Question about Easy Nichia 5MM LED 18 LM Adjustment Mini LED Flashlight Torch ARCHON B10
How to open the flash for battery replacement ?
    Sergeant:
  • 233 Answers
Many flashlights will have a threaded cap opposite the lenses side that will unscrew providing access to the battery storage compartment.
Posted on Nov 26, 2014
Chamberlain 3/4 hp garage door opener works but lights on opener flash 4 short and 2 long flashes over and over again, what is it trying to tell me?
That code is usually for battery back up issues. If you have a battery back up unit, replace the internal battery and it should resolve the problem.
Feb 17, 2015 | Building Materials
Sony cybershot dsw50 error flashing e;91;01 flash not working at all
E:91:01 is Flash error code and this error code comes when Flash Circuit doesn't work.
Camera needs Flash Circuit replacement and part number is as follows...
A-1166-208-A ST-133 BOARD, COMPLETE
Above said Flash Circuit is available in Part Store.
Good Luck.
Nov 27, 2008 | Cameras
No power to car key wont turn
check the alternator and check for a short or ground a wire may be touching the frame you may want to check the engine computer module
Feb 17, 2014 | 2004 Mercedes-Benz S 430
DEAR sIR, My camera flash is not working. I tried all method but still not working.
All -what- methods? The freshly charged new battery one and the one where you open the camera on lint-free cloth and replace the faulty flash component (e.g. bad flash tube?) Wiring in an LED flash is definitely superior to the one built in, and saves on battery wear; but LED flash units wear out too!
Aug 07, 2011 | Fuji FinePix Z10fd Digital Camera
The doors do not open by remote control key(BMW 740il 1996 model)
Programming
When
Key batteries completely discharged. Key batteries not replaced within 60 seconds. Key added or replaced. DO NOT press remote control buttons during battery replacement.
How
Unlock vehicle. Enter vehicle. Close driver's door. Switch ignition ON and OFF. Remove ignition key. Press and hold unlock button Fig. 1 [1]. Press lock button Fig. 1 [2] briefly 3 times within 10 seconds keeping unlock button [1] depressed. Release unlock button Fig. 1 [1]. Some models: LED Fig. 1 [3] flashes slowly for 10 seconds. Some models: Central locking system locks and unlocks rapidly to indicate correct programming. Some models: Repeat above procedure if central locking system does not work and LED does not flash or LED flashes continuously
To change batteries remove panel back of key then screws on plastic bar
Batteries are available from your local motor factor shop
You might not need new batteries try re programing as described above
Apr 24, 2010 | 1998 BMW 7 Series
Liftmaster 973LM. Remote opener does not work. Replaced battery - still does not work. Original owner left no manuals. Works with outside pad and inside button.
ONCE YOU REPLACE THE BATTERY YOU NEED TO REPROGAM THE REMOTE.
WATCH THE LED NEXT TO THE PROGRAM BUTTON WHILE YOU PRESS THE BUTTON ON THE REMOTE IF IT FLASHES THE REMOTE IS SENDING A SIGNAL AND SHOULD WORK.
IF IT DOESN'T FLASH THE REMOTE BATTERY MAY BE IN BACKWARDS OR THE REMOTE MAY BE BAD - IT IS NOT SENDING ANY SIGNAL AT ALL.
HOPE THIS HELPS
Jan 12, 2010 | liftmaster Chamberlain Garage Door Opener...
Garage door opener keypad stopped working. cannot reprogram it.
It could just be you need to replace the battery.
The warning light might be a "battery low" warning - advising you to replace it!
If it stops flashing, the battery has died altogether.
Nov 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
Problem with flash
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
4. Set the flash to iconfillflash.gif.
If issue persists, call 1.800.235.6325 for repair.
Thanks.
Neerak21
Sep 20, 2009 | Kodak EasyShare Z740 Digital Camera
Keypad lights flash, wont open with code. Wall button and remote work.
You need to do a remote and opener re synch, because your rolling synch codes were lost when you replaced the batteries. Go to manufacturers web site for re program instructions.
Apr 18, 2009 | Computers & Internet
Camera shuts down when the flash is opened
the flash circuit of the camera is short. the moment you switch on the flash it drops the supply voltages of the battery. you have to show it to a repairer.
Nov 17, 2006 | Fuji FinePix S1 Pro Digital Camera
Easy Nichia 5MM LED 18 LM Adjustment Mini LED Flashlight Torch ARCHON B10 Logo
262 people viewed this question
Top Easy Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you an Easy Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
