Question about Easy Nichia 5MM LED 18 LM Adjustment Mini LED Flashlight Torch ARCHON B10
Or you may advice me which end shall I try to unscrew, the front or the end side ?
  • 37 Answers
At the top there are two layers, one for the lens and one for the battery instalation, if this cannot be done try the rear endturn counter-clockwise.
Posted on Nov 26, 2014
Mate The End Part:)
Casiotone ct 660
Sounds like it might be mono output. You can get a mono to stereo adapter, but of course you will hear the same in each headphone.
Aug 14, 2014 | Music
Filter on washing machine
down the bottom on the right hand side is a flap,,, open it down and you will be looking at the front end of the pump,, unscrew the plastic screw type and pull it out.. if you cant pull it out after you have unscrewed it ypou will need to tilt the machine on its back and undo the one screw at the bottom near the pump, slide the whole plimpth right and it will clip off,, now undo the 3 screws around the pump,, and the pump will drop down,, you can unscrew it from its housing then empty the **** whats inside it,, then try unscrewing it once all the **** is out... then put it back together the way it came undone.
Oct 19, 2012 | Bosch Logixx WAS2446 Front Load Washer
Attempting to tow my 2002 foed exployer from a ditch I hooked a chain to the dricer side tie rod. It bent> I have unhooked the end of the tie rod from the wheel and now need to take the end of the rod...
I would count the number of threads exposed at the point of adjustment and duplicate those on the new. This will get you close enough to be safe but replacing any part that can affect tracking needs to be also brought in for alignment, otherwise you may have a tendency to pull left or right and experience uneven and abnormal tire wear.
Jul 08, 2011 | 2008 Ford Expedition El
How best should a speaker be place in big church auditorium
Main speakers shall be placed in front (left and right)
Satellite speakers shall placed at the front and right
sides until the end of the big church auditorium. spaced
at 10 meters apart.
Oct 22, 2009 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
Removing unit from car
pull the front surround off from around the unit, it may be affixed by screws, so be careful not to break the case, then you shall see some screws holding the unit in from around the side of the deck. Unscrew those and you're away
Jul 28, 2009 | Pioneer DEH-P6800MP CD Player
How do i change the speedometer cable on my 95gpz 1100, because my speedo is dead and i cant find anyone close that works on older bikes
First you must buy the cable.Then use a pair of pliers to unscrew the end of the old cable from both sides or a screw driver if it uses a screw to hold it.To unscrew the old cable from near the wheel it is easy I believe.But at your speedometer it is not.You must loose the screws that hold the whole assembly to their bracket so that you can lift them and see the other end of the cable.Remember the routing of the old cable to put the new one exactly through the same route.After you install in place the new one first try to plug in the lower side near the wheel.Try pushing from the other end the inside wire so that it clicks in the other side.Then keep your front wheel lifted and spin it and check that the other end on the speedometer is turning around.Then plug that end to the speedometer and the whole assembly to its bracket and you are done.
May 07, 2009 | 1995 kawasaki GPZ 1100
Both door handles in the interior have broken off, it is amanual door lock. This is a 1999 Toyota Corolla
Get two new handles.
Unscrew the phillips screw located in the center of the handles. Slide the handle assembly backwards and out. Unclip the clip that holds on the metal lock-rod (needle nose pliers helps with that), and remove the lock rod. Fit the rod into the new handle's clip, and snap the clip into place on the new handle. Slide the front end into the door cavity, and then the back side. Reinsert the phillips screw. Very easy to do.
Thnaks for choosing FixYa for advice!
Mar 12, 2009 | 1999 Toyota Corolla
How do I remove and replace the door handle on a '01/51 VW Golf ?
you need to remove the blank where the lock barrell would be fitted if it was drivers side.to do this remove the black plastic bung that is located on the edge of the door ,then pull the handle as if you were opening the door and hold it in that position,then insert a 20 torx screwdriver in the exposed hole from pulling the bung out and unscrew untill you start to feel resistance ,the screw will not come out you are just slackening it.then you will be able to release handle and pull out blank or barrell if you have one fitted.then flick the cable out the handle ,you can then pull handle towards the back edge of the door and un hook it from door.holding the handle while you are unscrewing the screw is important if you dont the retainer can fall of and end up in the door........not good....
Feb 10, 2009 | 2001 Volkswagen Golf
Easy Nichia 5MM LED 18 LM Adjustment Mini LED Flashlight Torch ARCHON B10 Logo
109 people viewed this question
Top Easy Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you an Easy Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
