Question about HP Designjet Z6100 InkJet Printer
HP DesignJet Z6100 Series - Error "Printhead Replacement Incomplete Restart It"
I have HP Z6100. Today one of them gets an error message to reseat the LcLm printhead (#4). So I reseat it and it still tells me that I need to reseat the faulty printhead. So I install a brand new printhead, and it still says to reseat. I swapped the the two LcLm printheads (#3 & #4) and still it says to reseat #4. I figured the contacts might be dirty, so I cleaned those. Spotless. Still it tells me to reseat. What's going on here?
  • 1,243 Answers
Time for a new printer. These things are just not worth fixing any more, even many of the large office units are made to break and be scrapped.
Posted on Nov 26, 2014
  • Anonymous Oct 14, 2015
    What a worthless answer.
  • Jeff May
    Jeff May Oct 19, 2015
    Have you ever tried to fix an embedded microcontroller? a sketchy ribbon cable? These parts are hard to find when the units are near new. After that, no longer available. Best bet is looking through the graveyard if you can find one.
Error 86:01
did you perform a scan axis calibration after changing all these parts? If not then you should do that before doing anything else.
Sep 01, 2014 | HP Designjet Z6100 InkJet Printer
HP DesignJet Z6100 Error 43:10
Hello. The error message indicates a vacuum fan failure. The problem can be solved by replacing the Vacuum Fan Assembly.
Q6651 60286 HP Designjet Z6100 Vacuum Fan Assembly
The service manual with instructions can be downloaded from: http://www.lpscomputer.com/collections/designjet-z6100-parts
Jul 22, 2014 | HP Designjet Z6100 InkJet Printer
Z6100 banding verticle in black
When you banding vertical do you mean Across paper feed direction OR With paper feed direction?
If its across the feed direction the chances are thje issue remains with the individual printhead, Print out a quality maintenance print to find which Printhead is not working as well as wanted, then replace ( or clean using the plotters control panel under image maintenance.
Errors along the feed direction can be down to Software/ Main Pca /
Mar 11, 2014 | HP DesignJet Z6100 Wide Format InkJet...
Code error 24:10
ISSUE: The printer front panel displays System Error 24:10. The printer may not print, and in rare cases, ink may leak from the printer. SOLUTION: HP is investigating a recent issue with some HP 91 Ink Cartridges in HP Designjet Z6100 series printers. A combination of factors related to handling during shipping have resulted in a very small incidence of HP 91 Ink Cartridges with the System Error 24:10 error. When the problem occurs, the printer front panel displays System Error 24:10 and the printer may not print.
HP regrets any inconvenience this may cause. Please contact HP Customer Support for assistance. Click here for information on how to contact HP support at http://welcome.hp.com/country/us/en/wwcontact_us.html.
Feb 15, 2014 | HP Designjet Z6100 InkJet Printer
Hp z6100 plotter error code 46:03
System Error:
46:03
Problem Description:
Primer servo shutdown.
Corrective Action:
Try the following:
1. Switch the Power OFF from the back of the Printer and disconnect the Power cord. Reconnect the power cord and power On the Printer.
2. Replace the Primer Assembly .
3. Replace the PrintMech PCA .
4. Replace the Interconnect PCA .
Feb 06, 2013 | HP Designjet Z6100 InkJet Printer
I consistently get a "Paper Skewed" message on
It's just a practice with every plotter that i've worked on.The guide lines are absolutely inacurate.For every individial z6100 may be different but in mine the the right side of the paper must be about 3mm inside from the tip of the guide arrows(the paper must cover 3mm of the arrows).
Jul 12, 2011 | HP Designjet Z6100 InkJet Printer
Hp designjet z6100 error code 21 : 13
Service Station error. Switch the power OFF from the back of the Printer and disconnect the power cord. Check the Primer Tubes. Reconnect the power cord and power On the Printer. Make sure that the Service Station path is clear. Remove any visible obstacles (e.g. screws, plastic parts, etc...) restricting the movement of the Service Station. If the System Error continues, replace the Service Station. If the System Error continues, replace the PrintMech PCA
Jul 27, 2010 | HP DesignJet Z2100 InkJet Photo Printer
Error Code 08:11 HP z6100
The 08 portion of the code indicates FRONT PANEL. the :11 is an action code requesting RESEAT, CLEAN meaning you should reseat the connectors at the display and on the other end at the electronics. Cover removal is explained in the service manual which can be downloaded here: www.lpscomputer.com/ec/manuals.htm
Oct 28, 2009 | HP Hewlett Packard Designjet Z6100 InkJet...
HP Z6100 error code 01.2:10
01.2:10
Problem
Description:
ISS PCA problem.
Corrective Action: Try the following:
�� Switch the Power OFF from the back of the Printer and disconnect the
�� If the System Error continues, replace the Ink Supply Tubes and Trailing Cable.
Sep 25, 2009 | HP Designjet Z6100 InkJet Printer
HP Designjet Z6100 InkJet Printer Logo
334 people viewed this question
Seeker5211
Seeker5211
