I have 2 lines like a shadow on my screne in the top midle
I have put a cold packet o bagon on the mark advise from u tube
  • 37 Answers
Normaly flat screens have 3 circut boards unlike the conventional TVs one of the three boards are display circut ..slowly it will give way and will need replacement, if your Tv is under warranty its nice, or else you will need to spend.
Posted on Nov 26, 2014
Two vertical light brownish shadows have begun to appear on my 40" bravia kdls40a12u TV - what is the possible cause of these ?
I came across your post and would like to help you with that! Do you have DISH service? If so, try unplugging the receiver for at least ten seconds and then plugging it back in. Let me know what happens so I can assist further. I hope that helps!
Dec 19, 2012 | Televison & Video
How do I add coolant to a 1993 vlx honda shadow
With the motorcycle engine cold , located the radiator cap on or just behind the radiator and fill the radiator to the top. Then, locate the over flow bottle often placed down by your feet and fill the bottle to the high mark. Ride the motorcycle and recheck the level of the over flow bottle after the cool down period. Top up as needed.
Apr 09, 2011 | 1993 Honda VT 600 C Shadow
I bought the Samsung 8 kg Top Loader (Model: WA80V3WIP) a few weeks ago. I only use cold water and bought the yellow packet of Sunlight washing powder, which specifically says on the packet that it works...
As with any top-loader, the soap drawer will deposit the entire soap load on one spot within the first few seconds of water fill. When the water starts running through the soap drawer, the brakes on the drum are released, so you can manually rotate the drum to disperse the soap over the load surface, thus eliminating the concentrated spots. Also, you may save the duvet, as the white marks are most probably dried soap powder which can be removed with a damp cloth wiped over the area.
Oct 19, 2010 | Samsung SW62ASP Top Load Washer
How do you check coolant in a 2003 750 Shadow Spirit?
With the engine cold , take off the radiator cap and if necessary top it off. Use only a non-silica antifreeze like Honda or GM Dexcool. Put the cap back on and top off the overflow bottle (to the high mark).
Oct 15, 2010 | 2003 Honda VT 1100 C Shadow Spirit
After changing oil the cap on oil tank keeps blowing off.
Sounds like you've overfilled the oil. The stick has two marks on it. The top mark is 'FULL HOT" and the lower mark is 'FULL COLD". If you changed the oil filter, you add three quarts of oil. If you did not change the filter, you only put 2.7 quarts in the tank. The next time the cap blows off, as long as the oil level is above the lower mark, do not add anymore oil and see what happens. As long as the oil level is between the marks, do not add oil. Sportsters are notorious for this. People check the oil before they go riding and "top it off". Bad move. As long as the oil is between the lines when cold, ride the bike to warm it up, and then maybe add a bit if it's low. Do not bring it up to the top line even if the engine is warm. About half way is good enough.
Good Luck
steve
Aug 22, 2010 | 2000 Harley Davidson FXST Softail Standard
Timing gear mark 94 dodge shadow
Look at this and see if this is how you did it. If that's not your engine you can enter your info to see it.
http://www.autozone.com/autozone/repairinfo/repairguide/repairGuideContent.jsp?pageId=0900c1528025169f
Aug 03, 2010 | 1994 Dodge Shadow
Model 70 clothes washer, cold water comes in extremely slowly, I need a diagram to show me where/how to clean the entry filter, please. I don't have a manuel for this old but very good machine. Thanks
Shut off cold water supply to machine.On the back of your machine where the cold water inlet line connects the machine. Remove the cold water hose (I recomend doing both hot and cold to ensure the the hot is clear while you are there). look inside the threaded hose connection on the machine water inlets on the back where you removed the hose(s). There are small screnes inside the fitting and can be removed with a small screwdriver. Simply rinse them out and reinstall them. Some hoses have a screne in the ends. I recomend removing your drain hose (the discharge) from the sewer and open the water fauscett and flush the homes lines and inlet hoses into the drain pipe (no mess or water on the floor). This also insures good water flow to your machine. reinstall hoses... Should fixya!
Aug 05, 2009 | Kenmore Washing Machines
ATT flashes on screne keys light then everything goes off
put someone else's simcard turn it on then off put your sim card in and turn it on that how i fixed mine
Mar 31, 2009 | Pantech Slate Cell Phone
Printing fade at the midle of the page
Build up on the printhead, printhead pressure, or worn platen roller...
Apr 26, 2007 | Zebra Stripe S600 Thermal Label Printer
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
Electro Med Services...
