Question about Refrigerators
My mrf335 fridge is too cold even in stand 1.
Cleaned the back
    Scholar:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 52 Answers
I can't find your model listed anywhere, could you confirm the model number?
Either way, you'll want to check your temperature settings on the fridge. If there's a dial in the fridge, make sure it's not set too low.
Posted on Nov 26, 2014
Testimonial: "Daewoo MRF 355. Maybe more than 10 years old."
  • CaidJ Nov 27, 2014
    I would also look into replacing the thermostat it seems that this model has been known to require a thermostat replacement, and if the fridge is stillcold, the thermostat will control the level of cold a broken thermostat will stop the fridge from being able to sense when it has reached its target temperature, resulting in itcontinuing to cool beyond the desired temperature.
    sorry for the lack of punctuation, my phone's auto puncuation appears not to work with this site.
4 Suggested Answers
  • 5 Answers
SOURCE: fridge not getting cold
Hi you have probably a leak. must inspect all piping to see if there is some small residue of oil.if you find oil you find the leak
Posted on Jun 29, 2008
lenwest
  • 150 Answers
SOURCE: fridge and freezer not getting cold
  • You have 2 fans Make sure your top fan is working ,its located inside the freezers back wall. If it is working the vent from the freezer down to the refrigerator may be blocked.With out a fan you have no circulation .Also if you can move everything out unplug it turn it off w/ doors open 12 to 24 hrs this will free up any clogged tubes. Good luck.
    Len West
Posted on Feb 19, 2009
  • 21 Answers
SOURCE: fridge not cold enough and freezer too cold
check the fan to see if it is running.
Posted on Sep 20, 2012
Fridge started working again after I cleaned the grill, then freezer stoppped, unplugged and waited now freezer is good but fridge won't stay cold. The temp says 56. Ugh! Model # is PLHS67EGSB4.
My Freezer is Cold But My Fridge is Not! - YouTube
? 1:51
www.youtube.com/watch?v=OiKCqniraM8
Nov 5, 2013 - Uploaded by Appliance Princess What to do if your refrigerator is warm, but your freezer is stillcold. ... Cleaning them is a good idea, even if it isn't the cause, because it will improve the fridge's efficiency. ... How does thefreezer fan's failure cause a fridge not to stay cold? .... How To Fix Your Fridgidaire Refrigerator (if the compressor won't ..
Sep 23, 2015 | Refrigerators
Fridge not cold enough and freezer too cold
Sep 20, 2012 | Whirlpool Refrigerators
Freezer not cold enough
setting the freezer at 7 opens the baffle from the freezer to the fridge to make the fridge colder. It works completely opposite than a person would think. Feel in the back of the fridge with it on this setting. The freezer is dumping all its cold air into the fridge thus equalizing the two parts. if you move the selector to 1, you should feel the air from the freezer cut off in the fresh food compartment. try a setting in the middle and let sit for 24 hours. Hope this helps
Jan 25, 2012 | Amana Refrigerators
I do not recall the model number for my side by side fridge. We did not use the fridge for 1 1/2 to 2 years. I recently cleaned it up, plugged it in and while it runs and the outside feels cold to the...
after standing for so long it may need regassing.if you have left it running for at least 48 hours and no cooling occurs,this would be my first fix
Oct 21, 2010 | Kenmore Refrigerators
Fridge and freezer not getting cold
    Len West
Feb 19, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Frigerator not cooling
HI thanks for the question. the water at the bottom means a clogged drain tube. which would cause the fridge not to get cold. its blocking the air vets , so the cold air, cant get down to the fridge section. . remove back wall ,of the freezer and clean all the ice build up. the drain tube goes all the way down, to the bottom drain tray .clean that tube. thanks the appliance doc. please rate my answer.
Oct 07, 2008 | Refrigerators
Servis Fridge not cold enough
Hi ruthcart1,
I'm Harvey the Master Plumber.
Your problem is: You have a free standing fridge freezer from Servis (silver) and the fridge doesn't seem to be as cold as it should be. The freezer is absolutely fine just the fridge even though you have adjusted the thermometer inside.YouI've had it maybe 3/4 years.
You're still under warranty. Modification now voids the warranty. I would call warranty repair. This should be their headache not yours.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 10, 2008 | Refrigerators
Fridge not getting cold
Jun 29, 2008 | Frigidaire FRT21P5A Top Freezer...
Kenmore Side by Side Refrigerator too cold
On a fridge freezer only the fridge temperature is monitored. In a cold location the fridge might not even need cooling and the freezer would get too warm but the thing won't care.
If the fridge sensor sees it as too warm then it will keep the motor running and the first thing to get really cold is the freezer.
Remember the freezing part is not temperature controlled ion a fridgefreezer.
Apr 28, 2017 | Refrigerators
Freezer Working, but Fridge side is not cold.
ou most likely have a defrost problem is there a large build up of frost in the back wall; of the freezer??
Jan 26, 2008 | Frigidaire FRS26KF5C Side by Side...
Refrigerators Logo
50 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
