Question about Copystar CS-1815 Printer
My copystar cs 1815 is printing low on one side?
I just had the tonner refill and then i notice.. i also clean the roller inside the drum then i notice one side of the printing pages really low.
  • Dave Ayre
    Dave Ayre Nov 26, 2014
    Hi ruben morales, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? 1/ Was the copy good before you replaced toner cart? 2/ Did you remove the process unit?
  • 3,866 Answers
The feeder assembly must be out of adjustment this is most likely at the drum. 85 bucks just in parts. Labor would depend on whom you choose to have it repaired with.
Posted on Nov 26, 2014
FixinFax
  • 3085 Answers
SOURCE: Copystar CS1510 Error E70
Your fuser needs to be replaced
Posted on Apr 29, 2010
krizanto81
  • 65 Answers
SOURCE: how to put an IP address on the CopyStar CS-1820 printer
putting an ip to 1820, just go to system menu, scroll down look for the network setting, you will find ip address, then fill it up.
Posted on Jun 27, 2009
maklean
  • 1665 Answers
SOURCE: C710 Code on Copystar 2030
Did you disconnect telephone line?
C710 : Interrupted Communication at the Destination.
If you're the sender, it's happening outside your machine.
Most likely, phone line
Posted on Feb 20, 2008
  • 215 Answers
SOURCE: Copystar cs-2550 drum replacement problems
ok. try this, take the rear cover off, theres quite a few screws. what i'm thinking has happened is you may have pushed the contact for the main corona wire out of place. this board is pretty flimsy. once you have back cover off, the board will be slightly to the right of center as u r looking at machine from rear. i can't recall EXACTLY what board looks like, but if you loosen your drum unit and have someone pull out drum a little and push back in, you will see what and where i am talking about. i'm a tech and had this bite me in the behind one time. will never forget it. hopefully, that will take care of it for you. let me know what you find.
good luck,
razors
Posted on Mar 30, 2009
SOURCE: Copystar CS-1815 waste toner
There are two screws on the drum unit. They are on the left hand side and one on the right hand side. Remove the screw from one side and take off plastic small side cover. Dump the waste toner. Do the same for the other side and then put it back together. Turn machine off then on and the error code should be gone......
Posted on Aug 06, 2009
Getting a error message JAM11 on copier CS-1815?
A paper jam in the
paper feed section
is indicated during
copying or printing
(no paper feed from
the cassette).
Jam code 11
Paper in the cassette is
extremely curled.
Check if the feed roller is
deformed.
Defective registration sensor.
Check if the feed clutch
malfunctions.
Electrical problem with the
feed clutch
The above is taken from the sm
Also the feed tyre needs cleaned / changing and or cassette springs need stretching !!!
Dec 03, 2013 | Copystar CS-1815 Printer
My kyocera copystar CS-1815 shows in the message screen "Waste toner near full." How do I empty the waste toner?
Hi there just open it up and inside there will be a small plass bottle that hold the waste toner you can clean out and put back.
Mar 04, 2010 | Copystar CS-1815 Printer
Copystar CS-1815 reports a paper jam at the document processor
Check for debirs in the unit that could be tripping the jam sensor if not the sensor has gone bad.
Apr 23, 2009 | Copystar CS-1815 Printer
I need help to install my copystar cs-1815
Its very easy let me know wat you want to do or if you want to send you the manual.
Apr 19, 2009 | Copystar CS-1815 Printer
Copystar cd-2550 copier , drum replacment print problems
hi
the drum unit on this model has two plugs which need to be plugged in and one on the dev unit that can come loose.
also the metal mechanism under the dev unit has to be pushed in to enable toner to get onto the drum.
is the transfer roller fitted correctly?
Mar 26, 2009 | Kyocera Copystar CS-1820 Black and White...
Copystar 1815 problem!
Are you getting black or white lines on your copies when you use the adf? When you lift the adf up and look at the copy board glass for any dirt, next look at the small piece of glass next to it. The white out is on that part or the copyboard glass. Clean it off and you should be good to go. You would get paper jams if the white out is on the rollers. If you want to clean them use a rag with very little WD-40 on it and lightly rub the white out off. Yes, I did say WD-40, it is not just for squicks... Good Luck
Jan 30, 2009 | Copystar CS-1815 Digital Copier 042DD512
Apr 17, 2008 | Copystar CS-1815 Printer
Black Lines and Very Harsh noise on a new Tonner. No printing with New tonner
Those printer tonners are very tricky to refill and a bad refill induse on bad printing so you can clean the drum (the round green thing) with isopropilic alchool. If it continues it indicates that the blade ( inside tonner plastic blade that cleans the excess tonner powder) is durty and you can clean it too with the same alchool. If it continues replace the tonner cartridge.
Feb 12, 2008 | Samsung ML 1710 Laser Printer
Copystar CS-1815 Printer Logo
55 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Tammie Duggan
Tammie Duggan
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
