Question about Samsung SCX 4521F All-In-One Laser Printer
<!-- from fixya rte -->Facing open heat error in scx4521 f - Samsung SCX 4521F All-In-One Laser Printer
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 58 Answers
Replace fuser and update firmware
Posted on Nov 26, 2014
Tip
GM OBD1 Codes
DTC - 12 No distributor reference pulse (diagnostic test active)
DTC - 13 Oxygen sensor circuit open or no activity
DTC - 13 Left bank O2 sensor circuit open or no activity
DTC - 14 Engine coolant temp sensor error (high temp indicated)
DTC - 15 Engine coolant temp sensor error (low temp indicated)
DTC - 16 System voltage too low
DTC - 17 Camshaft position sensor error
DTC - 21 Throttle Position sensor error (signal high)
DTC - 22 Throttle position sensor error (signal low)
DTC - 23 Intake air temp sensor error (low temp indicated)
DTC - 24 Vehicle speed sensor error (open circuit or no activity)
DTC - 25 Intake air temp sensor error (high temp indicated)
DTC - 26 Quad Driver Module (QDM A) error
DTC - 28 Auto transmission range pressure switch error
DTC - 31 Wastegate solenoid circuit error
DTC - 31 Gear Position Switch (PRNDL) error
DTC - 32 EGR system failure
DTC - 33 MAP sensor circuit error (signal high indicating low vacuum)
DTC - 34 MAP sensor circuit error (signal low indicating high vacuum)
DTC - 35 IAC problem or idle error
DTC - 36 MAF sensor error
DTC - 36 24x Crankshaft position sensor circuit error
DTC - 36 4T60-E Shifting Error
DTC - 37 TCC brake switch circuit error
DTC - 38 TCC brake switch circuit error
DTC - 39 Clutch switch circuit error
DTC - 39 TCC error
on Sep 10, 2011 | 1991 GMC Sonoma
Warming up scx4521
Its main board faulty & scanner unit.
Jun 12, 2013 | Samsung SCX 4521F All-In-One Laser Printer
Fax in samsung scx4521 is not working right now from from today
Does it come up with any errors when you trying to send a fax or receive? Please make sure that your fax line is working fine.
Mar 27, 2012 | Samsung SCX 4521F All-In-One Laser Printer
SCX4521 Printer is displaying error message Scanner Is locked how to solve this problem
Solution from samsung site i hope it will work for you
1. Press MENU # 1 9 3 4 in sequence rapidly. The LCD panel should now display TECH.
2. Press MENU, and then press ENTER. The LCD panel will display Tech Mode.
3. Press the left arrow (4. Press ENTER. The operator panel will display [YES].
5. Press ENTER. The toner warning message should be gone.
6. To exit TECH MODE, press MENU # 1 9 3 4 in rapid succession, as if you were dialing a phone number. The operator panel should no longer display TECH.
Oct 18, 2010 | Samsung SCX-5530FN All-In-One Laser...
While opening n70 camara error is unexpected error
HI there, after turn on the phone don't open the camera.Just reset the phone from phone factory settings.After that restart the phone.When is completely ready for work then open the camera. I hope you naver face the problem.If you faced that problem again, then reinstall the phone software from net or nokia shop. Thanks.
Feb 25, 2010 | Nokia N70 Cellular Phone
Open heat error cycle power
the thermistor in your fuser unit is faulty.
Dec 24, 2008 | Samsung SCX-6322DN All-In-One Laser...
Open Door Error - Open Heat Error
That looks like part of the heating element itself. You need to remove the four screws on the back door, then remove the door so you can have access to the fuser module. There is a black module about 8 inches across that has a heat warning on it and two sets of wires coming out. With printer unplugged and face down, unhook each wire set and locate the four screws that hold it in place. Remove them, then pull the module up and out. On either side of the module you will see where the wires connect to a long thin metal plate that runs through a rolling mechanism. In all likelihood, if the element on the fuser is broken you will need to order a new one. Installation is simple -- reverse my instructions for disassembly (Dell can send you the new part--just call Dell parts and service to order).
Feb 24, 2008 | Dell 1600n All-In-One Laser Printer
Samsung SCX 4521F All-In-One Laser Printer Logo
54 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
