Question about Sewing Machines
Singer626 bobbin still not filling needle working tread tied off but still wont fill or work
  • Sewing Machines Master
  • 627 Answers
I'M NOT SURE ABOUT YOUR QUESTION BUT IF IT MEANS THE THREAD ISN'T COMING UP FROM THE BOBBIN THEN HERE'S THE POSSIBILITIES:
1. YOU NEED TO HANG ON TO THE TOP THREAD WHILE YOU TURN THE HAND WHEEL. IT WILL COME UP IF EVERYTHING IS FUNCTIONAL.
2. THE TIMING IS OFF SO THE ANSWER IS GET IT TIMED OR TIME IT YOURSELF.
3. IF YOUR THREAD IS GETTING STUCK WHILE IT TRIES TO COME UP THROUGH THE HOLE OF THE PLATE YOU MAY HAVE SOME ROUGH SPOTS IN THE HOLE. FIX IT WITH A FINGER NAIL FILE AND MAKE IT SMOOTH.
Posted on Nov 26, 2014
Zenqi
  • 208 Answers
SOURCE: needle not picking up bottom thread
Remove the needle plate and the bobbin case.
Ensure that the needle is inserted all the way up into the needle clamp.
Set the machine for straight stitch, center needle position.
Slowly turn the handwheel in the normal sewing direction and observe the following hook timing setting:
When the needle reaches it's lowest point and travels up 3.5mm, the point of the hook should be directly behind the needle, or at least within 1 or 2mm.
Another view is as the hook passes the needle, it should pass the needle slightly above the eye of the needle.
If the timing looks good, use some alcohol on a bit of cloth to clean the hook, careful around the tip of the hook as it is very sharp.
If the hook timing is off, you will need to take it to a knowledgeable service person as there are several possible solutions and several other related adjustments which will need to be made.
Posted on Jan 16, 2010
SOURCE: Machine wont pick up bobbin thread
needle won't pick up thread I think the timing is off, how do I retime it?
Posted on Nov 18, 2007
bargainbox
  • 1388 Answers
SOURCE: bobbin filling
The handwheel may have a pull out/push in action to disengage/engage the clutch, or it may automatically disengage when the bobbin winder is moved to the right for winding........hold a short tail of thread to get it started and you should be away.
Move the winder to the left for sewing, or push handwheel in, according to the mechanism.
Posted on Jun 01, 2008
SewTechWayne
  • 186 Answers
SOURCE: Bobbin filling
Does the winder spin freely by hand? If so then it needs to be adjusted, maybe a new bobbin tire also. If not then try oiling it and freeing it up by hand.
Hope this helps.
Posted on Jan 31, 2009
SOURCE: Filling the bobbin with my Juki DDL-5550-6
It's actually designed that way on purpose so you can wind a bobbin while sewing. If you lift the presser foot, at least it'll make less noise in the process.
Posted on Apr 16, 2009
How to fix a hand wheel that doesn't move.
if its stuck physically then don't force it , have a look with a strong light in the bobbin compartment for foreign objects , ive seen needles break off and lodge in the bobbin spool locking it tight
Mar 10, 2016 | Euro-Pro Sewing Machines
How to fill the bobbin with thread
The bobbin is a little metal wheel that is usually housed under a plate where the upper needle darts down into. Slide the plate aside and fish the bobbin out. Put the bobbin up on the upper right hand side of the sewing machine and connect thread from the full spool of thread to the bobbin and then when you push the pedal down, (if you have arranged it right), your machine will automatically fill the bobbin with thread and automatically shut off when it is full. Then you have to leave a bit of thread hanging out when you put the full bobbin back down into its hiding space. Of course, you can always fill the bobbin by hand too. When you put it back in its housing, some thread has to be hanging out as the needle will drop down, grab it and the two threads (the top one from the needle, and the bottom one from the bobbin) work together.
Machines work differently but the is the main idea behind most of them. I hope that helps.
Feb 08, 2015 | Sewing Machines
Singer 7258 bobbin filling issues
If it is new, it is defective, return it for service or replacement.
Mar 23, 2014 | Singer 7462 Mechanical Sewing Machine
Please first up on needle bar (Pressre foot). Then take one small screw driver or big needle put on bobbin center before some 3 or 6 times wring some thread ,then put on the bobbin machine wheel side after machine start slow and correctly you fill the bobbin.
Dec 27, 2013 | Sewing Machines
Elna 6200 jammed on bobbin refill setting
Remove thread. Remove the needle plate. Turn hand wheel toward you. Rethread machine. Make sure presser foot in up position when you thread needle. Make sure needle all way up in shaft, flat side back and more rounded side facing you Turn hand wheel toward you again and observe the following: As needle comes down, make sure the needle's eye makes pass by the scarf of the needle. Hope this helps, and if not, try sewvacdoctor.com
Apr 03, 2012 | Sewing Machines
Thread in needle or bobbin keeps on breaking
The tread only breaks in the needle. what can i do . i don't get to sew anything . I tread the needle and get everything ready and start the machine and as quickly as that the tread is broken and the machine has not sewn at all.
Apr 07, 2009 | Brother LS-2125 Mechanical Sewing Machine
Feb 25, 2009 | Juki DDL-8300
Bobbin filling on Singer 626
The Singer 626 has a self-winding bobbin. You place the empty bobbin in the bobbin thingie (sorry for being so untechnical). On the left of the bobbin you will see a "lever" with a circular top on it (I think it is red-ish) Again, sorry for being so untechnical. Press the "lever" down. Thread your machine, thread the needle, wrap the excess thread from the needle around the knob that tightens the needle and holds it in place and press your foot down on the foot pedal. The bobbin will automatically wind as you hold the foot pedal down. Do not wind the thread onto the bobbin past the outer white line.
Aug 17, 2008 | Sewing Machines
Kenmore sewing machine older model 1345381
hi! there wind thread on bobbins winder 4 times by your hand rotate clockwise,insert in shaft bobiins winder on top of your machine near hand wheel push latch to engage loop thread on disc winder tension start your machine on pedal foot automatically winder disengage if already filled up of thead pull this winder and insert to bobbins casing insert thread to slot and pull out winder 6411c87.jpgshould rotate clockwise as shown.insert on shuttle hook casing and close cover needle plate.next thread your upper
97b52e8.jpgthreading tension as shown on red threading from spool pull threading and loop to dial tension threading and insert thread to lever needle and to needle hole tip. pull tread under the needle foot and feeder tooth.rotate hand wheel counter clockwise to hook up thread bobbibs and appear at top of needle plate,teo thread shoul appear,set dial tension to # 3 and stich to # 8 range to # 12 depend on fabric and layer of fabrics and set on straight stich sewing,let needle on upper position insert fabric for trial sewiing.put down foot needle lever. manually by hand rotate for assurance needle is free to sew if obtruction on loop bobbins thread occurs adjust all tension gradually then try again until free from sewing w/o problem star sewing.
Aug 08, 2008 | Kenmore Drop-In Bobbin 505S-21BH...
Sewing Machines Logo
23 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
