Question about Refrigerators
My refrigerator when you push the arm to fill your glass with ice it isn't doing nothing.
You push the arm and there isn't any noise even it is just dead
  • 1,363 Answers
Take out the guts and run over with hot water, than dry them good, try again.
Posted on Nov 26, 2014
KitchenAid 25in KSRJ25CNST00 icemaker trouble. The LED light on side of freezer is blinking twice with a delay and repeats same sequence. No ice is making. Any suggestions on what to look for?
Try the reset button on the control panel. If that doesn't work, then try unpluging the refrigerator.
Also, make sure that ice tray shut off arm isn't in the up position. It should be in the unlock position one notch below the off position. This arm is used by the refrigerator from over filling the ice cube holding tray. Once the ice fills the tray. The ice in the bend will push up on the arm which
initiate the ice maker to stop making ice. As soon as you start using the ice in the bend and the arm falls below the off position. The ice maker will start making ice. GB....stewbison
Sep 04, 2011 | KitchenAid Superba Architect KSCS25INSS...
The ice maker isn't working any more. It was making a clicking noise and no ice would fall into tray, now there isn't even the noise.
its just cheaper to by an aftermarket ice maker and replace it as its cheaper than repairing the old unit
Jun 30, 2011 | Magic Chef CTF1826AR Top Freezer...
The Ice maker has stopped working.
There are usually 2 small solenoid valves that are used to control water. Both are generally installed at the rear close to the bottom of the fridge. One of the solenoids controls the water flow for drinks and the other is to control water flow to the ice maker. You can determine which is which by tracing the water supply tubes from the freezer compartment to the solenoid or by process of elimination. The latter method requires that you feel for movement (clicking) or heat on the water dispenser solenoid while someone starts to fill a glass with water from the fridge.
Before going any further, make sure that the ice cube detection arm in the freezer is not up. Gently push the arm down if it is. When ice cubes are ready, the ice maker turns on a small heater to break the bond of the ice cubes to the cube mold. The arm is lifted up and out of the way. Then the mechanical fingers wipe or push on the cubes to dislodge them from the ice cube mold and they fall into the container. The arm is then lowered again and rests on top of the ice collected in the container. The position of the arm when resting on the ice cubes determines whether or not any more ice cubes are made.
If the arm is hanging down, then ice cube production should be on. The problem may be either a faulty solenoid valve (mentioned above), switch in the ice maker assembly - the detection arm in particular or wiring between.
Jun 18, 2010 | Maytag MFI2568AE Side by Side French Door...
LG Refrigerator LFX24971ST - ice naker does not make ice
Arm should not be in up position unless harvest cycle is in progress. Or unless you manually put it there to cut off Ice Maker. Most likely ice maker is defective
Nov 12, 2017 | LG LFX25971ST Bottom Freezer French Door...
Ice & water dispenser get stuck, water & is keep coming out os dispenser even after you remove glass
Unplug unit
Remover dispensor housing. Careful not to break tabs.
You will see the white plastic actuator arm.
Follow the arm to where it becomes part of the main support.
Push the arm you will see where the main support is catching on a plastic *** on the rear housing.
Cut or file off part of the ***. so it wont catch.
Reassemble dispensor.
Jan 18, 2010 | LG LSC26905TT Side by Side Refrigerator
Ice cube maker just stopped working. Ice cube arm has no tension to it.
If you can find someone that will take yours apart and rebuild the components inside the front of the ice maker would be good. The problem is with older ice makers you may over look the next part to fail. Your model has a tricky spring that helps the arm lock into place. You can visit our site or call the toll free number and get free help and advice. If you can locate your refrigerator model number that will also be helpful Their numbers always look like this for example 213.54698
Click link below and give us a visit, Sea Breeze
http://servicepartstec.blogspot.com/
May 23, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Kitchen Aid indoor ice maker
hi there,
i would recommend a technician to help you with this. this part that fell out is from the motor head off the icemaker. have the technician put it back together and make sure that there is nothing else loose.
Jun 14, 2008 | KitchenAid (KSRD22FKST) Side by Side...
Ice Maker Not Making Ice
Ice maker was installed properly, when you put the arm down it doesn't call for water to fill unit. It doesn't make any kind of noises at all. The water is turned on and all plugs are in there are no kinks in the line but when the arm is truned down for it to call for water nothing happens
The is for a frigidaire refrigerator.Ice maker is all new..
Nov 01, 2007 | Frigidaire 20.6 cu. ft. Top Freezer...
Kenmore Ice Maker Problem, Side by Side Refrigerator
Thanks for the question There is a water valve just for the ice maker so the problem could be there if you have a volt meter you can check the valve what you can do to check the valve reverse the wires onthe valve and push your water dispenser if no water goes into your ice maker . you have a bad valve replace thanks for the question The appliance doc
Oct 23, 2007 | Kenmore 53603 / 53606 Stainless Steel Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
