Question about Kitchen Ranges
Kitchen Aid electric oven's (KESA907PSS02) touch pad won't work. The clock displays, but none of the buttons work. There's no error code. Thanks for any help.
  • 1,383 Answers
Once again, tuner cleaner, just give it a light spay on the display or on the bord. about a $12 fix if it oworks, nice to have around, makes u look like a magician .. jay
Posted on Nov 26, 2014
  • Julie Song Nov 26, 2014
    is that the same thing as a contact cleaner? and just spray it on the touch pad itself? is that what you mean by display and board?
  • Jay Finke
    Jay Finke Nov 26, 2014
    no, tuner cleaner is safer, contact cleaner may damage plastic, thanks for asking.. do a test .. if it melts plastic. DON'T YSE IT.
I'm getting a periodic beeping signal and an "FO" error message from my lower oven. What is it telling me? The oven is a dual electric. Model number 326B1230P001. Thanks. Stanley Hochman
Hi!! Failure Code Fault Code Description Solution F0 Stuck touch pad Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both.
Although the manual recommends to replace the touch pad, try unplugging the unit form the wall for a couple of minutes to reset it. It works most of the time.
Good Luck!! Don't forget to rate this post!!
Sep 20, 2010 | GE Profile JGSP44 Dual Fuel (Electric and...
My kitchenaid keri203 is showing E0 in orange and F2 in blue on my oven display
F2-E0 - Shorted Touch Pad (Keypad) - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!@@
Aug 30, 2010 | KitchenAid KERI203PBS Electric Kitchen...
Display shows E0 F2 after pressing start and cancel at same time. No other buttons work. Stovetop still works.
May 14, 2010 | Whirlpool GY398LXPS Electric Kitchen Range
Dispaly E0 F2
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!%!%
May 08, 2010 | Kenmore 95822 / 95824 / 95829 Electric...
Oven is displaying f1-8 error code what is it
F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3 or F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components.
May 04, 2010 | Jenn-Air SVE47100 Slide-In Electric...
I have a maytag MER6772 Gemini Electric Rage it gave the F1-2 code. What must I do to Fix This Problem?
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
Display Condition Remedy
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 16, 2010 | Maytag MER6772 Gemini Electric Kitchen...
Electric Range.-oven stopped working. Error Code F1 show on electronic display
Hello there:
Here is the 2 most common f1 codes for this oven and what the problem is and what repair procedures that should be taken
F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad) F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC)
Dec 13, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
Whirpool model# RF385PXGN (electric) error code F2 E0 The failure/error display codes says replace control. What is control ?
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Jul 28, 2009 | Amana ARGS7650SS Gas Kitchen Range
Constant beeping and F7 is displayed
Hi tahitian,
The error code F7 means that the Function key is shorted or stuck. To fix this error, replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
Hope it helps.
Thank you for using FixYa.
Dec 16, 2008 | Magic Chef 31000 Gas Kitchen Range
Kitchenaid Oven won't work E0 F2 on the control pad
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!@#$
Jul 24, 2008 | KitchenAid KESC307 Electric Kitchen Range
Kitchen Ranges Logo
57 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
