Question about Easy Nichia 5MM LED 18 LM Adjustment Mini LED Flashlight Torch ARCHON B10
Sorry for sending uncompleted infn. After I unscrewed the lense cap I found no part can be unscrewed but the bulb holder compartment.
    Habit-Forming:
    New Friend:
  • 5 Answers
Write your problem clearly so we can help you
Posted on Nov 26, 2014
Lamp Holder
It has to be reinforced
Jul 25, 2012 | Neff Ovens
Rear deck stop light
the hyundai suggested method is by removing the back seat. the dealer will charge you around $100.
i have done it using an alternate method.
1. open the trunk
2. crawl in facing up
3. locate openings below the brake light
(the opening is offset from the bottom of the light and holder (very helpful of hyundai!!!)
4. remove the foam pieces if any.
5. remove the screws holding the cover in place. a magnetic philips screwdriver would be good.
6. unscrew the light using the tab at the bottom of the holder
7. push it up and into the passenger compartment.
8. the entire assembly should come out from inside the compartment.
9. replace the bulb.
10. saw off the extra plastic tab at the bottom of the holder ( will help in putting it back and for future installs)
11. replace everything in the reverse order: bulb , cover ( inside the passenger compartment), replace screws from inside the trunk.
Jul 19, 2012 | 2006 Hyundai Sonata
Can the light bulb on the Pfaff 7570 be changed without the bulb changer tool?
Yes. First turn off the machine. You need to get out the cover (cap) with the stitches number in it. Move the bobbin winder to the position to full a bobbin. Unscrew the screw near the bobbin winder. Next unscrew the screw near the thread reel holder. Pull up the handle to carry the machine and now put up this cover. Unscrew the biggest screw at the left hand, just unscrew a little. I'ts a little more down. Then pull up the cap at the left hand (the cap that have the thread trimmer). Now change the bulb and put all the caps to the right position. I hope that you understand me, my first language is spanish.
Dec 08, 2010 | PfaFF Creative 7570
How to install new light bulb
unlike the older models were there was a small compartment were you could take of a small covering and unscrew / replace the globe they are now a sealed unit if you take the entire top of youl see the globe and black globe holder dont try to unscrew it they dont unscrew if you can order a new globe holder included then simply install as per removal but be carefull microwaves hold a lot of power even when disconnected from power dont touch the capacitor or it will shock you
good luck
please rank me ..
Jul 04, 2010 | Microwave Ovens
Disassemble the plastic tail light lens to replace a bulb ES300
You don't have to take the lense apart to replace the bulb. Pull inner liner in the trunk back and your find where the light wiring is. Unscrew the light holder and replace the bulb.
Apr 01, 2010 | 2000 Lexus ES 300
HOW DO YOU PUT A BULB IN A MINI-MAGLITE?
Unscrew the lense, pull bulb out replace with new one. Normally an extra one is in the end cap in a plastic tube. be sure not to touch new bulb with hands use a tissue.
Oct 09, 2009 | MagLite Camping, Backpacking & Hiking
Need to remove and install driver's side tail light on 2007 Jeep Overland
OPEN HATCH AND REMOVE TWO SCREWS FROM THE INSIDE OF THE BODY PANEL FACING THE TAIL LIGHT. GENTLY PULL THE LIGHT BACKWARDS UNTIL THE WHOLE LENS AND LIGHT FIXTURE COME OUT FROM THE BODY. UNSCREW THE SOCKET AND REPLACE THE BULB. I HOPE THIS HELPS. THANKS FOR USING FIX-YA.
Aug 28, 2009 | 2007 Jeep Grand Cherokee Overland
Headlight bulb replacemnent
you don't you unscrew the lamp holder and pull the bulb out and pry the bulb from the bulb holder asembly.
Jul 22, 2009 | 2003 Kia Sedona
Can not figure how to access bulbs on rear of my 1985 Trans Am
You have to remove the rear lenses. There should be plastic wing nuts in the hatch compartment that if you unscrew them, the lenses can be removed exposing the bulb sockets.
Mar 28, 2009 | 1985 Pontiac Firebird
Replace tail light bulb
The process for changing the tail light bulbs for a 2002 New Beetle in my case a TDI is relatively simple. To remove the lense and gain access to the bulbs you first need to release the lense holder from inside the trunk by completely unscrewing the large plastic wing nut that is under a round plastic panel that's located almost directly behind the rear brake light lense. To gain access to the plastic wing nut remove the round panel by gently prying it off. After this is done you release the lense by using something flat like a dinner table knife to pry and release the clip that holds the lense in place. Locating the clip: The rear fender has two seams that end at the light lense, the inboard seam (the one closest to the hatch)is where you want to insert the table knife to pry the metal clip that holds the lens in place. Gently and carefully insert the knife blade directly at the seam and pry upward to release the lense. Once the clip releases pull the lens the rest of the way and remove the bulbs by turning the bulb holder sockets couter-clockwise. After this is done remove bulbs by slightly pushing down on the bulb and turning it counter-clockwise. The reinstall is reverse of the removal the procedure.When re-installing take care to clock the lense where the metal clip and the lense protrusions end up in the same position as before. Note: you may need to assist sliding the lens retaining clip in with the knife when reinstalling! Good luck
May 15, 2008 | 2003 Volkswagen New Beetle Convertible
Easy Nichia 5MM LED 18 LM Adjustment Mini LED Flashlight Torch ARCHON B10 Logo
100 people viewed this question
Top Easy Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you an Easy Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
