Question about Thomson Televison & Video
I have a Thomson Scenium 32" television. It doesn't switch on by one click. After several switching on and off it goes on. Also it frequently goes off too. Pls let me know the problem. Tha
Didn't do any repair as yet.
  • 1,171 Answers
Could be one or all of 3 things. The signal is weak from a low battery in remote, the "eye" that catches signal on the set is dirty, or the TV and remote are old enough that they need replaced. I had one that did the same thing but I dealt with it for 2 years. The set then started going top half of screen black for a short time, then just stayed that way. I replaced the set with another I had in storage. First thing to do is try to replace the remote and set up a new one on your TV. If that won't work, take the remote to a store and find a set it WILL work on. I don't know how old your set is, but it may be time to replace it, but does the TV set come on immediately when you push the power on button on the set itself, instead of using the remote? If it will, then it's in the remote circuit and replacing the remote is the first test you can do to find out. Let me know.
Posted on Nov 26, 2014
    Top Expert:
  • Thomson Master
  • 74,211 Answers
Fault with the main power supply regulator section. Either it will be on a separate board, or on the part of its main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
This fault you state here is a repairable one. Contact any service technician. This is known as start-up problem. The resistors used to get start-up voltage to the SMPS section circuit should be checked. Actually; this is not a user repairable one, as it need some testing instruments.
SOURCE: thomson scenium 44
i have had the same problem.....
my problem was gone after that i cleaned the tv and removed all the dust and **** behind the tv.....
Posted on May 19, 2008
tvtek
  • 1284 Answers
If you changed all 3 CRT's at the same time you are in for alot of alignment. If all 3 need to be replaced then 2 should be replaced then aligned to the remaing original then replace the last after all alignment is done. You will probably need some kind of template provided by RCA to do alignment especially if the set has auto convergence. Good luck....
Posted on Jan 11, 2008
ladywinn
  • 5138 Answers
SOURCE: Thomson Scenium 52 inch television
This is no easy fix problem you need to take set to repair shop, this is a lot of problems with these sets cold solder ,poor connections,bad deflection boards, tuner boards, bad ribbon connectors etc etc ect......BAD Flyback Transformers.Normaly id say your hori out put was shorted but on these sets anything can happen. ThankYou for using FixYa. Have a NIce Day.
Posted on Feb 08, 2008
Russmann
  • 203 Answers
SOURCE: thomson scenium doesn't start when
First, try to unplug and reset. Second, Remove back cover and check for shorted horizontal output transistor with ohmmeter. If shorted replace flyback. Next, carefully disconnect plug connectors from deflection pcb. No need to disconnect h.v. or screen leads. Remove from plastic frame and look at bottom (solder side) for cracks around pins of flyback transformer. Resolder all pins. Last, look for two or three bulging capacitors in power supply on same board and replace. Any of these things can cause a dead set. Good luck, Russmann.
Posted on Dec 12, 2008
SOURCE: thomson DV3 digital terrestrial recorder
this recorder is constantly getting bad reviews, I think it is unfair because mine does the job, however this problem occured heres what you do.
turn off at the mains and wait 20secs turn back on and hold the standby button untill a light appears.
in sequence up down left right menu ok press the buttons on the front of the box wait 60 seconds and the normal red light will appear turn on box and there you go.
Good Luck further issues visit www.topuptv.com WARNING- doing this procedure will swipe your library but i think it is the only solution
Posted on May 04, 2009
What does 3 flashes on the standby light on a Thomson scenium 44jw 611s mean
These blinks [flashes] are fault indication (Error Codes).From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it.This will make repair easy.These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times.Count it carefully.If you wish to get some details, check the site linked here.It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given.Surf the site with patience.
Feb 25, 2015 | Thomson Televison & Video
TV Thomson Scenium 28WF64E L
See that any of the buttons are pressed or any thing is shorting any of the switches or wires or PCB in your Television
Mar 15, 2008 | Thomson 28VK25US TV
Thomson scenium 30lcdb03b manual
this tv is old now and thomson no longer have them in stock
the menu on the tv is very good and should cover all conections and inputs and tunning
Jan 07, 2012 | Thomson 30LCDB03B 30 in. HDTV
Tv not coming on just red light flashing on and
thomson scenium jw 611s not coming on just red light flashing on and off at front of tv
Jul 13, 2010 | RCA Scenium HD65W20 65" Rear Projection...
Thomson 32" flat screen periodically switches on and off very qui
the standby power supply is probably faulty . there is a service kit available but needs to be fitted by a tv engineer and is available from www.tvs-services.com or call 01245382539
Jun 04, 2010 | Televison & Video
Thomson scenium keeps switching its self off
I would start by replacing the lamp and the safety switch inside the lamp door. Other fialures can be cused by the ballast and color wheel. I am assuming the set comes on with a picture,then shuts off,if not pls be specific of what it is doing!
Jun 03, 2010 | Televison & Video
Thomson 40KW611S - when switching set on, light flashes then goes into standby & cannot get to work.
this is an error code and directs the service engineer to where to lookfor the fault. I recomendyou contact a compertant service enginner to evaluate this fault for you as there are not much the layman can do.
Oct 11, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
MY THOMSON SCENIUM BOARD IS DAMAGED!!
CALL 01245392539 AND THE UK THOMSON SUPPLIER WILL BE ABLE TO TELL YOU IF IT IS STILL AVAILABLE
Feb 11, 2009 | Thomson LCDB 03B 27 in. Television
THOMSON SCENIUM 44RW65US Red light flickers
i have the same problem. i have to switch it off at the mains 5 times b4 it comes on
Feb 08, 2008 | Akai LCT2660 26 in. HD-Ready LCD...
Televison & Video Logo
Top Thomson Televison & Video Experts
 Grubhead
Grubhead
Are you a Thomson Televison and Video Expert? Answer questions, earn points and help others
