Toshiba 50h60 tv has power but no picture - Televison & Video
    Novelist:
  • 93 Answers
Although most HD TVs are 120 VAC devices, they actually have step-down power transmission sectios that take the line voltage from the wall outlet and turns it into the 13.8 VDC needed to run the HD TV. So, what does this have to do with the price of tea anywhere? The answer is that if you look at the output side of the power supply circuit, you will see the 13.8 VDC power signal appearing. That voltage, though, is there to tell you that power is available.
Now, take a look at the power supply circuit either in the owner's manual (if it is supplied) or on the lid of the power supply in the HD TV itself (warning, only open this device if you are familiar with and comfortable with working with voltages and a DC volt meter) and you will see at low-amperage circuit -- in the 1 to 5 amp range -- and a high-amperage circuit -- up to 20 amps. This is the important circuit because it drives the TV.
You will have to go into this device while it is on, so extra careful that you stay away from the AC input. You can look at the DC output because it is low-voltage.
Placing the probes of a volt-meter (in the appropriate range setting) across with the black (-) lead to ground and the red lead on the high-amp positive lead, measure the voltage. You should read 13.8 VDC or a similar reading. If you do not see any voltage on this terminal -- which I suspect the the case -- then you will have to replace the power supply. If you feel comfortable handling this repair, you can do it yourself. I would suggest taking it back to the store where you bought it and have them fix it -- to keep the warranty intacty -- or have them send it back to the manufacturer.
Posted on Nov 26, 2014
The power light blinks 3 times. What does this mean?
Toshiba Flat Panel Television how-to instructions, help and tips Three times so far, just the tv not the cable. Toshiba Flat Panel .... Timer light blinking red. TV will not turn on by power button on TV or using the ...
tv.manualsonline.com/.../toshiba/.../flat_panel.../product_problem toshiba.justanswer.com
Mar 11, 2011 | Toshiba Televison & Video
42rv530u toshiba tv no sound no picture change power supply and main board
The 42RV530U is known to develop problems in both the power board and the main board. You can check out our power board repair service at
http://www.coppelltvrepair.com/p/442/repair-service-for-toshiba-42rv530u-power-board-75010942-dead-tv-or-clicking-on-and-off-problem
and I'd also recommend that you search for 42RV530U at http://blog.coppelltvrepair.com as we will eventually release an article on how to test the board.
Hope this helps.
Aug 12, 2010 | Toshiba REGZA 42RV530U 42 in. LCD HDTV
I have a Toshiba 50hp66 that the power light cycles from red to green with a simultaneous clicking of a relay on the power board. I check for power at a few points per the Toshiba service manual and iy is...
Check the fuses on the ysus & zsus boards. Are any fuses on boards open . Disconect power cabels to ysus board first {board on left} . put tv on . if the light is green the ysus board must be replaced.
Mar 28, 2010 | Toshiba TheaterWide 50HP16 50 in. Plasma...
Toshiba 42HP66 No Picture, Only Power Works
try replaced z board Manufacturer Toshiba Part Number 75003032 Description ZSUS PCB ASSY
Oct 02, 2009 | Toshiba 42HP66 42 in. LCD Television
Picture on 36 inch toshiba tv out
I had the same problem on my 61" RCA TV... The switch for the power/channel changing buttons seems to be a faulty product... However if you are a little technical you can open up the front of the TV and disconnect the button panel from the tv and just use the remote to operate it.
Jul 02, 2009 | Toshiba Televison & Video
Picture goes black
GO TO MENU, THEN SETUP, SCROLL DOWN TO TIMER AND MAKE SURE IT IS ON 0 (ZERO) MIN. SOUNDS LIKE ITS PROGRAMMED TO GO SLEEPAFTER A CERTAIN TIME. THIS TV ALSO CUTS OFF AUTOMATICALLY IN 15 MIN. IF ITS TUNED TO A VACANT CHANNEL( NO PICTURE).
Jun 18, 2008 | Toshiba 36AF42 36" TV
42" Toshiba Plasma TV no picture or sound
My experience with 42" plasma tv's with no picture or sound was a missing power supply voltage. On the power supply board check voltages on the plug. The voltages should be marked on the board,
Mar 01, 2008 | Toshiba 42WP27 42 in. Plasma Television
Tv picture
Solder any / all bad connects in power supply,vertical,horiz &
video circuitry,esp. regulator IC's..................T.
Jan 09, 2008 | Toshiba 32AF43 32" TV
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Electro Med Services...
