Question about Panasonic Office Equipment & Supplies
What i do for film slack and change film
Please reply me as soon as possible.
    Sergeant:
  • 233 Answers
Many of these have tensioning devices built in to rid slack. You may try to remove the cartridge and tension (turning little by little) to try and remove slack or remove and reinsert to see if the machine will auto tension it.
Posted on Nov 26, 2014
How much is a fuser
contact the manufacturer .
Sep 12, 2016 | Office Equipment & Supplies
My pentax k1000 works great except for when I first load the film. Every time I first load the film, the rewind knob wont rotate when I snap pictures. Everything on the inside is intact and usually I have...
I'm not sure I see a problem here. There is enough slack in the film that the first few exposures can spool out of the canister without it turning. If in doubt, close the back and then _lightly_ turn the rewind crank to take up the slack. Don't force it, just turn it until you feel resistance. Then advance the film and see whether the rewind knob turns.
Feb 28, 2011 | Pentax K1000 35mm SLR Camera
Hi there could you please tell me if i can get analogue channels on a bush A series A6 32inch lcd tv.Could you please reply as soon as possible please many thanks Steven.
If there are any analog channels and its tuner is ATSC only get an older VCR and hook it up AV jacks Change channels with it .There dirt cheap flea markets etc.
Oct 23, 2010 | Televison & Video
How do i open the back door
You lift the rewind crank as per almost all other SLR's but there is a safety lock around the base of the crank which you must slide rearwards (counter clockwise) first.
Make sure that you have fully rewound the film before opening the camera.
Please take a moment to rate my answer if it has assisted you, if you need further assistance with this problem then add a comment instead and I will reply as soon as possible with further help.
Oct 05, 2010 | Nikon FE 35mm SLR Camera
Check Film and Cover Open: KX-FPC95
Check for slack in film between supply and take-up rollers. Manually advance take-up roller to remove slack before closing cover.
Dec 18, 2009 | Panasonic KX-FPC95 Plain Paper Thermal...
Hp l7580
Hi, it sounds like a faulty ink cartridge. Try changing the black cartridge and see if this helps
Dec 16, 2008 | HP OfficeJet Pro L7580 Color All-in-One...
Panosonic KX FP342 (fax)
The film cartridge can be purchased at almost any office supply store like Staples, Office Max, Office Depot, online and even Ebay.
IF there is film still left, make sure that the tension of the film is tight where there isn't any slack. If there is too much slack, or you are at the end of the roll, then you will get that message on your machine. One thing you can try is to roll the film backwards. There is a supply roll, and a take up roll. Just take the cartridge out and spin the roll the opposite way for about 5 feet or so. Then place the cartridge back in and see if it works. If it works then all you need to do is buy a new cartridge.
Hope this helps.
Good luck
Feb 08, 2008 | Panasonic KX-FHD331 Plain Paper Thermal...
Canon Error Eoo7
This error code indicates to the copier that the upper fixing film on the fuser assy is not rotating. Paper wrapped around the fixing film or the film itself is damaged may cause this. Unless you are very mechanically inclined , it will take the removal of the fixing assy and possibly the replacing of the fixing film assy. A tech would need to be called in to correct the problem. The fixing film is a replaceable item. Good luck.
Sep 26, 2007 | Canon imageRUNNER 8500 Copier
Tape Ejects Immediately
There are normally 2 causes. One is some obstruction in the tape path. Please open the cover of the VCR and shake and see for foriegn objects. Nothing??? Then there is one more possibility - Belts are loose.. Check the Tape Loading motor belt.Is it slack? This can happen over time.Change the belt.
Feb 04, 2007 | Panasonic NV-HD680 VCR
81 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
