Question about Brookstone Pure Ion Advanced Air Purifier Cleaner Ionizer 506840
Find out the electronic circuit voltage
I used a 120 50hz transformer and I think I burned up the power sully coil. I checked the circuit board and didnt see any burned circuits
    Sergeant:
  • 210 Answers
I am an electrical engineer and I do not fully understand your question. If the unit is designed to operate on 50/60 Hz, it cannot be damaged by operating it at either of those line frequencies. Mnay products today will operate at either line frequency.However, if you used an adjustable voltage power transformer (a.k.a. "Variac"), you may have "under-voltaged" or "over-voltaged" the device. If there is a circuit breaker, try resetting it. Otherwise, there may be a circuit board-mounted fuse internally that is now electrically "open." That can be tested with an Ohmmeter for continuity. (Finding a replacement may prove difficult.)
Operating a line-powered device above or below its input limitations can permanently damage internal power supply functions and, perhaps, other circuitry as well.
Solid state components can fail "open" or "shorted." If they fail "open" they will not draw appreciable current to "burn" them in any obvious way.
Posted on Nov 26, 2014
I cleaned my io breeze quadra plates with rubbing alcohol reinserted and turned it on, it made some crackling noises and started emmiting a burning smell like a hot transformer pulled insert plates found...
You will need to take unit apart to check both the and bottom. Start either at top or bottom go over the circuit path of hi voltage grid wire check for more burn marks. Insure hi voltage insulated wire coming from transformer is not broken. This will be located at bottom of unit you will have to take top pc board off and control transformer to get to hi voltage transformer, then when that is removed you will see the hi voltage connector I was talking about. That wire is soldered on and is a very delicate connection. Make sure wiring soldered. Hi voltage transformer should be ok if you did not leave unit on for a long time while you had your loose connection in the grid wire.
Dec 14, 2010 | Sharper Image Professional Plus Ionic...
My Flair stopped working correctly,so I purchased new Ozone plates. It still doesn't provide that clean ozone smell. I took mine apart and cleaned it and noticed a small bulb inside that doesn't light up....
pull the unit out of the enclouser and check the bottom for a circuit board and on the board their is a glass fuse see if it is blown. Also on that same board their is a small round black fuse that is labled f21 it is a 400ma 250 volt fuse on my unit and is soildered in this fuse is just for the ozone
May 23, 2010 | Ecoquest Flair Air Purifier
My Flair smells like it is burning and the plates are making a loud sparking sound
What's burning is probably your high voltage transformer. When your glass plates get a crack in them, they will spark. You probably have a burned out high voltage transformer. That's what produces the ozone. Helpful hint...........the high voltage transformer is also the one used in bug zappers
May 01, 2010 | Ecoquest Flair Air Purifier
Green light is on, fan is blowing but we know longer smell the ozone from it; we have just changed the plate & cleaned it?
Apr 18, 2010 | Ecoquest Living Air Classic Air Purifier
Ozone not working
Mar 24, 2010 | Ecoquest Fresh Air Air Purifier
Light wont come on. Purifier wont work
When the high voltage transformer is working right, it will make the neon bulb glow.
Mar 14, 2010 | Ecoquest Flair Air Purifier
Light doesn't come on, does not purify the air.fan runs
If the little orange neon light no longer comes on, it is a problem with the high voltage board and transformer. The board sits on top between the plates and the fan.
In my instance, the board had become corroded and shorted the terminals of the voltage regulator located on the board. Also, the ground strap around the ferrite core of the high voltage transformer had become corroded an needed replacement. Also, check the circuit paths from the nearest components to the Voltage Regulator pads. Mine blew one of the circuit traces.
All in all, I replaced the Voltage Regulator, Mouser P/N: 595-UA78L12ACLPE3, Transistor P/N: 512-2N4403BU, Timer IC P/N: 595-NE555P.
The voltage regulator feeds the latter two, as well as the high voltage transformer, I replaced those components as a precautionary measure.
The terminals do get corroded, so check those as well. There are no terminals on the high voltage board other than on top of the proprietary potted black box that feeds the target and neon light. Be careful with the terminal on that box because it breaks easy once corroded. As mine did.
Those components fixed my problem with the high voltage board and no neon light.
Hope this helps, let me know if you have any other questions.
Sep 19, 2009 | Ecoquest Flair Air Purifier
My flair works o.k. except the santinizer doesen't work. I have one ozone plates that is broke on the corner of the plates and there is a black line running through it. Could this be the problem?
The ozone plate will not cause the sanitizer button to not work but it may have caused the button to short out. The sanitizer switch probably needs to be replaced. The plate definitely needs replacing, when there is a crack in the plate it causes an electrical arc which is burning the black line onto the plate. Please remove and throw away that plate.
Jun 07, 2009 | Ecoquest Flair Air Purifier
Brookstone Pure Ion Advanced Air Purifier Cleaner Ionizer 506840 Logo
Top Brookstone Air Purifiers Experts
Are you a Brookstone Air Purifier Expert? Answer questions, earn points and help others
