Question about Crafts & Hobbies
How do i change a none dcc engine to one with sound and all the stuff
When trying to give a decoder a new address i keeps coming up error code 12how do i get around this
this might be due to electrical "noise" on track or near by , me I use a one piece dedicated track with its own power supply to power my dcc stuff when programming them , if your not in that position financially then try using a short one piece of your own track that doesn't have ends or go anyplace , also try to avoid programming near floursent lights these things throw out tons of electric noise !! and it drives my command system nuts sometimes
Dec 03, 2015 | Bachmann Easy Command Dynamis Wireless DCC...
Retrivemy old home page and info..was hacked also changed from verizon to comcast, lost all old info find it under joseph.lyons@verizon .net home page is new with none of my old info...help
There is something wrong with this question. Poster is Patricia and account asked about is Joseph. Sounds like someone trying hack her boyfriends stuff
Jan 22, 2015 | Facebook Social Network
What is the most common problem on the engine kompressor for w 202
none really bullet proof service regular it should be fine for ever fingers crossed only iffy stuff leaky cylinder head gasket they leek engine oil down the sides fan belt tensioners rattle some times the exhaust manifolds crack but this is on the early models but mine has 179000 miles and i have had no problems had a 190e which uses same block and that had 250000 miles still beautiful engine
Jun 26, 2014 | 2002 Mercedes-Benz C-Class
The red brew light comes on but will not brew about 3 years old
Amazing! My dcc-1200 developed the identical problem on the identical day. Sounds like planned obsolescence. I will watch this space for solutions. Sorry I can't help; I'm frantically looking for my receipt.
Dec 03, 2012 | Cuisinart DCC-1200 Coffee Maker
Lexus oil gel
change engine oil every 6000kms and a oil filter every third oil change and no problem ,this jelly is caused by not changing oil often enough so warm up engine and then drain some out then add about a litre of diesel and a good squirt of fairy liquid washing up stuff then run engine on idle for half hour and then drain it out ,refill with new oil filter and use a the cheapest diesel/petrol oil for a turbo engine you can find and use this all the time none of this fancy long life stuff but the cheapest you can get and this will keep the inside of the engine clean and make it last for ever.
Feb 06, 2012 | Cars & Trucks
Bad switch on DCC-1200W, Can I change it?
I would call Cuisinart and try getting an in-warranty exchange instead. They don't sell the switch parts.
Aug 21, 2008 | Cuisinart DCC-2000
Cuisinart DCC-1200 Coffee maker -
The machine is probably toast - but it's covered by Cuisinart's three-year warrany. Customer Service: (800) 726-0190. They charge $10 shipping, unless you live in California.
Jul 17, 2008 | Cuisinart DCC-1200 Coffee Maker
Ports for irc, dcc sending
it sounds like you will have to set up a virtual server on your router. I have had to do something similiar for traffic.
Feb 19, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
DCC port problem-1
You have to forced ON the DCC lead on Config - Circuit - Options - CtrlLeads.
ilker
Feb 13, 2008 | Alcatel Newbridge MainStreet 3600...
Crafts & Hobbies Logo
56 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
