My Raytheon Palm IR 250 will not power on. I know the battery is good, it works well with my other palm. I have started taking it apart and see nothing wrong with any components, loose wires, or any obvious problems. Any ideas? Just to add, the plastic housing of the eye piece was broken off when I purchased it, but all wires seem to be attached properly, holding it to the rest of the camera. Doesn't seem to be the problem, just giving all info as possible.
    Problem Solver:
  • 15 Answers
Hello, connect your thermal camera at the car-charger, if available, or better pull out the battery and try to start this camera only with the power adaptor connected. See if there is any blink- led, image.
These PALM IR have known battery problems.
Posted on Nov 26, 2014
  • 473 Answers
SOURCE: How to change the default handler from Outlook to Palm desktop?
Change sync methods from outlook to palm desktop !!!!! Hi, There are two ways to change the sync methods : 1. Insert the installiation disc into the cd rom device , u will get a window called dicover ur handheld , there please check for change ur sync methods , and u will get another window sayin ur currently using microsoft outlook to sync , would u like to change to palm desktop , say yes and then u will get congrats , click on finish . To make sure it is changed from outlook to palm desktop , right click on hotsync manager at the bottom right corner of the pc , make sure only local usb has a check mark and then left click on custom , in custom check and see if u see calender [outlook] or just calender , if u just see calender , then presuming all the data is in handheld , highlight calender click on change and change the action to handheld overwrites desktop then click on ok , do the same for contact , tasks and memo then click on done and perform a hotsync. 2. Insert the disc , open up my computer , then u will see ur cd rom drive , right click on it and left click on explore , u will find yellow folders , please check for a yellow folder called post install , open that up and inside that u will find outlook switcher , left double click on it and follow the same procedure as told in the first step . Regards
Posted on Sep 11, 2005
  • 277 Answers
SOURCE: Palm Screen Broken
hi the same site is in ynet: http://www.fixya.com/ynet/ go to "handy" in Dizingof cenetr - store for PDA's good luck
Posted on Apr 30, 2006
SOURCE: Dead Palm
Need to change the battery.
Posted on Jun 02, 2008
SOURCE: hard reset for palm centro
When performing a hard reset on the Palm Centro, you hold down the power button as you insert the battery, and then release the power button when you see the second Palm logo.
http://www.palm.com/us/support/downloads/centroupdate/pop_centrohardreset.html
Posted on Jul 31, 2008
SOURCE: Half of my Palm Desktop Contacts disappeared
I also lost my contacts from P to Z but had a back up on a nother computer and when I tried to sink it I lost p to z there also. Does palm know about this problem? Reading this form sounds like a lot of people have the same problem. ACK!!!!!!!!!!!!!!!! Black berry here I come.
Posted on Aug 27, 2008
I have a Palm IR 250 D. I need a replacement eye piece with the rubber eye pad.
I am also looking for a eye cup for a Palm IR250. Someone please post where to find this piece.
Sep 08, 2011 | Raytheon Palm IR 250D
I have a raytheon palm ir 250. I have purchased new batteries and the camera only runs for about 10 minutes before it fizzles out. I then recharge them and then I get less operating time until eventually...
When such things occur with devices it is usually as a result of a discrepancy in the device. If you can get someone with a similar device try borrowing a similar battery device and see how long it lasts. If the battery runs normally then it is the charging device which is faulty. If on the other hand it undergoes the same problem then it is the device which has some discrepancy in its consumption.
Hope this solution has been helpful?
Sep 24, 2010 | Raytheon Palm IR 250D
Bought a used palm ir 250, no battery, no battery charger and apparently the owner couldnt get it to work. I need a place/advice that I can purchase said items and have someone look at it.
This device uses PC-DR11: Duracell 6V/4200 mAh NiMH (BNH-159-4SBK) Battery Equivalent.
Duracell quit making this battery, but you can find after-market batteries at a moderate price. You should be able to find a universal charger that will charge these as well.
Jan 13, 2010 | Raytheon Palm IR 250D
PalmIR 250 Owners Manual Required Unable to work out operation?
you cannot get manuals online you can call the company at (702) 369-3966 and request one.
Jul 12, 2009 | Raytheon Palm IR 250D
Ratheon Palm Ir Model 250 When turn on only shows a solid white screen. I am attempting to repair this for a police dept. I am an electronics eng. and have onpened it up and can see nothing unplugged. I am...
Whenyou opened the unit there is a small black plastic disk with a white membrane. With the unit open and turned on is this spinning? If not the motor is likely bad. I am not sure where or even if parts are available for these units. I came across this post looking for a motor myself
Good luck
Jun 08, 2009 | Raytheon Palm IR 250D
Palm TX Touchscreen does not work
Search youtube for Palm TX Digitizer Replacement and Palm TX Take Apart Direction. If you think you can do it, or know someone who can, you can order a replacement digitizer on ebay for from somewhere like www.pdaparts.com.
Before ordering the part, you may want to start by opening the palm and cleaning the connecting ribbon cable contacts to make sure that a loose cable or oxidation has not caused your problem.
Feb 03, 2009 | Palm TX Handheld
Region unlock code.
hopefully this will help
Converting the player to Multi-Region:
Requires the use of a Palm Pilot w/Palm OS 3.0 or later and the OmniRemote Pro from http://www.pacificneotek.com/
(Other PDAs using Palm OS and compatible with the OmniRemote Pro from http://www.pacificneotek.com/ can also be used).
1. Program the Palm Pilot/OmniRemote. For instructions on programming the Palm Pilot/OmniRemote click How to Program the Palm Pilot.
2. Power on the DVD player without any DVD in the tray.
3. Keep the programmed Palm Pilot close to the IR port of the DVD player.
4. Start the OmniRemote program.
5. Place OmniRemote in TV mode and tap the "0" button on the OmniRemote.
6. The DVD player will power off.
7. Power the DVD player on again. Check the Region-free status by playing a DVD.
Dec 18, 2008 | Pioneer Televison & Video
Dropped my Palm TX, IR no longer works
I went to the Palm support website. It seems that after any reset, including a soft reset, the Beam Receive function has to be re-enabled. Follow this path:
  • Applications==>Prefs==>Power
  • Beam Receive==>Off==>On==>Done
For more information: http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE?New,kb=PalmSupportKB,CASE=obj(14838),ts=Palm_External2001
I also updated the driver for my Palm wireless keyboard.
http://www.palm.com/us/support/downloads/universal_wireless_keyboard.html
Cheers!
Nov 25, 2008 | Palm TX Handheld
Raytheon Palm IR 250D Problem:
Without the lens, the lcd screen is useless. The screens are pretty delicate and is probably broken if all you can see is white. Try it in a dark room. More than likely the on-imager screen is trashed. Try plugging a vcr / cam-corder into the video output on the device and you should get a picture there. Unfortunately, this limits your portability for the device. But you should be able to use it and the plus is that you can record your output.
May 03, 2008 | Raytheon Palm IR 250D
Unlock codes for Pioneer DVD player
Pioneer DV-667A
Dec 13, 2007 | Televison & Video
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
