Question about KitchenAid Refrigerators
How do i make the kitchenaid refrigerator door beep louder if left open
  • 937 Answers
Here is a link to the user instructions:
http://www.kitchenaid.com/digitalassets/KFCO22EVBL/Use%20and%20Care_EN.pdf
There is no indication of volume adjustment for the alarm - simply on or off.
Posted on Nov 26, 2014
SOURCE: Roaring sound
I have had the same issues. I have owned my LFX25960 for 18 months. All the cooling, noise, and condensation problems are related to 2 fans. One for the freezer/refrigerator compartments and One for the Ice Maker. The fans, apparently, are not sufficient to move enough air through the coils located behind a plastic panel in the freezer compartment. The part numbers for my fans are 1. Ice Maker 4681JB1029E and Refrig/Freezer 4681JK1004E. It is not impossible, but fairly difficult to replace them yourself. You have to remove the large slide out freezer drawer and glides. Then work the back freezer panel loose from the bottom. Be careful not to break it. It is plastic.
Routine maintenance: Pull the refrig out from the wall and blow-out the coils and fan located on the lower right rear. You might find it easier to do this by removing the cover on the lower, back of the refrig.
Posted on Apr 30, 2009
  • 4793 Answers
SOURCE: KitchenAid Superba refrigerator door not closing
have you adjusted the levelers underneath to make sure f/f is square.use a level on top.
Posted on Mar 06, 2010
Testimonial: "Got it done finally. It was an easy fix and I was planning to hire someone to do it. Thanks."
Macmarkus
  • 2605 Answers
SOURCE: continual beeping
Hi, welcome to Fixya A very common problem with those fridges actually. Check to make sure the door sensor`s are secure and contacting each other when the door is closed. You can do this by accessing one or both sides of the door sensors at the hinge assembly cover at the cabinet top. There should be sensor`s on either side which sense when the door is closed by "making" with magnets on the doors. They sometimes become loose from where they are held in place and therefore do not indicate the door is actually closed. That is the most likely cause. If this does indeed help you solve your issue please take a moment and rate it accordingly. If it doesn't solve the problem let me know and I'll try and assist you further. Thanks for visiting "fixya" today. good luck. macmarkus :)
Posted on May 16, 2010
  • 842 Answers
SOURCE: i have a kitchenaid refrigerator KSRP25FNSS the
HI,
I am assuming that the problem is with dispensing ice only, is the water portion of the dispenser still working? Are the switches in the dispenser making contact, I have seen in some model as yours that the dispenser switch bracket broken and would not make contact with the arms when attempting to dispense. Last question, is the bar to the motor you replaced connected properly? I have seen the service motor have a deep well in it and not make contact with the bin as it rotates.
I hope this helps.
Posted on Aug 03, 2011
  • 884 Answers
SOURCE: whirlpool refrigerator door reversal
Check with supplier first but almost all fridge bodies are made for reversal
Posted on Apr 22, 2012
Kitchenaid artchetice ss side by side built in beeping three times every two minutes, We have been having problems with ice maker but for much longer than the beeping has been happening. Also door open...
the beeping may be the tempt is to warm . caused by door not closing properly . ice mker / if fisrt to quit when temprs art too high.. so ck the coils under neath the frig and the fan . / clean the coils and make sure the fan is going . and ck the fan in the freezer also both must be going to maintain tempts . thes should help problem .. ****
Jan 03, 2010 | KitchenAid KSCS25FKSS Side by Side...
Beeping or Chirping
probalby not relates, but the beeping is ususally accompanied by an indicator light as to why its blinking, perhaps the door open alarm???
Mar 28, 2009 | KitchenAid KSCS25FKSS Side by Side...
Power and no lites in refrig/freezer; beeping
depending on age of unit, the problem may lie in the light bulb,well the door closing anyway, the newer unit s actuall will shut down all interior lights, in the evnet that teh door is left open for more then 2-3 min, so its possible that a light switch is not being activated so the uit thinks the door is open and has shut down the rest of lights, cooling however does continue normally.
Mar 08, 2009 | KitchenAid Refrigerators
The fridge beeps constantly and then the light goes out. any suggestions?
the light goes out??? are we talking about the interior lights, or dispensor lights???, and whats bl;inking (if any while "beeping") sounds as if perhaps a door/light switch has failed, and in which case the intereior light would stay on for more then 2 min(beeping "open door alarm", and after 2 min for safety reasons the lights turn off as not to "cook the food"
Jan 14, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Keeps making beping sounds
Not shuting off..it is off if the dispaly and lights are not illuminated
Dec 23, 2008 | KitchenAid KSRS25IL Side by Side...
Kitchen aid open door sensor alarm keeps going off door is closed
Open door and turn power off then on twice. Then press the Overtemp reset.
Dec 21, 2008 | KitchenAid Architect KBFA20ERSS Stainless...
Kitchenaid KSCS25INSS
im not sure about the alarm but im going to assume its a door ajar alarm tilt the fridge back using the adjusters on the front wheels till you can open the doors about 1/4 let them go and it will close its self fridges are air tight and some times when you shut one door the air it pushes will slightly open the other the installation inst say level the unit but its better to have them leaned back the lights probably turn of auto if a door is ajar give that a try and let me know please
Feb 13, 2008 | KitchenAid Superba Architect KSCS25INSS...
No water dispensing to the icemaker. Water does dispense through the door dispenser. KitchenAid ksbs25fkbl00
Unplug your refrigerator and leave the freezer door open for 2 hours (The food in the freezer will only partially thaw).
The line supplying the water to the ice maker has frozen...this will un-thaw it.
Oct 18, 2007 | KitchenAid Superba 21.6 cu. ft. Top...
Refrigerators Logo
280 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
