Question about Shark Vacuums
Shark navigator making strange noise. Still have suction, doesn't make noise when beater bar not moving. What could be the problem?
Can not remove plate to get to beater bar
    Master:
  • Shark Master
  • 789 Answers
HI, it's Jim from Crucial Vacuum!
If your Shark Navigator vacuum is only making a strange noise when the brush roll is turning then the two things to consider and examine would be the brush roll itself as well as the belt.
First off lets look at the brush roll itself. Right off the bat is there any noticeable debris caught in it? You're mainly looking for long carpet fibers, or even strands of hair? If so try using a scissor to cut the blockage away. Then, manually rotate the brush roll to uncover further clogs. When examining your brush roll take note of the condition of the bristles. Are they loose? If so this would be a good time to change your brush roll entirely. There should be two screws holding the plate onto your Shark Navigator. Use a screw driver to remove these screws to gain access to the brush roll and belt.
The second part to check would be your Shark Navigator's belt. With use the belt will stretch out, lessening the tension on the brush roll. Lesser tension diminishes the brush roller's turn rate and speed. So if your belt feels loose as well replace that. A general rule would be that you're going to want to replace your belt about every 6 months. And if your belt is really loose this could be causing a noise when your brush roll is active.
You can purchase your replacement parts for your Shark Navigator direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=Shark+Navigator&limit=all
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
Posted on Nov 26, 2014
    Top Expert:
  • Shark Master
  • 3,698 Answers
Something is inside of the beater bar area.
SOURCE: beater bar on Dyson upright won't turn when handle is lowered
I have finally fixed my sister's dyson dc 15 beater bar problem. It was just 2 tiny broken wires connect to circuit board lead to the beater bar. The wires broke where they go through the black rubber gommet. You need a torx screwdriver tx 15 to remove 2 plastic covers to access the wires. When looking at the front of the vacuum, the gray covers located on the right side of the vacuum. 1 big cover with a black rubber gasket and other small gray cover is on the rotating ball area.
This my new year resolution is to warn people not to buy Dyson vacuum cleaner ( Junk) design to break down! Shame on you Dyson!!!! Save your money find good old vacuum cleaner with metal parts.
OLD IS IN NEW IS JUNK!
Happy New Year!
Posted on Jan 01, 2009
SOURCE: The beater bar makes a horrible clunking noise when I turn it on
I just came from the repair shop. There is a recurring problem with a bearing coming out. Repair guy turned it on & said that loud noise is a symptom of that exact problem. This is a warranty item, as is the belt & on/off switch. Dyson comes with a 5 year warranty, so call their 800 number to get the name & address of an authorized repair shop.
Posted on Mar 28, 2009
SOURCE: 2 year old machine...new noise in beater bar area
I have a dyson 17 animal and have a loud noise comming from the beater bar area.Also I don't think the hight adjuster is working properly.
Posted on Jun 02, 2009
SOURCE: dyson DC 14 lost suction to beater bar/ suction to hose/stick
My Dyson DC14 had no suction...see if this works...turn the Dyson upside down...there is a length of hose that connects the bottom of the vacuum to the top, careful remove one end of the hose and check for debris...mine was clogged. Removed the clog and voila...it works. Thanks for the above info on checking the hose for cracks.
Posted on Aug 11, 2009
Vac Belts
  • 701 Answers
SOURCE: The beater bar on my Dyson won't turn. The vacuum
The belt doesn't have to be broken to make the vacuum not work correctly. If the belt is stretched the vacuum won't operate the way it is supposed to. You can get replacement Dyson Belts here:
Dyson Replacement Belts
Posted on Dec 06, 2009
Y Shark "Professional" model 540 26 is making a terribly loud noise and not picking up dirt. t also gets HOT
Check( 'beater bar',suction tube to canister) for accumulation of hair,carpet fiber,pet hair,etc....cut hair,etc,with scissors,clean...might also be hair stuck in belt that drives beater bar
May 08, 2017 | Shark Vacuums
SHARK NV90 VACUUM BEATER BAR DOES NOT ROTATE - WHAT IS MY PROBLEM?
Most beaters are driven by a rubber belt driven off a shaft from the motor. Check this is in place, and wrapped around both the shaft and the beater bar (they can break). If this is OK, try to move the bar by hand- it may be jammed by fibres, hair, or other material that has wrapped around the bar. If this is the case, cut along the fibres and remove.
Oct 15, 2016 | Shark Vacuums
I need a DIY solution because my shark navigator lift away beater bar attachment stops working intermittently
If you've gotten 4 years out of a Shark you've already beat the system. Give yourself a pat on the back, throw it in the nearest dumpster, then go to your local vac shop and purchase a quality USA made vacuum cleaner that is repairable and will likely last 20-30 years. Chinese vacs are designed to last one year and parts are not made for Sharks.
Jan 07, 2015 | Shark Navigator Lift-Away Upright Vacuum
Beater stopped. cant get base plate off to get to belt. please advise.
Sharks are not made to be repaired. They are built to throw away. No parts are made for them for this reason. Save yourself some grief and don't buy another one.
Oct 01, 2014 | Euro-Pro NV22 Shark Navigator Bagless...
Shark navigator manuals
GOOGLE...Shark Navigator manuals....you will find what
you are looking for.
Regards,
Dennis
Sep 07, 2014 | Vacuums
Chess piece lost in shark navigator rotator
You must extract the chess piece or else it could move within the unit and cause further damage. If you cannot open the shark and get to the intake section, then have a service do it for you.
Feb 26, 2014 | Shark Helmet NV22L Shark Navigator Upright...
Beater bar not working - no variable suction
Take it to your local vac shop for repair. Depending on what model you have, it may have a bad switch or you brushroll ends could have failed. Both are common issues.
Aug 08, 2017 | Dyson Vacuums
The beater brush doesnt work on the carpet and makes a loud squeeking noise.It looks like the brush sticks out past the base and gets stuck on the carpet . Works good on the bare floor.
It seems that your drive belt for the beater brush is stretched. This is a common problem -- if you flip the vacuum over so you are looking at the bottom, you should see several screws holding a faceplate in place. Unscrew these, and you should be able to get access to the beater brush and belt. Pull on the belt a little -- if it has a lot of give, or seems stretched or cracked, replace the belt and your vacuum should be fine. If it is not stretched or cracked, move the belt and look between the belt and where it holds onto the brush (there should be a little groove that the belt is sitting it). If there is a lot of debris or hair (I have long hair and this happens to me quite often) between the belt and the brush bar, clean it out, and you should be good. The squeaking noise leads me to believe that the belt is stretched and could be replaced.
May 26, 2011 | Shark Navigator Bagless Upright Vacuum
THE ROLLER ON MY SHARK NAVIGATOR WILL NOT STAY ON, I CLEANED ALL THE HAIR FROM THE ROLLER AND IT STILL WONT STAY ON. IS THERE A BELT I NEED TO CHECK
We have only had our Navigator for 6 months and the bar won't turn. We took the whole beater bar head apart and it was a wiring problem in the beater bar motor.
What a piece of junk this is, very poorly made and has many design flaws.
Looking for something now to take it's place!
May 09, 2011 | Euro-Pro NV22 Shark Navigator Bagless...
Vacuums Logo
588 people viewed this question
Top Shark Vacuums Experts
Thomas Perkins
Thomas Perkins
Ruth summersides
Are you a Shark Vacuum Expert? Answer questions, earn points and help others
