Decarbonising method - Computers & Internet
    Sergeant:
  • 216 Answers
Introducing a water spray continually into a running engine's air intake will decarbonize cylinder head, given enough time. You will struggle to keep the engine running but if you ar epatient, it can be done.
It is commonly known that a defective cylinder head gasket that leaks engine coolant into a cylinder will clean that cylinder head and piston to "like new" condition.
Some performance engine enthusiasts incorporate "water injection" systems to generate more horsepower. Water flashing into steam increases cylinder pressures and, therefore, engine torque and the cylinders get "steam cleaned" in the process, which helps removes carbon deposits.
Posted on Nov 26, 2014
2003 diesel landcruiser manual after towing heavy load up hills I stopped engine and started upagain after 2 hrs she was blowing white smoke no loss of power and coolant level and oil the same towed same...
white exhaust smoke indicates usually unburn fuel, it can be either, problem with gunky injectors, wrong timing or problem with valves, non-sealing pistons or glaze on the cylinders
I am usually recommending in cases like that use of any decarboniser add to the fuel (removes glaze from cylinder and help therefore seal), and then use some injector cleaner.
in your case - you were using too high gear and hence the glazing on the cylinder - if you did not have these problem before.
for future references, I would suggest towing in that condition on all four drive, and forget about fifth gear...
add injector cleaner first, and at next re-fuel add decarboniser.
hope this will help you at least a bit - do not forget to vote...
Mar 22, 2015 | Toyota LandCruiser Cars & Trucks
How to de-carbonize a motorcycle engine@
Hi, Anonymous for more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Decarbonizing 4 Stroke Motorcycle Engines Is It Really Required
Decarbonise Honda Wave
Decarbon bike engine using water
How to Decarbonize 4 Cycle Engine
Decarbonise Motorcycle Modenas Kriss
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jan 22, 2013 | Honda Motorcycles
How to de-carbonize a Honda motorcycle engine@
Engine Decarbonising Demystified Team BHP
Decarbonizing 2 Stroke Engine
1987 oldsmobile 98, I replaced the battery and the car still won't start ?
maybe the points need adjusting or check the exhaust at rear and see what tis colour black inside...... may need decarbonising.
Jan 15, 2013 | Cars & Trucks
Hello, I have a Honda XR250 1990 (europe) Black smoke and licht noise in cilinder, what to do ? Thankx zegersjulien@hotmail.com
Did you ever done Decarb for your Motor Cycle ? It is recommended to do a Decarbonisation of Cylinder Head and Replace the liner every 30000 - 40000 Kms .
Black Smoke Can be Because of
1. Damaged Cylinder Liner 2. Dirty Cylinder Head 3. improper Combustion 4. Fuel problems 5. Fuel Pump / Carburetter Problems
need Physical Examination Foe a definite Solution
Please Rate my answer and Support me
Nov 21, 2010 | 1990 Honda XR 250 R
Toyota 4Y engine Makes a Taping noise and and black smoke comes from the ex-oust Pipe? How can I solve this problem?
Time for a good check up, the black smoke is a good indication of a faulty fuel pump or fuel calibration/setting.
I would advice that it needs a good tuning up of the fuel and timing , or even decarbonising of the head/ exhaust.
the tapping noise can be the tappets. the clearance being high, which will be adjusted in the tuning.
So check this out
Aug 31, 2010 | 1985 Toyota Pickup
50cc 1999 derbi senda
Hi
Decarbonise the exhaust system.
Regards
Phillip
Oct 16, 2009 | Derbi Senda SM 125 4T Motorcycles
Black smoke coming from tailpipe when i excelrate
HI,
First your silencer needs to be decarbonised.
Second the quality of gas may not be good.
If problem still exists get your air fiters/carborater cleaned up.
Hope your problem is solved.
Thanks
Kanu
Oct 13, 2009 | 2003 Kia Sorento
Is decarbonising is necessary
Hi! With modern fuels and oils there really shouldn't be any need to de-carbonise.(Unlees Mixture is incorrect?) If you are really concerned then try a quality fuel additive, read fully the directions for use and Bingo job's a good-un.
Fork oil change, is there a reason? are the forks weak? any seapage? if not leave well alone as you may open a Hornets Nest.
Telescopic forks/dampers use very light oil for suspension, too much will blow oil seals, so if you are determined to change the fluid then make sure the correct viscosity is used and critically the correct amount/quantity. Cleanliness is of the utmost!
Good Luck!
Paul 'W'
Onyer~EDson(:0)~[><
Dec 09, 2008 | 2005 Honda Unicorn
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
