Question about Cell Phones
My Sony Xperia L flash light not working.I did factory reset buthe still not working.
    Sergeant:
  • 233 Answers
Have you tried to take a picture with the camera and use flash? If this works then the fault is in the application, if not the flash for the camera is faulty and not much can be done aside from replacing the camera inside or the phone. If flash with camera works, then try to reinstall the flashlight app.
Posted on Nov 26, 2014
2 Suggested Answers
SOURCE: How do I reset my Sony Xperia if I can't unlocked
Try reset code from service provider....
Posted on Dec 09, 2011
How do i format my xperia?
Hi Laila,
To factory reset your phone you will need to do the following:
Press and hold Camera key + volume up key+ power button together
The phone will format itself to factory default, if this does not work then you will need to navigate to:
Setting -> Privacy -> Factory data reset -> Reset phone -> Erase everything.
Please let me know if this helps,
Thanks,
Hunter Quinn
IBM Technician
Jul 15, 2014 | Sony Ericsson Sony Xperia Sola Red, 8gb,...
Sony xperia t troubleshooting
restore settings
or this one note all data will be deleted
How to Soft Reset or Reboot or Restart SONY XPERIA T LT30p ?
To soft reset SONY XPERIA T LT30p, press the POWER BUTTON KEY for several seconds, we will see the menu to restart or turn off. Choose restart/reboot than the SONY XPERIA T LT30p will do the soft reset or restart. This is safe to do because non of important data or applications will wipe or erase.
#Option 1, Hard Reset SONY XPERIA T LT30p with Software Menu :
  1. Make sure the battery is charge properly
  2. Turn on SONY XPERIA T LT30p smartphone
  3. Don't forget to backup all important data
  4. Go to menu: Setting > Backup & reset > Factory Data Reset > Erase internal storage > Reset Phone
  5. Choose Erase everything to continue and confirm you ready to do the format SONY XPERIA T LT30p
  6. The SONY XPERIA T LT30p will continue the step until ready to use in clean factory default.
#Option 2, Hard Reset SONY XPERIA T LT30p with Flashtool applications:
  1. Flashtool in the applications from Sony can be download from Sony website.
  2. Flashtool software need to installed in you computer and ready with USB data cable
  3. Make sure SONY XPERIA T LT30p battery is charge properly or full charge
  4. Power off SONY XPERIA T LT30p
  5. Boot SONY XPERIA T LT30p to flashmode with using: Volume Down Button and connect to USB cable at No.1 above
  6. Follow the menu at you computer display, it is easy to understand the steps.
#Option 3, Hard Reset SONY XPERIA T LT30p with Hardware Key Button:
  1. Make sure the battery fully charge
  2. Do not forget to backup all important data
  3. Turn off the SONY XPERIA T LT30p
  4. Press and Hold together: Power Button + Volume Up Button for several seconds
  5. Follow the menu at LCD screen to continue the hard reset SONY XPERIA T LT30p
You can choose the step options above to do hard reset while the SONY XPERIA T LT30p get problem or not running well. But we always suggest to do routine backup before your smartphone get problem. If SONY XPERIA T LT30p already stuck or run slowly or not responsive, then better try to do backup as you can because all important applications will be wipe or removed from SONY XPERIA T LT30p after doing master reset, but some data which saved at memory card will be safe, better to remove the microsd memory card before doing the hard reset.
Jun 16, 2014 | Cell Phones
How to nulock sony xperia s lt26i
solution 1, Hard Reset SONY XPERIA S LT26i with Software Menu :
  2. Turn on SONY XPERIA S smartphone
  4. Go to menu: Setting > Backup & Reset > Factory Data Reset > Reset Phone
  5. Choose Erase everything to continue and confirm you ready to do the format SONY XPERIA S
  6. The SONY XPERIA S will continue the step until ready to use in clean factory default.
solution 2, Hard Reset SONY XPERIA S LT26i with Flashtool applications:
  3. Make sure SONY XPERIA S battery is charge properly or full charge
  4. Power off SONY XPERIA S
  5. Boot SONY XPERIA S to flashmode with using: Volume Down Button and connect to USB cable at No.1 above
solution 3, Hard Reset SONY XPERIA S LT26i with Hardware Key Button:
  3. Turn off the SONY XPERIA S
  5. Follow the menu at LCD screen to continue the hard reset SONY XPERIA S
Be careful before doing this step to master reset, because all important data and applications will be removed from SONY XPERIA S, we always suggest you backup all important data before performing the hard reset.
Dec 19, 2013 | Sony Ericsson XPERIA S LT26I Nozomi Arc HD
Need to reset sony ericsson xperia 10x cell phone
The Sony Ericsson Xperia X10 is highly customizable and you have been hard at work tweaking it to your liking, but now the fun is over and you want to return it to its factory settings again.
Here, we show you how to hard reset the Sony Ericsson Xperia X10 with step by step instructions.
Please note that all data will be deleted from the Sony Ericsson Xperia X10 as a result of this procedure. This process may or may not delete data stored on the microSD card. We recommend backing up all of your personal data before proceeding.
First, try this:
1. From the main home screen, tap menu
2. Tap Settings, then SD card & phone storage
3. Tap Factory data reset
4. Tap Reset phone
5. Enter your password, then tap Erase everything to confirm
If that doesn't work, or if your phone is frozen:
1. Turn the power off. If your Sony Ericsson Xperia X10 is frozen, pull the battery out and reinsert it
2. Hold the Left and right buttons located beneath the display
3. Press and release the Power button
4. Follow the on-screen instructions to hard reset your Xperia X10
All data including third-party applications will be deleted from the Sony Ericsson Xperia X10. Once the wipe is complete, the phone will reboot to its factory fresh state.
Regards.
Aug 08, 2011 | Sony Ericsson Cell Phones
I can't start my phone and need to doo a complete reset. How can i do it? Thanks Regards
How to hard reset the Sony Ericsson Xperia X8First, try this:
  2. Tap Settings, then Privacy
  4. Tap Reset phone
  5. Enter your password if required, then tap Erase everything to confirm
All data including third-party applications will be deleted from the Sony Ericsson Xperia X8. Once the wipe is complete, the phone will reboot to its factory fresh state.
Jun 18, 2011 | Sony Ericsson XPERIA X8 Cell Phone
I cannot send text messages from my sony ericsson vivaz u5i, but i can recieve text messages, incoming calls and i can make outgoing calls.. what is the factory setting code so i can reset my phone?
First, try this:
  4. Tap Reset phone
The password is user defined, try the second method if you did not set a password.
Good Luck!
Jun 16, 2011 | Sony Ericsson XPERIA X8 Cell Phone
Hello. I tried to reset my new Sony Ericsson Xperia X10 in line with he user guide. I went from Settings to SD Card & Phone storage settings, but from there I cant find the 'Factory data Reset' option...
1 From the Xperia 10 Home screen, tap the applications bar.
2 Tap Settings > SD card & phone storage > Factory data reset > Reset phone.
3 Enter your screen unlock pattern.
4 Tap Erase everything.
Done! Now, You can reset your Xperia X10 to its factory default settings.
Mar 25, 2011 | Sony Ericsson XPERIA X10 Cell Phone
I can't remember my gmail account information and I am locked out of my xperia phone from too many pattern attempts. No combination I try will work.
Try to enter password as null. If didnt worked means do a hard reset . You will get factory settings enabled after resetting.
Mar 06, 2011 | Sony Ericsson XPERIA X10 Cell Phone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
