Question about Broan-NuTone N-LS100SE Exhaust Fan Exhaust Fan
Is it possible to connect two fan ducts to a single roof vent?
I have a bathroom vent. I just installed another similar vent in my closet and when I was in the attic I noticed the ducts from both are quite close next to each other. Both of them use 4" ducts and I'd rather not cut another hole in the roof. I know 100% that the new vent has a flap to prevent air back flow. I have not checked the bathroom vent but it's only couple of years old and I assume it has the same. I was wondering if it is possible to connect both ducts to the same vent in the roof, perhaps by using some y-connector. Are there any cons or pros? Is it in compliance with whatever codes that govern ventilation?
    Master:
  • 993 Answers
U should increase the size of vent,if both fans runs the same time
Posted on Jan 20, 2015
If it JUST a vent, then it would be fine. The VENT only allows air to move and is Not pressurized. If it is in fact a vent "fan", like in most bathrooms, then it will still work but for best results, you should Not have both fans running at the same time due to CFM of air being pushed through the 4" opening , it will be trying to accommodate twice the volume as intended/designed for.
Posted on Nov 26, 2014
  • 159 Answers
That'll work for sure. Dan
  • Dan Berry Jan 20, 2015
    Don't agree with comment #1. I have a 3" & a 4" (bath vent & stove fan vent--BOTH going into a 4" attic pipe--no problem at all.ll.
I am fixing a closet in my home. It is part of an exterior wall and creates a lot of coldness in the house. How can I insulate this wall better? My kid is freezing at night she says. <a href
If you have enough room behind the stud wall install 1" rigid foam tape seams and then use the thickest possible roxsul insulation to fill the studs. Or axe the foam and install 6mil plastic on warm side of the wall after insulating tape all seams when done.
Jan 30, 2015 | Cam Spray Pressure Washer Foamer...
Can I connect two bathroom fan ducts to a single roof vent?
No, both cannot be connected to same vent.
Or vent exhause from 1 fan will vent into other bathroom.
All house vents require separate duct.
Nov 26, 2014 | Broan-NuTone Fan,Bathroom Exhaust Broan...
The bathroom exhaust fan in our bungalow is leaking this past week every few days , we are not handy folks and so we are wondering what type of professional do we call in to deal with this leak and...
Sounds like the issue is simply condensation inside the exhaust pipe where it passes through the un-heated attic space. If you use the shower and the exhaust fan, lots of humid air is passing over the inside surface of a very cold duct, then running back down to your bathroom ceiling. You could get any non-specialist handyman to wrap insulation around that duct in the attic. But you can mitigate the problem by running the fan for a few minutes before you start the shower (thereby pre-heating the duct before you give it a blast of moist air) , and leaving it run for 20 minutes afterwards (thereby drying out the duct after use). Regarding the discolored ceiling, the handyman can apply some stain-covering white primer too.
Jan 14, 2011 | Fantech Fans Exhaust Fan In-Line
Some water condensations around bath fan
THATS GONNA HAPPEN WITH THE HUMIDITY IN THE BATHROOM AND THE TEMP DIFFERENCE. TRY INSULATING THE DUCT WORK FOR THE VENT. INSTALL A FLAPPER SIMILAR TO WHAT A CLOTHES DRYER HAS. U DON'T WANT COLD AIR COMING IN. INSTALL A DEHUMIDIFIER.
Dec 12, 2009 | Home
My Bathroom Extractor Fan does not work properly and for some reason the bathroom smells of cigarette smoke when the upstairs neighbours are at home!! Our landlord say's this is not possible!!!
Yes, very possible!. The bathroom fan is connected together, and the upstairs one is down-drafting to you. Have the exhaust checked for blockage, or buy a fan that has a built-in damper that closes the exit when not in use.
Oct 21, 2009 | HP Extractor Fan Kit 110V Rack Mount Fan
My Panasonic FV-11VQL2 seems to have the damper stuck in the closed position. The fan does not exhaust well, ever since we got a new roof (vent and 4" duct too). Any way to unstuck it without going into...
Hubby went into attic. The roofer did a poor job installing the new 4" duct and roof vent; duct was poorly attached and pinched at both ends. He redid both connections, and now the fan works well----no more foggy, drippy mirrors!
So, the fan is fine------the installation of the new roof vent and duct was shoddy.
Aug 24, 2009 | Panasonic Dryers
Panasonic Whisper Warm Installation
The vent fan must be exhausted into the outside air via a 4 inch flex duct, this may be difficult if installed in the wall!
Feb 20, 2009 | Panasonic WhisperWarm FV-11VHL1 Compact...
Moisture on bathroom exhause vent
the fan is pulling too many cfm (cubic feet per minute).you can replace the switch of the fan with a potentiometer type switch (this works like a light dimmer)you can reduce the speed of the fan,or you can use a couple of synthetic fiber filters to trap the condensation.good luck
Jan 04, 2008 | Fantech Fans Exhaust Fan In-Line
Broan-NuTone N-LS100SE Exhaust Fan Exhaust Fan Logo
116 people viewed this question
Top Broan-NuTone Dryers Experts
Mike Squire
Craig Dupler
Level 1 Expert
Are you a Broan-NuTone Dryer Expert? Answer questions, earn points and help others
