Question about Camping, Backpacking & Hiking
I need a charger
Nothing else
  • OlPoop Nov 26, 2014
    Your Torch wants a 4.2V 600mA charger. Look on ebay and you can find one for a few dollars. Here's an example:http://www.ebay.com/itm/Brand-New-Univer... Its only 500mA but should work fine.
    Problem Solver:
  • 17 Answers
Any more info? Do you want a battery charger, to charge the battery(s) out of the headlamp? or do you want a charger that connects to the headlamp? In the latter case, some info on the headlamp would be required.
Posted on Nov 26, 2014
Testimonial: "i need a charger that charges battery in torch by plugging into mains. atahis is for a Mission Cop 2,000,000 candle power spotlight torch"
    Your Torch wants a 4.2V 600mA charger. Look on ebay and you can find one for a few dollars. Here's an examplehttp://www.ebay.com/itm/Brand-New-Univer... Its only 500mA but should work fine.
    The link got cut. Here's the item# 3392971575
Napa charger #85-435 will not charge
He said his battery charger is not working, this has nothing to do with the car not starting or charging? So if anyone can recomend what he needs to do to get his battery charger working would be helpful to him.
Mar 01, 2013 | Cars & Trucks
Toshiba Satellite L655 Not Switching on
You mentioned that it won't turn on with the charger (without the battery). Does this mean that it turns on if the battery is in?
If it turns on with the battery, then you need to replace your AC adapter.
Feb 13, 2013 | Computers & Internet
The laptop lenovo z560 does not switch on. With battery it shows 2 short flashes of battery charge idicator, an one long (about 10 sec) and than nothing is happening. Withou battery nothing happens after...
Hi smialkovskyi,
With this specific concern that you do have, unable to turn on your Lenovo Z560, there 3 components that need to be checked. Your battery, the AC adapter (charger) and as well as the DC In port.
1.Based on what you have said, with the battery alone you have noticed that it's led indicator will show however still can't turn on system. Battery seems to be in good condition however no enough charge to turn on the system.
2. For your AC adapter, when you're using it without the battery nothing happens. To check if this is defective try using another AC adapter that is compatible to your unit. If your computer turned on using another AC adapter then your charger needs replacement. (You may also try using your charger to other unit where it is compatible, just to test).
3. However, if after doing the previous instruction and still system won't turn on then it could be the DC In port which is defective. This port is built in to *********** board.
After doing all these you need to contact Lenovo. They might be replacing your charger or *********** board if system is under warranty.
Hope this helps.
Thank you for using Fixya.
Jan 28, 2011 | Lifetime Lenovo/IBM IdeaPad Z560...
My eee pc 1005hab was dropped on the floor breaking the charger while still in the port, i took the charger out, netbook still on and used it till the battery died. that was two weeks ago. i now have a new...
The jack inside the laptop where the power supply plugs into is broken. It will need to go to a computer tech for repair, chances are the jack will need to be replaced and in order to do that a total dis-mantling will need to be done.
Jan 05, 2011 | ASUS Computers & Internet
I am afraid that I have bad news. You have more than likely broken the connector in your computer. Unless you know someone that can open the case and try to repair it you will need to send it in for repair.
Jan 05, 2011 | ASUS Eee PC 1000HE Netbook
Problem charging my Nokia 7610 cellphone
1. try to check if your charger is working or not
2. if charger is good.then try to replace the charging socket of your phone.you have to open it,but if you dont know how to do it.you need to go to a technician to fix it for you rather than taking the risk.
Apr 11, 2010 | Nokia 7610
Will not charge, or turn on
Probably the plug on the navman has suffered what we call dry solder joints from inserting and pulling out the charger you need a tech to fix it. soldering is nesessary shouldnt be too expensive I fixed mine its about half an hours work if not too damaged inside
Feb 15, 2009 | Navman F20 GPS Receiver
Help!Phone does nothing!
Ok you need to replace that charger cos thats the one that is doing all the damage. Check your battery voltage if its below 3v then you need to rejuvenate it back to its original capacity. It will be ok good luck.
Jul 02, 2006 | Samsung VM-A680
Camping, Backpacking & Hiking Logo
91 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
