Question about Car Audio & Video
Protection light on my car won't turn off - Car Audio & Video
  • 1,340 Answers
Try unhooking the negative terminal on the battery for about a minute this mat reset the ECM . is it a after market alarm ?
Posted on Nov 26, 2014
How to turn off airbag light?
if the air bag light is on there is a code that needs to be checked out. if you have it checked and tested for the problem the light will go out. if not and you bypass and turn off the light you won`t be protected in case of an accident.
Jul 29, 2014 | 2009 Chevrolet Impala
My Samsung UN55D7000LFXZA won't turn on just
The red flashing light has to do with what is called the protection mode.A power surge will cause that,It will have to be taken in for repair.
Oct 13, 2012 | Televison & Video
Left headlight
If the other head light works ,it won't be a fuse
Check every fuse in the car,won't take long &
the fuses will protect a complete circuit,not just
a couple head lights.
The light switch has a circuit breaker not a fuse.
Have you removed & tested the lamp it'self
No owners manual? Need that for fuses & bulbs/lamps
Sep 04, 2012 | 2001 Hyundai Sonata
My amp protection light came on one day. Now it won't turn on. What's wrong?
There is more than likely an issue with your amp, it could've happened from a wire being shorted to ground or a damaged sub causing bizarre impedance issues at your amp. Uninstal it and have it bench tested.
Jun 03, 2012 | Rockford Fosgate Power T1000-4 Amplifier
Sony HCD LX20i audio shelf sysyem won't turn on. Standby light flashing. Disc stuck in it.
Check the speaker wires for shorts, if okay! suspect the audio output ic's, the protection circuit won't come out of standby because there is a short.
May 06, 2012 | Audio Players & Recorders
The amp when i turn it on it won't work because the protection light is on
Turn it all the way down before you turn it on. If that doesn't work, carefully check all speaker connections for shorts. Beyond that might require professional service.
Nov 01, 2011 | Audio Players & Recorders
The "PROTECT" light indicator came on and now the
The protect light generally comes on when the is a short in the speaker cabling. as a test, turn on the mixer without any speakers hooked up. If it still goes into protect mode the problem is in the mixer. Take it to your local music store and have their tech look at it. if it doesn't go into protect, check the speaker cables by plugging them in one at a time. The bad one will send it into protect.
good luck
Sep 12, 2011 | Fender 150 Watt PA System
I have ablack screen and I turn the tv on and the lamp light flashes and the Temp light flashes and will not turn on No Sound and just a black screen
When the temperature light flashes then you have an overheating issue or at least the set thinks you do. It could be a bad temp sensor or as minor as the fan not working or an obstructed air path. The reason it won't come on is it is in protect mode when it senses a high temperature to protect the componenets. You will need to have the sensor check and also make sure all fans are working and there is a clear path for fresh air to cool the set.
Jun 13, 2011 | Hitachi 51F500 51" Rear Projection...
Sharp lc-22sv6u won,t power on. no green light.
Sound like the TV is in protection mode. This happens when a part goes bad inside. the TV turns OFF to protect the other parts from being damaged.
Most commonly it's a power supply related issue. A bad capacitor or transformer on the power supply board is to blame.
For a do-it-yourself fixer with electronic experience, a Service Manual is the best for trouble shooting the problem down to the bad part. Normally, you can find it over the internet for less than $20.
Jul 31, 2009 | Sharp Aquos LC-22SV6U 22 in. LCD EDTV
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
