Schematic diagram for p450la-motherboard on the pavillion a465c desktop
On p450-la motherboard jumper j19 original position.
    Problem Solver:
  • 19 Answers
The first 2pins near sata port
Posted on Nov 26, 2014
4 Suggested Answers
  • 11 Answers
SOURCE: Upgrading CPU on Asus PSBW-LA motherboard
Dealing with OEM PC's can be rather difficult. Most of the specifications on those chips are the same, except the FSB (Front System Bus). The E6300 is 1066MHz and the E6550 is 1333MHz. I don't believe that this is set by jumpers (i'm 95% sure). I would look into BIOS to see if it is an available option to change (though most of the time this setting is set on AUTO). There is a chance that you will need to provide a BIOS update. If you chose to do this be very careful as this is dangerous. Should something interupt this (power outage or something like that) your computer could become useless. Definitely make sure to do a lot of research and preparation before performing an update.
Posted on Mar 25, 2009
SOURCE: Desktop Board D915PGN - Motherboard - ATX - i915P - LGA775 Socket - UDMA100, SATA - HD Audio: the jumper pin settings a diagram ...
no power
Posted on Jul 08, 2010
joecoolvette
  • 5660 Answers
SOURCE: front panel pinout connections for ASUS A8M2N-LA (NodusM3
The Asus A8M2N-LA motherboard was made SPECIAL for HP.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00757531&tmp_task=prodinfoCategory&cc=us&dlc=en&lang=en&lc=en&product=3339286
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00820191&tmp_task=prodinfoCategory&cc=us&dlc=en&lang=en&lc=en&product=3339286
As such Asus has no info on it.
Looking at the second link posted (Motherboard Specifications), scroll down to the bottom, and click right on - Motherboard Layout
Motherboard layout shown (Direction), is the same as is installed in your computer; Processor to the Top, white PCI slots to the Bottom, Ram Memory to the Right.
The plastic front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the cables (Wires) go to from the Front Panel, is the Front Panel header.
Abbreviated F_PANEL 1, at the bottom right corner of the motherboard, is the Front Panel header.
There are 9 contact pins. Two rows.
Across the Top row they are numbered ODD.
Across the Bottom row they are numbered EVEN.
Coming from the Left side of the motherboard towards the right side, on the Top row;
Pins 1, 3, 5, and 7
Coming from the Left side of the motherboard towards the right side, on the Bottom row;
Pins 2, 4, 6, 8, and 10.
A) Pins 1 and 3 are for the HarDDrive activity LED light.
Pin 1 is for the Positive wire. ( + )
If the HDD LED is dim when operating, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pins 2 and 4 are for the Power On LED light.
Pin 2 is for the Positive wire.
D) Pins 6 and 8 are for the Power On switch.
Regards,
joecoolvette
Posted on Apr 10, 2012
Tip
Schematics + diagrams + laptop + desktop + motherboards
on Mar 11, 2015 | Computers & Internet
BDQ20 Compal LA-1711 motherboard diagram
http://www.smdcode.com/media/service-manuals/motherboards/compal/compal-la-1711-rx02-d-schematics.pdf
Jun 11, 2012 | Dell Inspiron Computers & Internet
I cannot recover my bios password could someone help plz?
Most motherboards have a jumper switch usually situated close to the CMOS battery. The jumper usually connects over 2 pins with an open pin next to these. By moving the jumper over to the open & center pin you will reset all BIOS settings, including your BIOS password. Move the jumper back to its original position before turning your PC on.
In some instances you will find no BIOS jumper. In such a case you can clear the password by removing the CMOS battery from the motherboard for a few seconds and then replacing it.
Best wishes,
Graemevm
Jul 25, 2011 | eMachines EL1352G-01w (884483537679) PC...
I have a acer m1641 when i am using it, it shut down and i can't
Check your system board(motherboard) for a CMOS reset jumper. usually located near the CMOS battery. change it over to the "reset" position. wait 5 mins boot pc. if it makes it to windows. shut down move the jumper back to the original position and try to boot.
Jun 08, 2009 | Acer Aspire M1641-U1521A PC Desktop
I NEED THE JUMPER SETTINGS FOR MICRO STAR MS-6533E MOTHERBOARD. THANS FOR THE HELP!
why are u trying to set the jumpers ? i should have thank u if u add some more details. all the jumpers onboard have their own purpose. look carefully on ur mainboard, u'll see the jumpers with their distinct labels.
May 05, 2009 | Computers & Internet
Need jumper diagram for motherboard
Check that the hard drive is set to "slave" on the jumper settings where you connect it (if it's IDE). Also, check the boot order in the BIOS (or setup as it may be called when booting up) to make sure that they computer's not trying to boot off the new drive rather than the old one. I don't think the jumpers on the motherboard will help you at ALL. Drive jumpers are the only thing and as mentioned - set the new drive to SLAVE and make sure the original drive is on MASTER (this is usually all recorded on the top of the drive on the label)
Dec 15, 2008 | Dell OptiPlex GX520 PC Desktop
Compaq for Evo D300 Motherboard
The manual can be found here. There is a numbered diagram inside. http://www.eserviceinfo.com/downloadsm/5105/Compaq_Evo%20300-500.html Hack
Jul 09, 2007 | Compaq (281946-001) for Evo D300...
T2893 Motherboard Layout - Where do the power jumpers go?
go to this link for the information you need http://www.intel.com/design/motherbd/sr/sr_con.htm#IC
May 05, 2007 | E-Machines T2893 PC Desktop
Computers & Internet Logo
David Payne
David Payne
