Question about Janome Memory Craft MC 9700 Sewing and Embroidery Machine
How do i take the plastick covers off the mershine
The stop & start button has stop in how do i take the plastick covers off it
    Sergeant:
  • 233 Answers
I think you mean the buttons have stuck. Try reading the manual for this unit and if you no longer have the manual, you could try to use a toothpick to gently try to encourage Tue buttons to unstick. Many of these use a small button to release the covers or a screw that can be removed with a screwdriver to gain access.
Posted on Nov 26, 2014
Cannot change stop start button on innovis 1200 sewing machine
The start/stop button won't work if your foot control is plugged in, or if your presser foot is up.
Sep 07, 2016 | Brother Sewing Machines
Once start sewing back stitch will not stop
sounds like the start and stop button is starting to malfunction, probably needs to be checked
Mar 13, 2016 | Sewing Machines
How do i tack the plastick covers off a janome9700
I would recommend that you purchase the service/repair manual for your machine. It might not specifically tell you how to replace the button, but it WILL tell you the best way to take the covers off. I believe they charge $15 for a service manual, and it's well worth the price because knowing how to take it apart can save a LOT of grief later.
Generally, there is a cover over the thread path that must be removed first, then the back, and the front is last. Also, for your purpose, it's not likely that the base will have to be removed. Sewing Parts Online sells service manuals for a wide variety of machines; if your machine is not listed, give them a call and they can and will order it for you.
Nov 26, 2014 | Janome America Inc 9700 Memory Craft...
My Aunt gave her D'lite sewing machine. It sews correctly but will not stop sewing unless you unplug the cord. The start and stop button will start the sewing if not using the foot pedal but it will
There's a possibility that your foot pedal is sticking; if that is the case, it's probably overriding the stop button. See if you can take the cover off and clean it using alcohol, and leaving it open for a couple of hours to make sure it has dried. Visually check the wires while it's open, too, to see if you can see any fraying, and make sure the plug on the machine side is firmly seated in the machine.
Sep 14, 2014 | Sew D'Lite Sewing Machines
E7 error message Singer Patchwork
I used can air and blew out the reverse button area. Worked immediately after turning off and back on.
Mar 23, 2014 | Singer 7258 Sewing Machine
Start/stop button
In order to use the start/stop button the foot pedal must be unplugged.
Jun 15, 2013 | Simplicity Quilter's Classic SW240...
Flashing start/stop button
could be a short in the wiring, the button could be jammed
taking the machine to a sewing machine shop would tell what's
wrong for sure
May 31, 2012 | Singer Izek Computerized Sewing Machine
I need to know how to thread a bobbin?
TRY THIS, itma not be your model, but should help Title:
ac093.jpg Pre-tension disk ac094.jpg Bobbin winder shaft ac095.jpg Bobbin
1. Pull up the spool pin as far as possible, and then put a spool of thread on this pin. windingbobbin_a0991.jpg
2. Pass the thread around the pre-tension disk. Make sure that the thread passes under the pre- tension disk.
windingbobbin_a0992.jpg ac098.jpg Pre-tension disk c_b4.jpg Pulling it in as far as possible
Caution If the spool of thread is not in the right place, the thread may tangle on the spool pin.
3. Pass the end of the thread through the hole on the bobbin from the inside of the bobbin. windingbobbin_a0993.jpg
4. Put the bobbin onto the bobbin winder shaft and slide the bobbin winder shaft to the right. windingbobbin_a0994.jpg
5. Turn the bobbin clockwise, by hand, until the spring on the shaft slides into the groove of the bobbin. windingbobbin_a0995.jpg ac099.jpg Spring on the shaft ac0991.jpg Groove of the bobbin
7. While holding the end of the thread, gently press the foot controller or press start/ stop button (for models equipped with the start/stop button) to wind the thread around the bobbin a few times. Then stop the machine. windingbobbin_a0997.jpg
Note
  • If the sewing machine is to be operated using the foot controller, connect the foot controller before turning on the machine.
  • When the foot controller is plugged in, the start/stop button cannot be used to start sewing (only for models equipped with the start/stop button).
Caution Make sure you follow the instructions carefully.
If you do not cut the thread completely, and the bobbin is wound, when the thread runs low it may tangle around the bobbin and cause the needle to break.
9. Slide the sewing speed controller to the right (to set the speed to fast).
(For models equipped with the sewing speed controller.) windingbobbin_a0999.jpg ac0992.jpg Sewing speed controller
10. Press the foot controller or press start/stop button (for models equipped with the start/stop button) to start. windingbobbin_a18.jpg
11. When the bobbin seems full and begins spinning slowly, take your foot off the foot controller or press start/stop button (for models equipped with the start/stop button). windingbobbin_a19.jpg
12. Cut the thread, slide the bobbin winder shaft to the left and remove the bobbin. windingbobbin_a191.jpg
13. Slide the sewing speed controller back to its original position (for models equipped with the sewing speed controller). windingbobbin_a192.jpg
Caution Not winding the bobbin properly may cause the thread tension to loosen, and may break the needle.
woundbobbin3.jpg ac0993.jpg Wound evenly ac0994.jpg Wound poorly
Note
  • When the sewing machine is started or the handwheel is turned after winding the thread around the bobbin, the machine will make a clicking sound; this is not a malfunction.
  • The needle bar does not move when you slide the bobbin winding shaft to the right.
Sep 02, 2009 | Brother LS-2125 Mechanical Sewing Machine
SINGER IZEK MODEL 1500
The Izek has a motor over current protection circuit which measures the currend draw at the main motor. If the main motor is trying to run and it draws more current than it should the machine will stop sewing. In sew speak terms the machine is too stiff to turn easily. There are 2 different solutions. Completely lubricate the machine anywhere metal is on metal use oil (sewing machine) and metal on plastic or platic on plastic use white lithium grease. Try the machine now!
Next if that did not fix it make sure there is no lint, thread or the like wrapped around andy parts of the machine. Good luck
Mar 01, 2008 | Sewing Machines
Janome Memory Craft MC 9700 Sewing and Embroidery Machine Logo
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
