When I command my eoson stylus photo 1410 to print, the ink unit system blocks the carriage unit just before it picks the paper producing a loud noise with paper light blinking & ink flow into the waste cintainer. I really need assistance in this please. My email is hafizua@ymail.com.
    Top Expert:
  • 6,702 Answers
We don't send mails.
But scrutinise the printer, to check nothing has fallen in. Even a paperclip can block free passage of the printer head.
Eventually disconnect the printer from the mains and try to move the head careful from one site to the other. Use a bright light to see if anything is blocking the head.
Posted on Nov 26, 2014
I replaced a waste ink container for my epson stylus photo 1410, after that if I on it, the carriage will move to home position, the other side & back again. Then suddenly a loud noise whiles both ink &...
Carriage return drive error sounds like a possible obtruction or drive belt hangup. The best I can suggest is a thorough inspection but remember the printer head drive (which is the same as the old old carriage return nomemclature from typewriters and daisy wheel printers) can be impeded from several sources including even the paper feed. The question you should ask yourself, if you can't find something to adjust or fix, is how old the printer is. These days, many printer are cheaper to replace than even to change the first ink cartridge. So you must weight the cost of repair (in it comes to that) with the cost of a another, new, essentially disposable, replacement printer. Also, sometimes total shutdown and inplugging replugging of a printer will restor normal functioning. Also clean paten and roller with damp cloth might eliminate jams in the cartridge transport drive train.
Oct 28, 2014 | Office Equipment & Supplies
Print out is unclear
Epson Stylus Photo 1410 Series Print out is unclear
Mar 23, 2014 | Epson Stylus Photo 1410 Series
I get noise in the dark earies whine i use glossu paper
You should check that you are using compatible ink for the printer that you are using and that you are selecting the correct paper type in the printer properties section when printing.
Jan 20, 2013 | Epson Stylus Photo 1410 Series
Problems with printing photos. Hp Psc 1410
check the configurations again, if the problem were still there, try with other cartridges.
Aug 13, 2009 | HP PSC 1410 All-In-One InkJet Printer
Paper feeds ok but after a second it advances an inch then get the error paper jammed. wont print please help
When turn on status ok, but when star to print, it feed paper then jammed? Problem with head carriage. Check chip and connector chip at carriage. Try to use another ink tank.
Jun 25, 2009 | Epson Stylus Photo R300 InkJet Printer
Red warning lights remain on.....
Ink and paper light on : head carriage error/general error. Head can't move extremely to right : head carriage blocked or CR motor error. Turn of printer, unlock head carriage lock. Move head left and back to right (to parking position). Is it move freely?
Jun 16, 2009 | Epson Stylus Photo R200 InkJet Printer
I have an epson stylus PHOTO RX500. I need to change the "black" ink cartridge but the ink carriage will not move into a position that will allow the top of the ink carriage to be lifted. When I push the...
Try unplugging the unit and then plugging it back in. When you first power it up, it should do an initial system check, which involves moving the print head. Unplug the unit the moment the print head is in a position to change the cartridge. I did this with my old Canon when I had the same problem and it worked. Hope it works for you too.
Feb 08, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Epson 1280 ink carriage making noise and not printing
hello there. try re-seating the cartridge. Take it out, then put it back in.
Nov 28, 2008 | Epson Stylus Photo 1280 InkJet Printer
I have trouble psc 1410
reason of all led check all step by step
1. cartridge short or fail
2. encoder strip not working
3. paper sensor not working
4. carrige block data cable brake
5. carriage block pcb fail
6. main pcb fail
Feb 11, 2008 | HP PSC 1410 All-In-One InkJet Printer
Epson stylus photo 830
Yes it can probably be fixed. I hope you poked your friend in the eye for giving you such a headache though. You will need to dismantle the machine and remove the Auto Sheet Feeder (ASF) Once removed, check there is no bits of paper stuck inside. Then turn the pick up mechanisme by hand through a couple of revolutions to re synch everything. Also check the paper sensor is still intact - if not you can construct a new one from a piece of plastic or if the old one is still present, just glue it back together. You can download a service manual to hep you out with the dismantling from either: http://www.TheServiceManualShop.com http://mikeburton.tradebit.com/
Apr 12, 2007 | Epson Stylus Photo 830 InkJet Printer
29 people viewed this question
jasbo
jasbo
