Question about Jenn-Air Ovens
Jenn-air oven not responding
The clock is on but none of the buttons on the touch pad work
    New Friend:
  • 13 Answers
Get out the owners manual and there are some symptoms solutions
If you can't find the answer there there is a customer service support line telephone number. You can give them the model number of the stove and he'll give you a method to find out what's wrong it may just be a fuse
Posted on Nov 26, 2014
Jenn air expressions double oven
F-7 error code means that the Function Key is stuck or shorted out. You will have to replace the touch pad or if the touch pad is part of the clock, you will have to replace the clock (ERC).
Aug 18, 2014 | Jenn-Air Ovens
Error code SAb bath on Jenn Air oven. Held clock button down for 5 seconds and key pad still will not work.
possible need new key pad.first check no loose connection from key pad to the control board,if not replace key pad
Nov 24, 2013 | Jenn-Air Ovens
F7 code flashes on jenn aire 27 inch wall oven
The F7 code indicates that the touch pad either has a "stuck" or shorted key. Depending on the oven model, you either need to replace the touch pad or the controller (clock) and the touch pad. (Some Jenn Air appliances sell the two as one unit.)
Please add a comment with your model number to get additional information on the availability and price for the parts. (Parts may be available from a number of suppliers, including jenn-air.partselect.com.)
I hope this helps.
Mar 01, 2012 | Jenn-Air 27 in. Electric Single Wall Oven...
JJW8230DDB Jenn Air double oven. Black. Digital display. The only buttons working on the display are the Cancel buttons. Display still shows time, but I can not set the time (the clock button does not work...
When buttons are not working most of the time it is due to a short in the touch pad or the electronic control in a unit you would have to call for service if you did not know how to use a multimeter to perform ohms and continuity testing and measureing of both pieces. Usually though due to the button not working most of the time it is the touch pad though. If you have any further questions message me back Thanks again
Rick
Oct 16, 2011 | Jenn-Air JJW8230D Electric Double Oven
The Jenn-Air Gas Range Electronic touch control 800. The key pad does not work. You can not set the clock or work the oven. Help.
My Jenn Air has the same problem with the computer touchpad. The only temperature I can get to work is from the left hand column, 411 degrees. I don't want to waste another dime on this oven. I've read so many complaints from other owners. No more Jenn Air products for me.
Nov 22, 2010 | Jenn-Air Ovens
What does F- mean on my jenn air expressions electric wall oven? If it means what I think, then this is the 4th failure in 10 years. This just can't be right!
Common fault codes:
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
Display Condition Remedy
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
May 22, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
The baking does not work
sounds like the touch pad or main control board could be bad...call for help on checking components....
May 12, 2010 | Jenn-Air JGW8130DD Gas Single Oven
How to fix F1 error code on jen aire oven
HI There
I have this code for you to read and this is helpful. Let me know how it goes.
F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information.Thank you for writing to fix ya.
Best Regards Richard
Jan 05, 2010 | Jenn-Air JGW8130A Electric Single Oven
Jenn aire
Maytag-Maycop-Magic Chef-Jennair-Admiral
Oven Fault Codes:
May 10, 2008 | Jenn-Air WW30430P Stainless Steel Electric...
Jenn-Air WW30430W double oven flashing F7 and beeping
It seems you have a stuck button. Here is a list of fault codes:
JENN AIR
Range/Stove/Oven Fault Codes
Failure
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad) F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) F2 Oven too hot Replace relay board (if present) or oven temperature sensor F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Check for proper voltage F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or attempt to un-stick button F8 Analog/Digital supervisory Replace clock assembly (also called the ERC) F9 Door latch supervisory Check door lock circuit or replace clock assembly (also called the ERC) F0 Function key stuck Replace touch pad or clock assembly (also called the ERC)
Dec 09, 2007 | Jenn-Air JJW8530C Expressions Collection...
Ovens Logo
95 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
