Question about Ipcw Ford F150 / F250 Ld 1999 2000 2001 2002 2003 Fog Lights Projector W/ Halo Clear-1 Pair
My name is don, i have a 2003 ford 150,when turn the heat control to heat, the switch from cold to warm does not change and continues to blow unheated air. what should i look for.
  • 28 Answers
The "blend door" directs air from the AC core and Heater core. It is regulated by an electronic actuator or if manual control with a wire from the lever to the door.. Either the actuator is bad or the blend door is broken which frequently happens. The rest for the system - fresh/recirculated air, foot/dash/defroster, are vacuum controlled. You have to pull of the dashboard to access it. Check out this guy's photos: http://tinyurl.com/nce4jl9
Posted on Nov 26, 2014
  • 33 Answers
Two possible causes, Blocked heater core, or the inner door in the heater plenum is not closing to change where the blown air from the fan is going.
With the engine warm and running, BE CAREFUL, there should be two 5/8 or similar hoses going to the fire wall at the back of the engine. Touch both hoses and see if both are Hot to the touch. If both are warm then you have hot coolant going through the heater core which is good. If one is hot and the other is cool or cooler, then you don't have water circulating through the heater core.
Look for a valve assembly on one of the two hoses. Not sure if Ford uses a hot water valve for the heat anymore or not. If there is a valve touch the heater hose on both sides of the valve. Both sides should be the same temp Hot is valve is open. If one side is hot and the other cool you have no circulation. Needs to be fixed.
Most modern heater plenum doors are now electronic. Go over the fuse panel and look for a blown fuse for heat ac. Check them all. Not sure what it will be labeled. If all fuses check out, look under the dash and see if there are any wires and plugs dangling from any where near the heater plenum. If there are try to plug them back in.
The only other thing you can try is if the plenum doors are vacuum actuated. With the care running, and the heater set to heat but the fan off or as low as possible, get under the dash and listen for a hissing sound which would be a vacuum leak. fix the leak if you have one.
Good luck.
    Problem Solver:
  • 6 Answers
Heater core,plugged up.
  • 29 Answers
Blend door actuator located under dash When functioning normally it switches a flap that diverts the air, Common problem on ford / lm products
I have a 2010 f150 lariat dual climate and passenger side blows cold and driver side is warm I don't hear any clicking from changing the temps like they say u hear it the blend door how do I diagnose
Some vehicles have a DCCV that controls flow of coolant to one side and the other. Don't know if yours does or not. And you won't hear an electric blend door motor very easily. don-ohio
Jan 27, 2017 | 2010 Ford F-150
I have a 2003 Ford F-150 FX4 5.4 and the AC only blows out of the defrost and help
Dustin, Sound like vacuum loss to position switch. Defrost is the default position when vacuum is lost in vent control system. Check any and all vacuum lines and connections under hood first, especially any that run through firewall. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
2001 F150 V6 4 2 AC Heat Stuck In Defrost Easy Repair
Heating Vent Control Issue Page 2 Ford F150 Forum
2003 150 heater auto climate control Defrost Only Ford F150 Forum
Fixed the EATC defrost only Ford F150 Forum Community of Ford Truck Fans
Apr 13, 2016 | Ford Cars & Trucks
My 92 E350 blows cold air new water pump backflushed system but still blows cold air.
Check for stuck thermostat. Feel the heater core hoses to see if they are warm.
Oct 16, 2014 | Air Conditioning and Heat for Ford E350
No heat from vents
As per your problem mentioned. There are few solved help links to troubleshoot these problems. Go through the list and Click the link below:----
2000 Toyota Avalon: No heat on Passenger Side?
http://whatisbyme.blogspot.in/2012/05/2000-toyota-avalon-no-heat-on-passenger.html
No heat on Oldsmobile Silhouette?
http://technoanswers.blogspot.in/2012/02/no-heat-on-oldsmobile-silhouette.html
Heater blows cold?
http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
Heat blows cold on drivers side and hot on passenger side?
http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html
Hot air on the driver's side vents only?
http://repairhelpcenter.blogspot.com/2012/01/hot-air-on-drivers-side-vents-only.html
Temperature gauge does not move and no heat when heater is ON?
http://technoanswers.blogspot.com/2012/01/temperature-gauge-does-not-move-and-no.html
1992 Toyota Camry: A/C Control light Flashing and A/C not Blowing Cold?
http://technoanswers.blogspot.in/2012/04/1992-toyota-camry-ac-control-light.html
No heat, blower blows only cold?
http://technoanswers.blogspot.in/2012/02/no-heatblower-blows-only-cold.html
Ford F150 Ac only blows through defrost vents?
http://technoanswers.blogspot.com/2012/01/forf-f150-ac-only-blows-through-defrost.html
Dodge A/C come out of defrost vents only?
http://technoanswers.blogspot.com/2012/01/dodge-ac-come-out-of-defrost-vents-only.html
Ac vacuum line on dodge cummins?
http://technoanswers.blogspot.com/2012/01/ac-vacuum-line-on-dodge-cummins.html
Ford ranger AC blows cold through defrost vents instead on cabin vents?
http://technoanswers.blogspot.com/2012/01/ford-ranger-ac-blows-cold-through.html
2005 Chrysler PT Cruiser: A/C Blows Warm?
http://whoisbyme.blogspot.in/2012/06/2005-chrysler-p8t-cruiser-ac-blows-warm.html
2009 Mercury Grand Marquis: A/C blows Cold From Defrost Vent Only?
http://whoisbyme.blogspot.in/2012/06/2009-mercury-grand-marquis-ac-blows.html
AC not blowing through Vents on 2007 Chevy Trailblazer?
http://schematicsdiagram.blogspot.in/2012/04/ac-not-blowing-through-vents-on-2007.html
Passenger side temperature is warm air out of dash vents?
http://schematicsdiagram.blogspot.in/2012/04/passenger-side-temperature-is-warm-air.html
These will help.
Thanks.
Nov 28, 2012 | 2006 Ford Taurus
I have no heat in my 2003 Mitsubishi Lancer. When
The cable that pulls the cool/heat switch on the a/c gets weak and it doesnt allow the dial to switch over to heat. You can see that cable and the way its supposed to work on the right side of the gas pedal over it. I usually just use my foot to push that switch over to heat and reach with and pull on it with my right hand to cool.
Jan 08, 2010 | 2003 Mitsubishi Lancer
2003 winstar no heat
Check the operation of the temperature control door. It is located in the center of the dash behind the radio. Look up between the gas pedal and heater case. It is white in color Move the temp knob while watching the actuator. If it is clicking it is bad. Good luck.
Oct 12, 2009 | 2003 Ford Windstar
2003 Ford Ranger 4 Cyl 2.3 litre engine
Is the blower blowing? if not could be a blown fuse or bad blower. If the blower is working make sure your coolant level is full, If both of theese things check out , you may have a vacume line loose somewhere that controls the duct witch controls it to change to defrost ,vent or hot to cold.
Oct 07, 2009 | 2003 Ford Ranger Regular Cab
Driver's side air blowing warm, won't change
Sounds like there is a crack in the vent that leads to the drivers side, and hot air from the engine is leaking through.
Aug 29, 2009 | 2003 Hummer H2
No heat - when temperature selector knob is turned it stays cold
There shouldn't be anything down near the transmission that would affect your heat output. What I'm thinking is there is a possibility that the heater controls on the dash are malfunctioning, and when you select heat, for whatever reason the system isn't getting the signal to go warm. Would you be able to pull a heater control panel out of a salvage yard? If so, it shouldn't cost more than $10-12 and might be a worthwhile investment. If your controls are not sending the signal to have the air go warm, it'll continue to blow cool/cold.
You might also call a shop and see if they have the capability to scan the car for chassis failure codes, similar to what they do for the engine computer when you get a check-engine light - my Audi has this capability and I've seen it on other cars as well.
Oct 21, 2008 | 2003 Dodge Caravan
Ipcw Ford F150 / F250 Ld 1999 2000 2001 2002 2003 Fog Lights Projector W/ Halo Clear-1 Pair Logo
119 people viewed this question
Top Ipcw Office Equipment & Supplies Experts
Robert McCall
Robert McCall
 Russ Hill
Russ Hill
Joel C.
Joel C.
Are you an Ipcw Office Equipment and Supply Expert? Answer questions, earn points and help others
