Question about Malber WD1000 Front Load Washer/Dryer
How do I dry clothes
Help!! I need to pack for thanksgiving and have only dirty clothes!
    Welcome Back:
    Visited the website for 2 consecutive days.
Some models of the Malber wd1000 you need to remove half of a full load and then hit the half load button. The condensing dry cycle will come on then. I don't find that it gets the clothes very dry.
Posted on Mar 18, 2016
Either hang them up wet or put in clothes dryer
Posted on Nov 26, 2014
How do I take the drum of a dc33 to wash it
Hi there, it's Jack at Dyson.
To remove the clear bin, first separate the clear bin and cyclone pack from the vacuum cleaner. Press the trigger to open the bin base, as if you were emptying the machine. Then with the bin base still open, press the silver catch on the rear of the cyclone pack to remove the clear bin.
You can then rinse the clear bin in cold water without detergent, or wipe it using a damp cloth. Make sure it's completely dry before reassembling the vacuum.
Please note, the cyclone pack should never be washed or submerged as this could cause damage not covered under guarantee. You can use a soft brush or a dry cloth to remove any fluff or debris from the shroud.
If you'd like further help or guidance, you're welcome to contact the Dyson Customer Helpline on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Feb 23, 2015 | Dyson DC-33 MultiFloor Upright Vacuum...
How do you wash a j whistler jacket?
Usually most of the people can people give their jackets for dry clean because some times if we wash clothes from normal washing powder then your jacket will shrink, rough and loose its shine. It is better to wash your jacket with mild gel liquid which are used to wash the woolen cloth or you can give it to dry cleaner.
Carharrt Jackets Buy Pants Outerwear by Carharrt Here
Dec 24, 2014 | J. WHISTLER Down-filled Snorkel with Faux...
Why dryer shuts off too early on auto
The sensor detects the moisture content of the clothes, If the clothing is packed tightly some of the clothes in the middle of the pile might not dry completely, if the clothes on the outside near the drum have low enough moisture. If you have a position on the control for dryer clothes or a more dry position try using that or use timed dry.
Aug 01, 2014 | Whirlpool Dryers
Olympus stylus 1050 sw
Does not sound like everything is perfect. Did you check the battery contacts? also the contacts in the battery housing of the camera? did you check the battery door? There is a (very small) switch, that indicates the door is closed. If that is defect, or perhaps just a spec of dust is in there it could spoil all the fun.
If contacts are not clean and shiny, try cleaning them with a dry cloth. Never use sharp tools or sanding paper. If the contacts are really dirty or oxidised, use just a little contact oil on a cotton swap, and after that, carefully clean and rub away all the oil with a dry cloth. It will damage the contacts beyond repair.Use some pressed air, if you think the battery cover switch is dirty.
Jan 14, 2014 | Cameras
The auto dry sensor cycle shuts down before clothes are totally dry -paul
Hello Paul,
The problem with your dryer very likely is that the sensor bar is dirty and needs to be cleaned...especially if your using fabric softner sheets they leave a coating on the sensor bar and it cant properly read that the clothes arent yet dry.
Its very easy to clean the sensor bar,just need to use some rubbing alcohol and the green scrubby side of a kitchen sponge and clean the sensor bar,then rinse with plain water.
GENE
Sep 16, 2011 | Dryers
Dryer turns on and rotates. However, does not dry clothes completely. Cycle signals wet,then damp,cool down and finally dry,but clothes are still wet. Sometimes the dryer works fine and completely dries...
This problem may be the result of a dirty lent filter which if clogged will short cycle the dryer and the clothes will still be damp when done. Also a dirty exhaust pipe (usally 4") will prevent the clothes from drying correctly. Make sure that the air is leaving the machine. To do this you have to go outside when the machine is running.
Mar 21, 2010 | Kenmore Dryers
Black Printhead needs cleaning - how do I get to it?
Print cartridge
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth.
Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge .
Hope this help. Please Rate My Response! Thanks!
Aug 27, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Hp photosmart 2610 not recognizing new color printer cartridge (97)
Print cartridge
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth. Use a dry, lint-free cloth to remove moisture from the contacts.
Aug 19, 2009 | Office Equipment & Supplies
Dirty Mirror
You must be very careful when cleaning the mirror, it is not like any other mirror as the silver is on the front of the glass. I believe that Hitachi's are made of glass and not mylar.
Do not use a glass cleaner, as they have drying agents in them.
I try to avoid cleaning the mirror unless it is really dirty. It is very easy to leave streaks on the surface.
Most likely you would be well served by using a mild detergent in a bowl of water, a soft cloth, (I like to use cloth baby diapers) anything that is lint free. Do not let the cloth drip into the set.
Clean the surface with the damp cloth and dry with a clean dry cloth.
Try to use the dry cloth to remove any streaks.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I have helped you, please help me, and rate this suggestion a FixYa rating. If not then please comment to this post and I will try to help you further.
Thank you for you support and use of FixYa
May 14, 2009 | Hitachi 60FX20B 60" Rear Projection...
Olympus 795 sw lens moisture
Exterior:
• Wipe gently with a soft cloth. If the camera is very dirty, soak the cloth in mild soapy water and wring well.
Wipe the camera with the damp cloth and then dry it with a dry cloth. If you have used the camera at the beach, use a cloth soaked in clean water and wrung well.
• If any dirt, dust, sand, or other foreign material adheres to the periphery of the lens cover after use, or the lens cover does not move smoothly, wash the camera using the method described on P. 66.
Monitor:
Lens:
• Blow dust off the lens with a commercial blower, then wipe gently with a lens cleaner.
Battery/Charger:
• Wipe gently with a soft, dry cloth.
Note
• Do not use strong solvents such as benzene or alcohol, or chemically treated cloth.
• Mold may form on the lens surface if the lens is left dirty.
Apr 20, 2009 | Olympus Camedia C-50 Zoom Digital Camera
Open Questions:
See all Malber WD1000 Front Load Washer/Dryer Questions
Malber WD1000 Front Load Washer/Dryer Logo
93 people viewed this question
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
ashburton
Dan Webster
Dan Webster
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
