Question about Dell Computers & Internet
Is the AC Power adapter be the cause of this Problem?
Hi Good Day I have posted this message reg. my Precision M6500 it's a core i7 720QM with nvidia quadro 2800, bought it again as a used unit, runs great but there's slight issue with the unit, It Runs ok when on Battery, but as i soon as i plugged in the Power adaptor after a few seconds of opening an apps (any app. like ie, google, ms office) the display goes black, then using a flash light i tried to look on the lcd panel, no images aside from no backlight while the unit is still on , hdd, power indicator, fans i can still even turn on and off the keyboard backlight, just the screen blacks out without image, tried to pull the ac power to see if the screen goes back but no luck, i have to force shutdown the unit, power on the unit again with ac plugged in it fully boots, but again opening any apps or connecting via wifi same thing happens, but if on battery everything works fine, I'm using a dell power adapter it's a 130watt 6.7amp 19.5 volts. i tried to enable via bios power supply scan, and it turns up upon Boot "WARNING: 130WATTS ADAPTER DETECTED, U MUST USE A 210W OR HIGHER ADAPTER" THE PERFORMANCE WILL ADJUST TO MATCH THE POWER OF YOUR ADAPTER" is this causing the screen blackout using an under rated power adapter, i tried using a dell alienware 14x power rated 150W 7 amp (20w higher though) but it just last a bit longer "a few second " versus the 130 watt, then same thing happen. Is this kind of behavior common on a precision M6500, should it act this way, Thanks
    Scholar:
    New Friend:
  • 142 Answers
You seem to already have the answer: Your power supply is underpowered for operating your laptop. It is probably supplying enough power to charge the unit, when it is off, but the power draw is so great that the unit is selectively shutting off various elements of itself to protect itself from damage.
You can use the power supply to (slowly) recharge the battery, but you shouldn't be using it to power the laptop. Do yourself a favour and buy the recommended power pack.
Posted on Nov 26, 2014
Testimonial: "Hi thanks for the helpful advice, I,m still using the lappy, but i have to charge that to full when the unit is "OFF" or still ok if it's powered "ON" but in idle (doing nothing), Thanks for the heads up will be buying a new power brick soon. Again Many Thanks Sir Michael"
  • walter255 Nov 26, 2014
    Hi forgot to mention, yes your right, when charging the laptop powered "ON" aside from doing nothing, the battery percentage increase is so slow that it takes at least 5 to 10 mins. to increase by 1% only. Thanks
  • 162 Answers
It sounds like the back light power inverter is triggering a safety feature, perhaps due to a fault or bad charging system. I'd first contact Dell to make sure you're using the right power adapter for your unit. Enabling a bios pdu scan that's resulting in a message such as the one you described WARNING: 130WATTS ADAPTER DETECTED, U MUST USE A 210W OR HIGHER ADAPTER" THE PERFORMANCE WILL ADJUST TO MATCH THE POWER OF YOUR ADAPTER" is a hint to a larger problem so, if that's all correct take that to an authorized dealer and swallow the cost. Remember that's a workstation so lifecycle services may be having issues with the brick.
Testimonial: "Hi thanks for the helpful advice, I,m still using the lappy, but i have to charge that to full when the unit is "OFF" or still ok if it's powered "ON" but in idle (doing nothing), So is this mean that I have to buy a new power adapter the compatible one's Thanks Sir Tony"
    Thanks for the Info, I'm still using the 130 watts power brick (the original one is 210watts), works great on battery use, I have to charge it when the unit is "OFF", charging the Unit powered "ON" is still ok but in idle, "no web browsing or opening an app"
    Hi forgot to mention, when charging using the 130 watts power brick the laptop powered "ON" aside from doing nothing, the battery percentage increase is so slow that it takes at least 5 to 10 mins. to increase by 1% only. Thanks
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 9 Answers
The problem is the gpu not power supply..i have the same problem with 250 w power sypply..i have replaced the fx3800 with firepro and now it is ok..the gpu is around 130$..or if you dont whant to spend money try to downclock the gpu and it will work..you need to use NVIDIA power mizer manager software..and select medium range settings that will take down the gpu to 300 mhz core clock and reboot the pc..and you will never have black screen again
Posted on Mar 24, 2015
Testimonial: "thanks, I already replaced my adapter to it's original OEM 240watts and re install the O.S., it's already okay upon testing and does not have any black screen as for the moment, Thanks for the help and will reconsider your advise if it happens again thanks again Sorry very late reply though :)"
I get a message Ac OFF
Hi, Your assumption is correct. The phone is not sensing any external AC power. If you are sure that the AC cord/adapter is plug in to the mains, then it is either: 1. the walloutlet or where the ACplug/adapters is connected does not have any power; or 2. The adapter itself is defective. Hope this b e of some help/idea. Pls post back how things turned up or should you need further information. Good luck and kind regards.
Sep 26, 2007 | GE RCA 4-Line Speakerphone
How to disassemble
find door on outside-- held by screws or spring clips remove and you see inside- look carefully at parts to remove and do it-----no power and no carpet-- use some hard surface
Aug 13, 2014 | Dell Mobile Precision M6500 Computer...
Dell precision m4300 screen black
Hi
you have to be sure if the laptop is running the alert LEDs, the sound of the fan in fucionamento, use an external monitor to be certain. and finally replace the LCD and its. cable
Apr 06, 2014 | Dell Precision M4300 Laptop AC Power...
Remove CMOS battery
Dell heroically provides extensive service manuals for it's loyal owners, whom Dell must consider as responsible and bright :- )
The procedure is described here under "coin-cell battery"
http://downloads.dell.com/manuals/all-products/esuprt_laptop/esuprt_precision_mobile/precision-m6500_service%20manual_en-us.pdf
I salute Dell Technologies !
In my country at least , a laptop is not a " prescribed device" and so is legal for any owner to effect simple maintenance , like changing the cmos battery or ram memory upgrades, as per the provided instructions .
The ac-adapter is a " prescribed device " and so ******* for the unqualified to execute maintenance or repairs
Mar 12, 2014 | Dell Precision M6500 Notebook Pc 544101103
My hp pavilion dv6-2117ax laptop won't power up (no power light on where adaptor meets laptop). Replaced power adaptor / charger and laptop powered up and operated for a day and then next day woul
The laptop probably isn't charging. Could be a bad d/c connector on the laptop or the battery is bad. Remove the battery and plug in the a/c adapter and see if it powers on. Wiggle the a/c plug in gently while pressing the power button on the laptop. It powers on and off briefly then I'd say it's the d/c jack on the laptop, bad sodder joint.
Dec 04, 2012 | Computers & Internet
How do i reset the jumper on the motherboard
First you will need a CD to boot from, like your OS ( operating system ). To boot from that CD, keep tapping the <F12> key until it displays a boot selection menu. There you can create or delete partitions that hold your OS.
Sep 26, 2012 | Dell Mobile Precision M6500 Computer...
Dell precision m50 will not boot power light just flashes when I push the power on button. I have reseated all of the connection in the laptop. I have tried different batteries and different power...
remove external peripherals. remove battery. use ac adapter alone. check if ac adapter has sufficient power or check if ac adapter led is solid green or blue. if not then ac adapter might not giving laptop enough power to power up.
if ac adapter led stays on but some problem check the ac adapter - laptop pin socket if loose or damage. if not then replace mobo.
Dec 07, 2009 | Dell Precision M50 Notebook
My dell precision m65 battery does not get charged at all... Even though i charge it, it shows only 12% of charge n says low battery... Kindly advice me what could be done...
If your battery is not charging there could be two reasons for the same . First the battery has exceeded its lifetime and requires a change or is faulty
Second your ac adapter is not giving enough charge to charge the battery.
Open the battery health meter , by pressing the Fn+ F3 key on the keyboard . check if battery reports any error message.
Shutdown the computer and disonnect the Ac adapter and the battery and press the power button for 10 seconds
Reconnect both the Ac adapter and the battery
power on the system and tap on the f2 key slowly on the left side of the screen , look for the option that says battery info.
Check what is the status of the Ac adapter and is the battery showing charging.
if the Ac adpater shows as none, then adapter needs a replacement otherwise the battery.
Thanks for using fixya
proton
Aug 15, 2009 | Dell Precision M65 Notebook
Computers & Internet Logo
88 people viewed this question
Alun Cox
