Question about Easy Nichia 5MM LED 18 LM Adjustment Mini LED Flashlight Torch ARCHON B10
Still the flash cannot be open for battery replacement. your continuing support is much appreciated.
The end portion and the lense side unscrewing trying failed.
  • 37 Answers
There are two threadings one for the lens and one for the bulb, try again
Posted on Nov 26, 2014
Where is battery located on 1986 Suzuki calvacade
Hi, Mark for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Suzuki, despair not, for a mere $10 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
1986 Suzuki GV1400 Cavalcade LX battery location Google Search
1986 1987 1988 1989 1990 Suzuki GV1400 Cavalcade models Service Repair...
OEM parts for Suzuki
Suzuki GV1200GLG Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jul 14, 2016 | 1986 Suzuki GV 1400 Cavalcade LX
How to open the flash for battery replacement ?
Many flashlights will have a threaded cap opposite the lenses side that will unscrew providing access to the battery storage compartment.
Nov 26, 2014 | Easy Nichia 5MM LED 18 LM Adjustment Mini...
FS2S0 universal stylus laser pen how do you put the batteries in
If you lay the combo pointer on the table with the stylus to the left and the laser end to the right...then pick it up and unscrew the laser end of the barrel from the stylus end of the barrel, or unscrew the clip portion of the pen from the stylus barrel end....the batteries will be in the clip end of the pen....remove and replace batteries with in kind and reassemble.
May 26, 2014 | Computers & Internet
Replacing battery
Need a screwdriver. Unscrew the back of the mouse. Usually there's a compartment where the battery is isolated.
Apr 02, 2014 | HP DC172B Mouse
I'm trying to identify a tail light lense that I believe to be 1973 Pontiac tail or rear side marker. The raised portion of the lense is 7/8" X 7" and it says PMD 35A SAE P1A 73 on it It has...
Can you upload an image of the lens? Perhaps your internet service provider has an area that will allow you to upload an image, then you can paste the link to this post so I can view it?
Dec 29, 2010 | Pontiac Catalina Cars & Trucks
I would like to know how i get the very bottom piece off my vacuum off so I can put a new fidder hose on it? The hose is black and it is only about six inches long. its lacation is on the very end of the...
You don't have to take the vacuum apart.
Assuming this is an Epic 3500 or similar upright Electrolux:
1. Lay vacuum on it's side.
2. Gently pull hose from power head. It's not screwed in so that should be easy.
3. Unscrew it from the upper portion of the machine by turning the hose clockwise. Turning counterclockwise tightens it.
4. Remove it.
5. Screw one end into upper portion of vacuum by turning counterclockwise.
6. Insert other end of hose into opening in power nozzle. Some manipulating may be necessary for proper fit, but this is all that's needed.
Sep 22, 2010 | Electrolux Epic 3500 Vacuum
KREEPY-KRAULY Ties itself into a knot while cleaning.
Solution:
We removed 2 portions of hose located at the Krauly end, and attached those at the filter end, then we took the 2 portions located at the filter end, and placed those at the beginning of the Krauly end.
Apparently the problem was that the 2 portions of hosing at the Krauly end had become "twisted" and continually enabled the Krauly to move in the knot tying direction. By replacing these 2 portions at the Krauly end with "un-twisted" portions from the filter end, this ended the twisting cycle.
The Krauly has been running for 48hours straight now without a single knotting episode.
If we see the knot tying direction beginning again, we will repeat these steps, continually replacing with un-twisted portions.
At 1st we thought we needed to purchase some new tubing, but we didn't have to, only needed to move around some hosing.
Jan 03, 2010 | Pentair Kreepy Krauly Inground Automatic...
I have a 2000 Nissan Xterra SE V6. My center
Before you begin to diagnose and test the stop light system (that's what's it's called in the service manual), you should look at the following
wiring diagram to try and understand how the system work. This will help you to logically walk through the diagnosis process.
TESTING FOR “OPENS” IN THE CIRCUIT
Continuity Check Method
The continuity check is used to find an open in the circuit. The
Digital Multimeter (DMM) set on the resistance function will indicate
an open circuit as over limit (no beep tone or no ohms symbol).
Make sure to always start with the DMM at the highest resistance
level.
To help in understanding the diagnosis of open circuits please refer
to the schematic above.
1) Disconnect the battery negative cable.
2) Start at one end of the circuit and work your way to the other
end. (At the fuse block in this example)
3) Connect one probe of the DMM to the fuse block terminal on
the load side.
4) Connect the other probe to the fuse block (power) side of SW1.
Little or no resistance will indicate that portion of the circuit has
good continuity. If there were an open in the circuit, the DMM
would indicate an over limit or infinite resistance condition.
(point A)
5) Connect the probes between SW1 and the relay. Little or no
resistance will indicate that portion of the circuit has good continuity.
If there were an open in the circuit, the DMM would
indicate an over limit or infinite resistance condition. (point B)
6) Connect the probes between the relay and the solenoid. Little
or no resistance will indicate that portion of the circuit has good
continuity. If there were an open in the circuit, the DMM would
indicate an over limit or infinite resistance condition. (point C)
Any circuit can be diagnosed using the approach in the above
example.
Voltage Check Method
to the previous schematic.
In any powered circuit, an open can be found by methodically
checking the system for the presence of voltage. This is done by
switching the DMM to the voltage function.
1) Connect one probe of the DMM to a known good ground.
2) Begin probing at one end of the circuit and work your way to
the other end.
3) With SW1 open, probe at SW1 to check for voltage.
voltage; open is further down the circuit than SW1.
no voltage; open is between fuse block and SW1 (point A).
4) Close SW1 and probe at relay.
voltage; open is further down the circuit than the relay.
no voltage; open is between SW1 and relay (point B).
5) Close the relay and probe at the solenoid.
voltage; open is further down the circuit than the solenoid.
no voltage; open is between relay and solenoid (point C).
Any powered circuit can be diagnosed using the approach in the
above example.
TESTING FOR “SHORTS” IN THE CIRCUIT
To simplify the discussion of shorts in the system please refer to
the schematic below.
Resistance Check Method
1) Disconnect the battery negative cable and remove the blown
fuse.
2) Disconnect all loads (SW1 open, relay disconnected and solenoid
disconnected) powered through the fuse.
3) Connect one probe of the ohmmeter to the load side of the fuse
terminal. Connect the other probe to a known good ground.
4) With SW1 open, check for continuity.
continuity; short is between fuse terminal and SW1 (point A).
no continuity; short is further down the circuit than SW1.
5) Close SW1 and disconnect the relay. Put probes at the load
side of fuse terminal and a known good ground. Then, check
for continuity.
continuity; short is between SW1 and the relay (point B).
no continuity; short is further down the circuit than the relay.
6) Close SW1 and jump the relay contacts with jumper wire. Put
probes at the load side of fuse terminal and a known good
ground. Then, check for continuity.
continuity; short is between relay and solenoid (point C).
no continuity; check solenoid, retrace steps.
1) Remove the blown fuse and disconnect all loads (i.e. SW1
open, relay disconnected and solenoid disconnected) powered
through the fuse.
2) Turn the ignition key to the ON or START position. Verify battery
voltage at the battery + side of the fuse terminal (one lead
on the battery + terminal side of the fuse block and one lead
on a known good ground).
3) With SW1 open and the DMM leads across both fuse
terminals, check for voltage.
voltage; short is between fuse block and SW1 (point A).
no voltage; short is further down the circuit than SW1.
4) With SW1 closed, relay and solenoid disconnected and the
DMM leads across both fuse terminals, check for voltage.
voltage; short is between SW1 and the relay (point B).
GROUND INSPECTION
Ground connections are very important to the proper operation of
electrical and electronic circuits. Ground connections are often
exposed to moisture, dirt and other corrosive elements. The corrosion
(rust) can become an unwanted resistance. This unwanted
resistance can change the way a circuit works.
Electronically controlled circuits are very sensitive to proper
grounding. A loose or corroded ground can drastically affect an
electronically controlled circuit. A poor or corroded ground can easily
affect the circuit. Even when the ground connection looks clean,
there can be a thin film of rust on the surface.
When inspecting a ground connection follow these rules:
1) Remove the ground bolt or screw.
2) Inspect all mating surfaces for tarnish, dirt, rust, etc.
3) Clean as required to assure good contact.
4) Reinstall bolt or screw securely.
5) Inspect for “add-on” accessories which may be interfering with
the ground circuit.
6) If several wires are crimped into one ground eyelet terminal,
check for proper crimps. Make sure all of the wires are clean,
securely fastened and providing a good ground path. If multiple
wires are cased in one eyelet make sure no ground wires have
excess wire insulation.
Apr 06, 2009 | 2000 Nissan Xterra
Sony dscw50
hi there
is it the lense not coming out or just the covers over the end of the lense?
if it is the lense it self gently tap it on its side by the battery compartment then switch on when the lense comes out take hold of the end and gently twist then pull it and switch off and on again this may solve your problem.
Aug 30, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Can't fire properly at 90 degrees
Did you buy this used? Maybe the following problems: wires inside are loose or cold soldered. Flash tube has coated with film coating or flash head(inside)is dirty. Alexander atdlee@netzero.com
Jan 13, 2007 | Metz Mecablitz 60CT4 TTL Flash
Easy Nichia 5MM LED 18 LM Adjustment Mini LED Flashlight Torch ARCHON B10 Logo
135 people viewed this question
Top Easy Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you an Easy Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
