Question about Konica Minolta Office Equipment & Supplies
How to correct permanent F26-3 code
How to programme prmb
  • Norman  J Weimar Jr
    Norman J Weimar Jr May 03, 2016
    Hi Peter Taiwo Oyinyemi, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?model number would help
Hi. I have a SONY Vaio. Model: PCG-21114W. I have somehow changed the "hard disc user password" when laptop starts up. How do i change this without wiping the whole laptop completely?
You can't. It is a permanent password. All you can do is type the correct password or purchase a new hdd and restore your backups to it after installing your OS and programmes.
Nov 15, 2016 | Sony Computers & Internet
Programing anew key
BMW Multi Tool is known as one of the best car key programmers for BMW vehicles ever since OBDII tools were available in last century.
It has multi-function: key programmer, odometer correction, eeprom read and write, Synchronization Codes, and so on.
BMW Multi Tool includes forth parts, hardware device, dongle, programmer, software. Before running software you must connect dongle and hardware device to computer.
Newest version is V7.0 BMW Multi Tool V7 0 for CAS1 3 and EWS Powerful Than AK300
May 09, 2014 | 2001 BMW 325
Hoover optima not displaying correct wash times
Seems that if the fault seems to be permanent it is due to failure of the PROGRAM CONTROLLER UNIT.
You will need to check on the connectors to and from the controller, clean and reset. If not replacement of the controller is the only solution.
Jan 16, 2013 | Washing Machines
What is the function of the battery, is it just backup for loss of power?
The battery in the remote control is the power source. The remote control is essentially an LED flashlight that turns on and off very rapidly to send coded signals to the controlled device. The light is infrared "colored", which is not visible to humans.
Like any flashlight, it fades out when the battery gets weak. Also, at some point the encoder chip quits working because there is not enough voltage for the transistors inside it to operate correctly.
Some remote controls (programmable models) store setup information in memory. These either use an internal rechargeable battery or capacitor to retain the data for a short time while the battery is changed, or they use an EEPROM for more permanent storage. The EEPROM models would be more expensive, but they won't lose their programming data if the battery is run down too far.
Apr 29, 2011 | Televison & Video
How do I set the temporary or permanent override feature on the Honeywell RTH2310B model thermostat?
To set the temporary override, press arrows up or down to desired temp. This will keep temperature
at temporary setting for 2 hours then return to programming. To permanent override press MODE button until schedule period number disappears (number inside little house on stat). Then adjust temp with arrows. Press the MODE button again to cancel override and return to programmable.
Jan 25, 2011 | Honeywell Programmable Thermostat Heater
Permanent hold message on thermostat
press run program.... from there, set the schedule for maximum efficiency. permanent hold only shows up after the hold button has been pressed 2-3 times. If this does not fix the issue, there is a master reset button on the thermostat that will set all settings back to factory default.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/cody_17f08cf8e340c06c
May 16, 2009 | Honeywell Programmable Thermostat Heater
Zanussi washing machine won't start E10, E40 & E50 at times
It was suggested that the pump had failed and taken out the programmer with it - expensive! Wife wouldn't wait, and bought new machine. Problem almost solved - anyone want an out of order washing machine?
Feb 03, 2009 | Zanussi ZWF1440 Front Load Washer
Configuration settings do not save in 'Permanent' mode
Q#1, is the DPI the same as the other printers? there is also an option in the menu to rescale DPI that could cause the issueprint out a setup label from the printer and compare it to one of the other printers.
May 24, 2007 | Zebra Z4M Printer
67 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
