Question about Janome America Inc 9700 Memory Craft Sewing Machine JAN012
How do i tack the plastick covers off a janome9700
How do i take the covers off the mershine to put a new stop& start button in it
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • Janome Ameri... Expert
  • 631 Answers
I would recommend that you purchase the service/repair manual for your machine. It might not specifically tell you how to replace the button, but it WILL tell you the best way to take the covers off. I believe they charge $15 for a service manual, and it's well worth the price because knowing how to take it apart can save a LOT of grief later.
Generally, there is a cover over the thread path that must be removed first, then the back, and the front is last. Also, for your purpose, it's not likely that the base will have to be removed. Sewing Parts Online sells service manuals for a wide variety of machines; if your machine is not listed, give them a call and they can and will order it for you.
Posted on Nov 26, 2014
How do i take the plastick covers off the mershine
I think you mean the buttons have stuck. Try reading the manual for this unit and if you no longer have the manual, you could try to use a toothpick to gently try to encourage Tue buttons to unstick. Many of these use a small button to release the covers or a screw that can be removed with a screwdriver to gain access.
Nov 26, 2014 | Janome Memory Craft MC 9700 Sewing and...
How do I make a large buttonhole ..( 1 3/8 inch).. the button doesnt fit on the buttonholer.
You do it using narrow rows of side by side zig zag stitches and bar tacking the ends of the rows. Make a line where you want the hole to be. Set the zig zag stitch width very narrow, whatever is closest to what suits the fabric. Coarse or loose weaves need a wider width, finer ones a narrower width. Experiment on some scraps to get it right. Number of stitches per inch, or stitch length, should be very fine, at least 20 per inch, but not 0. Try a few more experiments on scraps to make sure it looks right. Make a test hole to be sure it is the right size for your buttons.
Stitch a straight line of zig zags down one side of your line, with the edge of the stitching not quite touching your line. Stitch a second row directly on top of the first one.
Repeat on the other side of the line. Ideally you should still be able to just see the line you drew when the rows are done, but not see any bare fabric on either side of the line.
Then move to one end of your rows. Leave the stitch length the same, but change the width to match the width of your two side by side rows. Stitch a bar tack, about the same length as your two rows are wide. If your two rows are 1/8 inch wide, your bar tack should be 1/8 inch long. Do the same at the other end. Make sure the bar tack covers the very end stitches in the rows as it is the anchor that will prevent unravelling. This is exactly what machine buttonhole makers do, but they do it all for you.
Carefully slit between the rows to open the hole. I like to put a drop of Fray Check or something similar on my buttonholes after I cut them open. It makes them much stronger and they will never come out.
Oct 09, 2014 | Sewing Machines
How to make a butten hol
This is a 4 step process. You start at the first step and it sews backwards first, Next you perform step 2 to sew the bar tack. Third you sew the right side of the button hole as it comes towards you. The final step is another bar tack which is the same as the second step.
Dec 26, 2013 | Husqvarna Huskystar 215 Sewing Machine
E1 flashes on the message window of my brother sewing machine
Brother Computer Codes
  • E1: Make sure the presser foot is lowered before sewing.
    E2: You chose a stitch other than a buttonhole stitch or a bar tack stitch and you tried to sew with the buttonhole lever in the lowered position. Raise the buttonhole lever.
    E3: If you selected the buttonhole or tack bar stitch and start to sew with the buttonhole lever raised, you will get the E3 code. Lower the buttonhole lever.
    E4: You hit the reverse button while the bobbin winder shaft was moved over to the right. Move the bobbin winder shaft to the left.
    E5: On automatic sewing machines, the start/stop button was pressed while the foot controller was plugged in. Unplug the foot controller if you are using the automatic function.
    E6: This code tells you that the motor locked up because the thread is tangled. Untangle the thread, make sure the machine is threaded properly and that the proper tension is set before continuing.
Oct 03, 2012 | Brother CS-6000
The button holes that I want to do are larger than the automatic buttonhole will do on my Janome MS5027, is there a way that they can be done manually?
Mark your garment with chalk taking care to mark the start point and end points and a straight line to follow. Set your machine up for a fairly wide bar tack (zig zag in place) Then position the needle left and set it up for a satin stitch (fairly narrow) slowly stitch forward until you get to the end mark. Then do another bar tack. At this point you move your needle to the other side and satin stitch in reverse until you get to the first bar tack.
I would test this on a scrap piece first. Then proceed.
Jul 25, 2012 | Janome Sewing Machines
My machine has a one Step Buttonhole Feature - having problems
Try an Even Feed Walking Foot for more control on thick and quilted type layers
Dec 10, 2011 | Brother CS6000i Computerized Sewing...
When i turn on my sewing machine and press the foot control my machine beeps and e2 error appears
bar tack stitch was selected and the foot controller was pressed (or the start/stop button was pressed if the foot controller is not connected) while the buttonhole lever is lowered.
Raise the buttonhole lever before continuing the operation.
Jun 26, 2011 | Brother CS-6000
How do you use the sliding button hole attatchment
attach the sliding foot by clipping off the current one, placing the sliding food onto the needle plate, lining up the clip with the attchment point and lowering the pressure foot down onto it so it clicks in.
Now, does your machine have a little lever device to the left and just behind the pressure foot, have a look for it. If yes, then pull it down, this is the buttonholing trigger and it connects with the sliding foot to trigger the reverse and stitching of the second side.
Program the machine for button holing, this might be pushing in a numbered code, on my 6500 there are five buttonholes and they each have a code that I enter.
Place your fabric test sample under the pressure foot and put the button into the back of the pressure foot, there is a little ratchet device that closes up holding the button firmly to get the right dimensions.
I always do at least 2 test buttonholes using same fabric, usually 2 layers with interfacing between.
Start the buttonholing sequence by pressing on your machines foot control, it should sew backwards away from you down the first side of the buttonhole, and the trigger should connect with a bit on the slide foot triggering the machine to stop, sew the bar tack, and then reverse and sew the otherside and final bar tack.
That's how it goes on my 6500, I hope this applies to your MC10000 too, it should be very similar. Your machine probably has at least 3 or 4 different types of buttonholes it can do. If you don't have a manual for it, it probably is worth sources one as these machines have lots of features to use.
Jun 12, 2011 | Janome Memory Craft 10000
I can't find my manual and I need to know how to do button holes
You could try to locate a manual on the web or try sewing.about.com, there is lots of information on this website.
Sorry, I'm not familiar with this model machine at all.
But if it is an automatic buttonholer model, there is probably a special buttonhole foot in your accessory box? Is it a long white plastic device where you put a button in the back to get the correct lenth. If yes, then put it on the machine and there will also be a lever at the left side of the presser foot that you need to pull down. This buttonhole style sews the bar tack, then one side, the end tack, then the other side and works backwards from the starting point.
Now check your machine dial settings, there is probably a buttonhole icon?
You might be able to muddle through this way?
Feb 27, 2011 | Simplicity Denim Star SW210
Janome America Inc 9700 Memory Craft Sewing Machine JAN012 Logo
56 people viewed this question
Top Janome America Inc Sewing Machines Experts
matty_w
Chris Wetmore
Tim Rickards
Tim Rickards
Are you a Janome America Inc Sewing Machine Expert? Answer questions, earn points and help others
