Question about Bosch Washing Machines
I have a avantixx 7 which wont empty when on a rise n spin mode
    Dedicated:
    Visited the website for 20 consecutive days.
  • 817 Answers
If the machine spins and is trying to empty at the correct place in the cycle it could be a number of causes other than a circuit board problem. These include a blocked filter, blocked or kinked outlet hoses, a faulty pump or a blocked pump. Included in the blocked pump is the chance that something is stopping the pump impellors turning so even though some water may escape it is not allowing it to pump efficiently. I have found hair clips to be a problem but more often than not it is the wire from inside a brassiere. Not sure of your model, but some pumps operate by being pulled up to a wheel that spins and operates the pump. It is possible that the pull is not sufficient enough to work the pump fully.
Posted on Nov 26, 2014
  • 36 Answers
If it is just on 'rinse n spin' it may be you are using loads that won't balance because they are too much for the machine and the drum stops going round. It will try again after a few seconds but if still unbalanced it will stop. It could also be a faulty sensor that is saying the drum is out of balance.
If it is a pump problem there can be a few reasons but the most common is the possibility the pump is clogged up with everyday debris (I found bits of wood, coins and hairgrips in mine and what finally jammed it was a pair of tweezers!)
How to reset the error code F21 on a Bosch Avantixx 6
You can try the following steps:
1. Turn the washer knob to the 'off' or reset position 12 o'clock.
2. Turn the knob to the 6 o'clock position.
3. Press and hold the spin button.
4. While holding it, turn the knob to the 7 o'clock position.
5. Continue holding the spin button for about 5 seconds.
6. Release the button.
7. Turn the knob to off.
When your turn it back on it should have cleared the error code.
Jul 21, 2016 | Bosch Washing Machines
I've a Bosch avantixx washing machine and it won't empty the fabric softener unit. It has water left in or some softner. I've taken the tray out and cleaned it.
The softener unit is flushed between wash cycles to prevent clogging. What you are describing is normal operation.
Jul 12, 2016 | Bosch Washing Machines
My hoover optima 7 kg 1400 aaa will not go into the spin mode ?
drain pump needs to be replaced, washer needs to be empty then will spin. please comment.
Dec 03, 2014 | Hoover Washing Machines
Water wont empty
The pump out motor is in line with the outlet hose. This motor must spin to pump out water. The motor has 2 push on electrical connectors and mains voltage must be across the connectors in pump out mode. If mains voltage is across and motor does not spin ... motor open circuit and need replacing. If motor spins but no water pumped out indicates either pipe blocked or impeler in motor not turning. No voltage across terminals indicates a wire fault or timer / switching fault that must supply voltage to the pump at the correct time. The removal of the motor is quit easy to do.
Apr 26, 2010 | Maytag 24 in. MDBH970AWS Built-in...
Need code/s for LG WM1832CW to have washer do a spin/drain only
1. press POWER button to turn om.
2. press SPIN SPEED button only.
3. press START/PAUSE button/
May 02, 2009 | LG WM-1832C Front Load Washer
Matag top load washer wont spin or empty
Set the timer for manually for the spin cycle and trun it on.
If it does not spin replace the lid switch.
Mar 14, 2009 | Maytag Washing Machines
Washing Machines Logo
98 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
