See question details above. symptoms are listed there.
There's a thermal fuse that can pop if it won't run or no lights,if you have power in the box where power connects to dishwasher most likely it will be the fuse,go here to see it,it's on the computer board
https://www.repairclinic.com/Shop-For-Parts/-x33333736333539/3376359-Parts
IT MAY BE THE SWITCH WHERE YOU SHUT THE DOOR CHECK TO SEE IF IT LOOKS OK OR BROKEN! ALSO YOU MIGHT TRY TAKING OFF THE CONTROL PANEL TO SEE IF THEIR IS ANY LOOSE CONNECTIONS YOU MIGHT TRY UNPLUGGING THEM AND BACK IN AGAIN. YOU MAY ALSO TRY A HARD RESET UNPLUG FOR 30 MIN.
SOURCE: Kenmore Ultra Wash Dishwasher - no lights, won't reset
check wire nuts that were used to install power cord/it is on the right hand side of toe kick if ok there is a fuse on the control that you can replace located top of door
