Question about Brother MFC-8370DN Laser Multifunction Printer 40567
NO NETWORK SETTING SHOW IN LCD PANEL IN BROTHER 8370DN AFTER RESET THE PF KIT 1 MESSAGE.
Please help: I have followed the 8370DN RESET THE PF KIT 1 MESSAGE steps on 8370DN but after restart the printer there is no NETWORK setting show the LCD display and No LED blink in NIC port. I think, printer Network setting goes Disable please help
  • gurjit singh
    gurjit singh Nov 27, 2014
    Thank u for response: I tried the above steps but no LED found in the nic port. i would like to tell u , in the printer LCD display there is no option for NETWORK. after resset the pritner PF kit 1 . so, NIC not working. I think printer software is corrupted . please help
  • 28 Answers
Hi gurjit: try this..
Reconnect the LAN cable to the hub to verify
that the cable and network connections are good. If possible, try connecting the
machine to a different port on your hub using a different cable. If the connections
are good, the lower LED of the back panel of the machine will be green.
sends me the result.
Posted on Nov 26, 2014
Testimonial: "Thank you for kind reply: i tried the steps u guide but problem not solved.. actually there is no option in the printer LCD display for NETWORK SETTING : after resetting the printer PF KIT1 message then no NETWORK found in the printer MENU Panel while other option are there like : GENERAL, COPY, USER SETING ETC. EXCEPT NETWORK/SCANNER . I think after reset the PF kit 1 Printer software's corrupted. I tried to install printer with USB but Fail, so, please help."
How to reset pf kit mp of brother mfc-8460n?
Hello ,
First you have to enter in service mode , then to go to reset menu , and reset pf kit mp an then to live service mode
1. Service mode : menu*2864 , you have to make it fast until the lcd is on : maintenance mode
2. reset menu 88 , now you have to go to pf kit mp and reset
3. Live service menu with 99 or shut down the mfp and after 10 sec restart
Mar 03, 2016 | Brother MFC-8460N All-In-One Printer
How do I reset the fuser AND PF (PAPER FEEDER) part life
1) Press the 3 and 9 buttons at the same time in the ready status.
2) "Reset Menu" will appear on the LCD. Scroll to Fuser by pressing up arrow or down arrow button then press the OK button.
3) "1. Reset 2. Exit" appears on the LCD. Press the 1 button to reset the fuser counter. The display briefly shows "Accepted".
The machine returns to the ready status after a few seconds.
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Brother Printer Support
Feb 07, 2014 | Brother MFC-9120CN - 17 PPM Multifunction...
HL-5250 report shows fuser and laser life at 0% and PF kit 1 at 12%
The fuser is a separate component to the drum and toner in this printer. It has a much longer life than them but will run out eventually. Sadly a fuser unit is not a commercially available consumable for this printer either. I would recommend contatcing a printer technicain or Brother directly for a quote on replacing this part.
Apr 12, 2013 | Brother HL 5250DN Laser Printer
OK, we've got a second-hand brother 6050dn for our computer lab of about 35 computers. I've recently replaced the PF KIT For the MP drawer, but had trouble resetting it. Finally figured it out...
Replace the parts! If it is used you have no idea of how old the parts in it are even if they look good. The counters that turn these messages count sheets of paper not time and the parts may have moisture damage from sitting up.
May 02, 2017 | Brother HL-6050DN Laser Printer
I need to replace "PF
Ah the Paper Feed Kit 1 on this unit is pretty easy,
If you remove the paper tray and put the printer on it's back you should see the rollers you're going to replace.. unfortunately the service manual doesn't show this procedure so I can't provide a picture.
If memory serves correctly there should be a long light-blue plastic piece that holds the PF Kit roller assembly in place. If you bend this towards the back of the machine the PF Kit should swing down and you just slide it out, replacement is the reverse of this.
Once you're done you'll have to reset the PF Kit counter by:
Press GO and + together,
you should see RESET PARTS LIFE on the LCD
You can then use the + / - to pick the PF Kit and press the SET key to reset the counter.
If you still have problems let me know via this question and I'll try to help further.
Jun 10, 2011 | Brother HL 5250DN Laser Printer
How to replace the PF roller on a brother DCP 8065
1.Pull out the paper tray
2.turn the machine upside down
3.push the blue lift arm and pull out the pin of the PF roller
4.then slide the PF roller to the left and pull it out
5.replace it with new one put the pin of the new roller into the hole of the blue lift arm.
6. place the machine on its base.
P.S you need reset pf roller counter after replacement
press "MENU - START - 088"
LCD shows "PARTS REPLACEMENT"
go down with arrow till "reset PF kit T1?" PRESS "SET" key
all done.
Jan 31, 2010 | Brother DCP-8065DN Laser Printer
Brother HL-1670n failing to feed paper.
I am facing problem for my "Brother HL- 1670N" printer with error E52.
Please help me out!
rj_rrohanjag@yahoo.co.in
Nov 04, 2009 | Brother HL 1670N Laser Printer
Mfc-9420cn pf-kit2 reset, how to reset the counter after installing new kit
Press Menu/Set, 7, 4. Press down arrow to select PF Kit 2 and press Menu/Set. The confirmation message appears on display PF Kit 2. Press 1 to reset or 2 to cancel. PRESS 1.
Nov 03, 2009 | Office Equipment & Supplies
Resetting "Replace PF Kit 1" message
Same with me on my MFC 8870DW. The procedure worked perfectly:
1) Turn off printer
2) Press and hold menu button and turn on. Keep holding button until you see maintenance on display.
3) Press 88. This brings up parts replacement menu.
4) Press Up arrow until you see the part you replaced (laser, fuser, pf kit1, pf kit mp).
5) Press the OK button.
6) Power off and restart printer.
But how do I know whether or not I really NEED to replace a PF Kit1? I guess I'll find out if it recurs soon.
Joe
Jun 18, 2008 | Brother MFC-8460N Laser Printer
Brother MF 9420CN is asking for troubleshooting and routine maintenance 'unable to print'
Via the control panel (This is a Factory Reset)
  1. Make sure the machine is not operating, then disconnect all the cables from the machine (except power cable).
  2. Press the Menu or Menu/Set key on the control panel.
  3. Press up or down navigation key to select LAN and press Set or Menu/Set.
  4. Press up or down navigation key to select Factory Reset and press Set or Menu/Set.
  5. Press 1 to select "Reset".
  6. Press 1 to select "Yes".
  7. The machine will re-start, re-connect cables once this is complete.
Jan 21, 2008 | Brother MFC-9420CN All-In-One Laser...
Brother MFC-8370DN Laser Multifunction Printer 40567 Logo
126 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
