Question about Samsung Pn42b450 42-inch 720p Plasma Hdtv as Is
How do i get hdmi back on my menu
Going to menu but there no hdmi setting
  • 29 Answers
You might try to reset the television - possibly by - with the television ON, hold down the EXIT button on the remote until you are prompted to reset (15 seconds or so). Toggle to YES and then click ENTER. That will bring it back to the last factory mode installed.
Posted on Nov 26, 2014
The Bravia menu comes up across my screen. It will go off when I hit any button on the remote; then come back on. the model # is KDL-32EX301. How do I get it to go away?
It's caused by the Bravia Sync feature. It doesn't always connect correctly. When there are issues then attempts to sync up cause the menu to appear.
The solution is to switch off Bravia Sync.
Go in to the TV's set-up menu, and choose HDMI Set-up.
Scroll down the menu list and choose Control for HDMI, then set the menu option to OFF
Let us know if that fixes the problem for you.
Sep 15, 2014 | Sony KDL32EX301 32 in. HD-Ready LCD TV
The Bravia menu comes up across my screen. It will go off when I hit any button on the remote & then come back on. the model # is KDL-32EX301. How do I get it to go away?
Sep 15, 2014 | Sony BRAVIA KDL-32EX301 32" LCD TV - 16:9...
How do you unhide the HDMI input
Assuming you hid the HDMI input in the setting menu? Go back to the setting menu and look for either inputs, or input labels. Once there, you should see a list of all the inputs and be able to choose them and then name them too!
May 27, 2014 | Televison & Video
How to connect to HDMI
newer tvs need to know that HDMI is attached to give you signal also need to turn on device from where HDMI signal comes from.post the model of your tv ,or if universal remote has input try this,1.- connect hdmi ,2.- turn on device(dvd,ps3,blue ray, etc.) 3.- press input on remote ,or go to menu manually on tv and find input.hope it works.
Dec 14, 2013 | Televison & Video
The hdmi wont work the av works I have tried all three hdmi plugs on the the tv and it says no signal could you please help everything I have is setup for hdmi
Tries tv and those cables or satalites boxes unplug,replug it back like about an hour later for those pay boxes to reboot and upgraded it softwares.Tv to do a whole resetting itself back to the factory setting.Than go into the tv Menu.Go into Video Setting,go down and do a resetting back to factory setting.By doing this steps for every components devices that hook to the tv HDMI hubs ports on the tv Tuner signal board to reboot and resetting too.Have very good chances all the HDMI hubs ports on the tv to work again.
Jun 26, 2011 | LG 42LC2D 42 in. LCD HDTV
When using hdmi outlet,,,the picture comes in for 1 second then screen turns all green
That HDMI port hub it properly shorted,tries used another HMI ports hub?Tries to reset the tv back to factory setting,by unplug,replug it an hour later,go to the tv menu go to PICTURE,go down to reset.So the Tuner board reset itself back to the factory setting,all the HDMI ports hubs,should work now or that HDMI port hub is shorted,or the Tuner board it dead.
Jun 11, 2010 | Sony KLV-S32A10 32 in. HD-Ready LCD...
My HDMI connections aren't working. How do I
Tries unplug and replug the tv back about an hour.Let the tv reset itself back to factory setting.Now go in ur menu go to PICTURE.Go down the menu pick reset,that to reset all the funsctions in the Tuner board.This process should get all the HDMI Hub. working again,not than ur Tuner board have all the HDMI Hub. are shorted and dead.
Apr 27, 2010 | JVC LT46FN97 46 in TV
Playstation 3
Have both the AV cables and hdmi cables hooked up from the tv to the ps3. On the TV Menu goto the av station which is different from the HDMi station...From the ps3 menu screen gotot settings then to video and audio and select hdmi then back to the tv menu and select the hdmi station and the ps3 main menu should be seen and you are all set
Jul 11, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
Cant see ps3 main menu
when in standby hold down the power button for over 4 seconds, it runs the optimal screen settings menu, hope this helps.
Feb 26, 2008 | Sony Playstation 3 (PS3) Console
No sound
The Philips DVP5982 has an odd menu setup for the HDMI sound.
If you get sound from the analog outputs from the unit, but no sound when you use the HDMI output, use this procedure to see if you can restore it:
On the remote control, press Setup.
- Right cursor to the Audio Setup Page
- Go down to Digital Audio Setup
-Right cursor, to get to the screen that shows
Digital Output
LPCM Output
HDMI Audio Setup
Try to go up to the Digital Output setting- if you can't , and instead it shows only HDMI Audio Setup with the "On" highlighted in blue, this is the quirk:
Go into the HDMI Audio Setup, and select "Off", and press Enter, so it's highlighted in blue.
Now it should let you go into the Digital Output menu selection, where you may find it to be on the "Off" setting.
Select "All", and then you can go back to the HDMI Audio Setup and set it to On again, and it should now output sound from the HDMI again.
For some reason, they decided to lock out the Digital Output settings menu when the HDMI Audio is On- go figure.
So you need to turn off the HDMI sound before you turn the sound on.. ;)
Jan 12, 2008 | Philips DVP5982
Samsung Pn42b450 42-inch 720p Plasma Hdtv as Is Logo
Jerry Greenberg
Jerry Greenberg
