Question about Baumatic Dishwashers
I have a Baumatic fcc 2002, I am unsure what charcoal filters to use. can u help
  • 937 Answers
I have a baumatic 1206 which will not drain. All suggestions are to clean the filter, but I cannot find a filter. There is no detachable panel at the front bottom of my machine
IS THERE A DETACHABLE PANEL AT TOP? IS THERE A CREVICE NEAT THE TOP? IF NOT U MAY HAVE TO REMOVE THE WHOLE CABINET? IS IT TOP LOAD OR FRONT LOAD? HERE ARE SOME PICS THAT MAY HELP
May 25, 2015 | Baumatic Washing Machines
2002 pontiac grandam fuel filter where is it located
look in between the fuel tank and the rear axle just above the charcoal canister. The charcoal canister can be moved out of the way by removing the bolt with a 10mm socket that holds it in place on the drivers side of the canister.
Sep 28, 2011 | 2002 Pontiac Grand Am
My 2002 Hyundai Santa FE 2.7 engine dies every time I gas up. It runs fine the rest of the time. So far I have replaced the fuel pump and vent valve. It still stalls. What could the problem be>
The evaporative emissions system consists of 5 major components
1. CCV - Canister Close Valve
2. Charcoal Canister & filter
3. Purge Contro Solenoid Valve (PCSV)
4. Differential Pressure Sensor (DPS - Fuel Tank Pressure Sensor)
5. Fuel Cap
Based on my experience, you have a PCSV which is sticking OPEN and constantly applying a vacuum to the charcoal canister. When you fill up, the fuel vapors which were absorbed by the charcoal are being constantly/continually sucked into the engine intake manifold causing an excessive 'RICH' mixture of fuel-to-air.
Sep 08, 2011 | 2002 Hyundai Santa Fe
Have a baumatic extractor fan and am unsure how to clean filters. There are no sponge filters inside only steel fittings and mesh. Can anyone help me?
The steel mesh panels are the filters, can be hard to clean if not done regulary. You can put them in the top rack of your dishwasher but you shouldn`t use detergent as it can change the colour of them. The other option is just to wash them in dishwash detergent in the sink, can be a bit awkward and if not done regulary, a bit hard to get completely clean. I tend to soak them for a while, wash them and then run really hot water through them. Hope this helps.
Jan 08, 2011 | Baumatic F60 Stainless Steel Kitchen Hood
F02 Baumatic error not cleared Even when filter cleaned...?
Perhaps you need to check the outlet hose from the pump for a blockage, and of course, make sure the pump itself is working.
Jan 17, 2010 | Baumatic BTWM4 Front Load Washer
Where is the charcoal filter?
There is no charcoal filter unless you replaced the standard filter with a carcoal filter. Also, it may have m=been changed to a charcoal filter if the unit was alterd during installation as a re-circulating vent, not vented to the outside via the roof or wall.
The filter (Charcoal or not) is on the bottom of the unit. Put your head under the microwave and look up, there it is.
Apr 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Where do I put the charcoal filter?
It would fit over / into where the other filter goes the charcoal filter is to help eliminate more smoke and grease
Feb 10, 2009 | Baumatic F60 Stainless Steel Kitchen Hood
No manual
The light bulb is the oven light.
The snowflake with 3 raindrops is Defrost Mode (fan runs with no heat to reduce defrost time)
The 2 lines up top & down bottom is Traditional Cooking (heat from top & bottom elements)
The big circle with a fan is the Fan forced Oven
The small line at top only is the Grill Mode
The larger line at top only is the Double Grill Mode
The line up top with the fan underneath is Double Grill with Fan mode
The line on the bottom with fan on top uses the lower element with the fan for delicate dishes
The manual can be found on the Baumatic website - www.baumatic.com.au - select your product which takes you into another page & you will see on the left hand side a link to "View User Manual"
Nov 11, 2008 | Baumatic B187 Stainless Steel Electric...
Rangehood malfunction
My Baumatic Rangehood model BAISL92.2 had the letter A flashing. I was advised by a repairman that it indicated the filters needed to be cleaned with warm soapy water. Apparently in my particular model there is a built in 30 hour timer for when the filters need to be cleaned. To remove the flashing letter A, I was advised to clean the filters, turn off the rangehood and while it was off, press the (-) (minus) button and hold for 5 seconds. It beeped and the flashing letter A was removed. This worked for my particular model - I couldn't guarantee it would be the solution for your model. I hope this is some help.
Jul 22, 2008 | Baumatic Upright Freezer BV12A
How to clean the air filter of my goldstar microwave model # MV1526B/01
That sounds like the charcoal filter. It cannot be cleaned, and must be replaced. From the owner's manual:
CHARCOAL FILTER REPLACEMENT
If your oven is vented inside, the charcoal filter should
be replaced every 6 to 12 months, and more often if
necessary. The charcoal filter cannot be cleaned.
To order a new charcoal filter, contact the Service
Center.
1. Remove the two vent grille mounting screws.
(2 middle screws)
2. Tip the grille forward, then lift it out
To get a new filter, you can try local appliance parts stores or see customer service or find servicers here: http://us.lgservice.com
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Apr 13, 2008 | Goldstar MV-1526 Microwave Oven
Dishwashers Logo
183 people viewed this question
Top Baumatic Dishwashers Experts
Greg Cann
Greg Cann
Kolbrun...
Are you a Baumatic Dishwasher Expert? Answer questions, earn points and help others
