answers
Hello Molly;
I am sorry you are so frustrated.
Having done what you have described is only going to last until you cycle through the next automatic defrost. Your freezer section goes through a defrost cycle every 8-10 hours, where your unit shuts down for 20-30 minutes and your defrost heater turns. Everything will shut down except for the light bulbs.
You have a frozen drain and the condensate has no where to go except on the bottom of your freezer. The back wall of your freezer needs to be removed, where you can attach a 12 gauge wire to the defrost heater and run it into your drain hole. The defrost heater is about 4" away from your condensate drain and can not clear the ice.
I see you have a bottom freezer. They are a service technicians night mere when it comes to pulling the back wall off to access components.
Since you have a bottom freezer and the difficulty involved to do a permanent fix as described above, you only have two options.
1.) If I was still working for Sears Home Services and I came to your home, I would have to charge you at least $240.00 for the job.
2.) Or, you can turn you unit off for 24 hours with the doors open and let the ice in your condensate pan and drain melt. This may last for a year or several years, it is hard to say.
Why do drains freeze? Once I found a kernel of corn in the drain. It starts with one droplet of condensate clinging to the inside of the drain and then another and so on.
Tips to help prevent your drain from freezing:
1.) Unplug your unit. Pull it out so you can access and remove the back lower panel. Look for any leveling jack screws on each side of the front end. Turn counterclockwise to lower until your unit is free to move. You may have locking wheels.
2.) If you have a small rubber grommet on the end of your drain tube, throw it away. The original purpose was to prevent air from going up the drain tube. What it actually does is inhibits draining and creates a air pocket.
3.) If up have a 'S' shaped drain tube replace it with a straight tube. The 'S' tube also inhibits free draining. They are available at your local appliance store. Do not through the 'S' shape away. On some units they are required to prevent one door from popping open when you close another, but not necessary on all units.
So, Molly, will you give me a helpful on this one?
Posted on Nov 26, 2014
  • 1462 Answers
SOURCE: MY MAYTAG REFRIGERATOR
remove back panel inside freezer and there is a tray at the bottom with a drain hole in the middle. this is blocked with ice. melt off with a hairdryer and follow up with hot water till it flows waay freely
Posted on Oct 02, 2008
huuum
  • 750 Answers
SOURCE: 11 year old amana bottom freezer icemaker drips water when filling tray
Hello dunc444444
Welcome,
You said, Bottom freezer works fine, but upper refrigerator has no cold air
Is your freezer so full that it is packed to the top especially in the rear?
Refrigerators and freezers share the air from the compressor and travel through vents in the rear of the freezer and fridge.
Sometimes it can effect the cooling in the fridge if the freezer articles block the vents!
The water overfilling in the ice maker is an ice maker problem only.
When we install an ice maker there is a short white plastic tube that we push through the rear
hole of the fridge which supply's the water to the maker, the outside water line attaches to this.
That tube we push through the fridge must go in till it stops. And empties in to a little sistran at the rear of the ice maker. Make sure it did not sip out or backwards a little when you may have moved
rolled the fridge out to clean under it!
Also you need periodically to remove the front grill down in front of the fridge and gently run a refrigerator brush under the coils to clean out the dust that may block air flow over the coils.(the coils are metal black tubes that run back and forth along the bottom of your fridge.
The vacuum will not reach in to that tight space. That's why they make a special brush for this chore.
Let me know how you do?
Huuum {
Let me know.
Huuum
Please remember to leave a rating.
Posted on Oct 05, 2008
peyton32034
  • 410 Answers
SOURCE: not getting ice
sounds as if the icemaker is getting too much water and causing the unit to flood out. aside from replacing the icemaker you may be able to adj the amount of water going into the icemaker. there is a screw that holds the front cover of the icemaker inplace. remove the cover and you should see a screw  with a + and - sign on it. try turning the screw 1/4 turn then wait for the icemaker to cycle and see if it improves. keep making theses adjustments until your problem is solved thx peyton
Posted on Jan 28, 2009
peyton32034
  • 410 Answers
SOURCE: Maytag MFI2568AES Stainless Steel Bottom
  • 11800 Answers
SOURCE: GE Profile Side by Side
The temperature setting in the fridge section of your refrigerator is generated by diverting a part of the cold air generated in the freezer. This is done with the help of a fan and is controlled with a thermistor. If the temperature doesn't drop low enough then either the fan is faulty and it will have to be replaced
http://www.appliancepartspros.com/part_details.aspx?part_id=3875639
or it's not properly commanded because either the thermistor is faulty
http://www.appliancepartspros.com/part_details.aspx?part_id=3185407
or the control board itself has failed and it continuously activates the defrost resistance
http://www.appliancepartspros.com/part_details.aspx?part_id=4436216
If you need diagrams you can find them here
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5236940&diagram_id=23953624#d23953624
Posted on May 28, 2011
What is causing ice buildup in bottom freezer
Can you provide a model number and Make? Example Let me know by answering my post here, Thanks John T.Appliance 911
Contact
Apr 29, 2015 | Maytag Refrigerators
Why ismaytag bottom freezer leaking water?
Try clearing all vents - inside (make sure vents not covered - in fridge and freezer) and outside (gently vacuum - the coil areas in the back and bottom of fridge)
Sep 05, 2014 | Maytag MBF2258XEW 21.9 cu. ft....
I have condensate leakes into the bottom of my freezer and ices up the bottom of the freezer
YOUR DEFROST DRAIN IS CLOG UP YOU WILL NEED TO PULL THE BACK COVER OFF IN THE FREEZER SIDE AND CLEAN THE DRAIN YOU WILL SEE IT AT THE BOTTOM BEHIND THE FREEZER COVER
Oct 31, 2012 | Maytag Refrigerators
We have a model MBF1956KEB the freezer works but not the fridge
sounds like you have a bad damper,if you go here and look at part number 13 you can see it
http://www.searspartsdirect.com/partsdirect/part-model/MAYTAG-Parts/Refrigerator-Parts/Model-MBF1956KEB/3048/0161000/M0607105/00010?blt=06&prst=&shdMod=
it's broke in the closed position so no cold air can get blown over from the freezer and into the fridge section,open the freezer door and make sure you hear the fan blowing,also check around the freezer door and ceiling of the freezer and make sure there isn't any ice,common problem with bottom mount freezers is the door can get left open,warm air gets sucked into the freezer and ice forms in the air ducts,if all looks good i would say you have a bad damper,one more thing,remove the bottom kick panel there should be a tech sheet either folded up in the panel or taped on the cabinet wall down there,it will tell you how to do a diagnostics check to check all the parts like the damper,this way you know what part is bad.hope this helps you out and good luck.
Jul 28, 2012 | Maytag Refrigerators
Mr refrigerator leaks water out of the front of the machine on the corners, the bottom tray is solid ice. The model is MBF2255KEB with the freezer on the bottom.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 17, 2011 | Maytag Refrigerators
Late model freezer below maytag refigerator leaking water out the bottom where is the drain located?
drain is in the back behind the plate . and below the evap coil . if its covered with ice you cannot see it .. mm
Aug 06, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Ice in the freezer side bottom of my side by side Maytag.
You are having either a defrost problem combined with the defrost drain being frozen over. Need to unplug and remove the rear panel in back of freezer to examine exactly what is happening. Some models like yours have electronic vents that cole if the control becomes defective. . The other possibilities ar the
Adaptive Defrost part number 61005988
The defrost heater with defrost thermostat part number 61006199
Visit our site or click on your model number or part number. I will be here to assist you in your repair, Thanks Sea Breeze
Click Here=> PART NUMBER AND MODEL SEARCH FEATURE
Aug 03, 2009 | Maytag MSD2756G Side by Side Refrigerator
I have a maytag MSD2754GR, the freezer bottom is all iced
The drian hole has become stopped up and ice has accumulated in the the drian hole. You will need to unplug the fridge and remove the cover on the back (located at the bottom, 6 screws). On the freezer side there is a drian hole with a rubber 90 and a clear line that runs to the drain pan. Remove line and unstop. Don't not put the line back on yet.
Now for the fun part, remove the basket and the two bottom shelves from the freezer. Half way up the back there are 2 screws that need to be removed. After removing screws pull up on the top cover to so you can remove the bottom cover. The bottom cover maybe froze to the coils and to the inside drain pan. Break the ice with a butter knife, and remove cover ( do not hit the coils). Now you need to break the ice that is froze to the the pan and under it. Once you have remove all the ice you will see the drain hole, use a small pointed object to break ice that is in drain hole. Now you can put the drain line back on and make sure that the other end is in the drain pan under the fridge. Now reassemble the fridge and plug it back up.
It took me about 20 minutes to do this.
Hope this helps.
Jun 22, 2009 | Maytag MSD2456G Side by Side Refrigerator
Ice maker is not working anymore. Water doesn't fill the tub. Water dispenser out of the door is still working
I need you to double check the model number. Maytag has a service library at this link. http://www.servicematters.com/maytag_library/html/index.html
By placing the first 3 letters in the search feature it will take you to models like yours. Chose the correct model that you have and enter the number in the search. I believe that the water control valve on back of your refrigerator is the problem. Maytag is very good about helping their customers. Let me know if you have problems gettting the information you need, Thanks, Sea Breeze
May 26, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Bottom of Maytag Freezer Ices Up
You have a plugged defrost drain. easiest way to fix it is unload freezer compartment defrost all of the ice, then remove the 2 screws that hold the rear cover in place about half way down the back wall. once this is removed use hot water to flush out the aluminum evap pan at the bottom of the coil. once it is cleared i will usually pur a little bleach in to kill any algae build up.\
be sure to unplug the refrig and use caution not to cut your self on the evap coil as the fins are very sharp..
Dec 16, 2007 | Refrigerators
Refrigerators Logo
54 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
