Question about Refrigerators
I have a frigidaire LFTR1814LB. It has been leaking water from the freezer into the refrigerator section for about a month. A couple days ago it started making an obnoxiously loud vibrating sound periodically and now the freezer is working fine but the refrigerator isnt cooling enough. I can feel a little cool air blowing in from the freezer but not much. The freezer does has a small amount of ice built up over the vent/ back wall
  • 4 Answers
Check if any piece of ice is stucked in thw vent and also check the thermostat of the refrigerator! When you close both doors you should hear the sound of the vent going fast
Posted on Nov 26, 2014
4 Suggested Answers
gwshaw71
  • 83 Answers
SOURCE: Freezer and Refrigerator section stopped working
check your drain line and check defrost system, defrost thermostat, heater, and timer
Posted on Nov 30, 2007
heatman101
  • 43501 Answers
SOURCE: refrig not cooling
Usually when this happens it is because of a problem with the fan that moves cold air from the freezer section of your unit to the refrigerator section. Either the fan has gone bad or the unit has frosted up to the point of stopping the fan. Try defrosting (unplugging) the unit over night and then check it to see if the fan runs. If not then replace the fan. If it runs and then stops after awhile like days or even a few weeks, then you may need a defrost timer.
The other thing that can cause this is the heating element going bad, but this is not usually the problem. The element can be checked with an OHM meter. If the coil does not have any resistance then it is bad.
You can find parts for your unit by doing a search for “appliance parts”.
Once you get the results of the search, pick a site and when it comes up it will usually ask for the model number of your unit.
Enter your model number and you will then get a page with exploded views and a parts menu.
Find the part you need and then order it.
Check a few different sites to be sure that you are getting the best pricing.
Most sites can have the part to you in a couple of days.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Posted on Dec 18, 2009
heatman101
  • 43501 Answers
SOURCE: Frigdaire- Top freezer cold but refrigerator is not cold enough
Check out these tips...they can help you figure out whats going wrong...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Posted on Aug 12, 2010
Ireland
Hey friend, thank you for the post!
From my understanding you have water leaking out of the freezer of your Frigidaire refrigerator and onto the floor. I would like to ask you a couple of additional questions. First, do you see where the water is coming from? Secondly, what is the model number of your appliance? You can locate your serial tag (which lists your model number) on the inside cabinet of the fresh food compartment normally on the left side in a top mount. But on a side by side it can be found on the right hand side. I look forward to hearing back from you. -Matt
Jul 17, 2014 | Frigidaire 20.6 cu. ft. Top Freezer...
Every Couple of Days water leaks out from under the freezer. I bought it from Home Depot about 2 months ago. What do I do now?
every 8 hours of cooling ( compressor run time ) which may be every cople of days the frig has a auto defrost . your unit may use a a d control so it may do it an any time it decides to defrost . when defrosting the water goes through a drain and under the frig to a holding pan . if pan is cracked or if drain hose is not in the pan it would leak .. it should be under warranty so i would call maytag and im shure they will correct the problem .. mope this helps mm ..majic **** ...
Oct 22, 2010 | Maytag MFD2560HES Bottom Freezer French...
Frigidaire leaking water out the bottom
it comes from freezer. remove back cover of freezer and unclog hole where water collects
Feb 13, 2010 | Frigidaire GLRS234ZA Side by Side...
Frigidaire plht189sska top freezer fridge problem. Freezer is cold, fridge is warm. About a month ago, had the problem of frost build up in freezer, water pooling under veggie bins, warm fridge. ...
If the defrost heating element, defrost timer or evaporater fan weren't working, you'd develop a block of ice on the evaporator. Is the compressor running? If it is, it might have bad valves from the frost buildup scenario. Liquid refrigerant could have gotten to the suction valves. The sealed system should have a five year warranty. Might be time to call a pro
Sep 15, 2009 | Frigidaire PLHT189CSB Stainless Steel Top...
Ice accumulation at bottom of freezer
Hi, Remove the rear inside panel of the freezer and locate the drain hole under the evaporator coils.
Use a hair dryer and melt the ice. Make sure and get the ice out of the drain hole as well.
After the ice is removed, be sure and flush the drain hole with hot water. A baisting surenge works great for the flush.
I hope this helps you. If I can assist you further, please let me know.
Vic
Jun 01, 2009 | Freezers
Water Leaking - Freezer
My mother's fridge had a leak on the freezer side in the front. I removed the cover below the doors and found a plastic coupling in the water line to the water in the door option, when anyone filled their glass with water the coupling leaked. I bought a new plastice 1/4 inch coupling and replaced the old one and the problem was solved. The coupling costs about $3.00 a Lowe's and it took about 2 min. to change.
Apr 18, 2009 | Frigidaire FRS26R4A Side by Side...
Just replaced freezer fan a couple days ago. Now water leaking into top shelf of fridge. Could drain be clogged ? Frigidaire model FRT8S6ESBG.
Frozen drain
Ice maker water line and wiring
harness openings not sealed.
Seal water line and wiring harness
openings.
Drain trough not properly formed.
Ensure drain trough is at 90° angle to
back of freezer and that lip is up on front
and ends.
Divider (foam block) frozen.
Replace divider. Check drain trough.
Visit my site, I offer free help and model and parts number search feature. Movies and instruction manuals for most brands. seanreezehvac@yahoo.com click on link below, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Apr 04, 2009 | Frigidaire FRT8S6ESB Stainless Steel Top...
Leaking water
dianaluscou,
The freezer has a drain hole in it typically in the back at the bottom. This is clogged and needs to be cleared out in order to stop the water problem in the refrigerator section. Remove everything from the freezer and if needed defrost. Look for the drain hole and you can pour hot water or use a hair dryer to melt the ice in the drain. Once it is unclogged, the water problem should stop.
I just did this about 6 months ago on my own refrigerator/freezer.
Cathy
Jan 21, 2009 | Frigidaire FRT21P6BS Top Freezer...
Frigidaire FRS26ZSH freezer leaking
Plz provide me with a e mail adres so i can foward a users manual to you for a Frigidaire FRS26ZSH.
Thanks.
Wouter....
Aug 31, 2008 | Frigidaire FRS26R4A Side by Side...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
