Question about Sewing Machines
Husqvarna Prisma 990.Problem with additional - Sewing Machines
Husqvarna Prisma 990.Problem with additional threads on the lower side after sewing.See photo attached. Please help. Thank you
    Problem Solver:
  • 15 Answers
You will need to take the bobbin case out then pull the hook out. I believe there are 4 screws that hold the hook in. It sounds like you have some thread stuck in maybe behind the hook. If there isn't any thread look closely at the hook and you will probably find a burr where the needle hit the hook and it is catching the thread. If you find a place on the hook that is catching the thread you can use a little piece of sand paper then use some clear finger nail polish to smooth it out. That should take care of your problem
Posted on Nov 26, 2014
  • Hiew Nov 26, 2014
    Done what had been suggested.problem still the same. Additional set of thread at the bottom.
  • 201 Answers
SOURCE: Husqvarna bobbin thread jamming
Make sure the bobbin thread "clicks" into the tension slot. However, thread nests underneath are usually caused by the top thread, not the bobbin. Make sure your thread is seating itself in the top tension disks. To do this, put the spool on the machine, pull off about 12 or 15 inches of thread, then hold this thread down with one finger on your right hand as you take the thread tail through the threading path with your left hand. When you get to the needle, tug the thread (still holding it down up top) to be sure it seats in the tensions disks. You must also have the presser foot UP while you do this to ensure that the tension disks are open. Watch the first thread guide after the spool as you sew to make sure the thread is not jumping out of there (a common problem with Des1 machines, fixed with SEs - no comfort to you and me!). I have put a small piece of tape across there with the end turned back on itself so no sticky bit is going to catch on the thread.
Posted on Mar 21, 2009
  • 87 Answers
SOURCE: Threading a husqvarna viking 3610
This should be your machine:
http://www.sewingmanuals.com/Viking_Pics/Viking_3610i1.jpg
Sewingmanuals.com shows that they have this downloadable in Adobe PDF format here:
http://www.sewingmanuals.com/Sewing_Machine_Manuals/Viking.htm
#37 in the list as of me posting this. You can get a CD version too but you'll just pay more and wait longer for the same thing. Once you have it print the manual (preferably both sides to keep it small) ang you'll have it. You can also peruse eBay to see if anyone is selling a manual but I doubt that will yield regular results. The machine looks to be pretty basic and standard but it's best you have the manual to get the most out of the machine. Also be sure to check the cleaning and lubrication section and go through the process so that the machine is in top working order before you put it into regular use - saves a lot of headaches.
Posted on Apr 28, 2008
kent581
  • 87 Answers
SOURCE: Husqvarna Prisma 980 decorative stitch cassettes don't work
On that machine, the cassettes aren't actually computer chips. Each cassette has a little spot of white on a certain little area you must find (top right I'm pretty sure). Look in the machine at that point. There is a sensor that looks for that white spot, and as it identifies it, it changes stitches according to that cassette. Either the sensor is blocked, gone bad, or you can put a fresh coat of white paint on with white out. I hope this helps.
Kent
Posted on Mar 23, 2009
  • 371 Answers
SOURCE: How to thread my sewing machine? Husqvarna Classica 95
Suggest you contact an authorized Husqvarna Viking dealer. They can order you a user manual. Authorized dealers can be found at the Husqvarna Viking website - http://www.husqvarnaviking.com/us
Brief description of probably how to thread from looking at a picture of a Classica 90 machine which should be similar -
Thread sits on spindle on backside. Pull thread straight across to upper left backside and fit in the metal guide. It should pull easily with only a little resistance. Pull thread forward across top toward you. Let thread fall between the metal disks (doesn't matter which one if more than one) and pull thread straight down. Pull thread slightly to the left to fit under a hook of some type and back up to fit through the large hook that moves up and down when the handwheel is turned. Come straight back down to needle and thread through eye of the needle. Just above the needle should be a thread guide (sideways hooking looking metal piece), slip the thread through it to hold thread close to needle. Hope this helps. Otherwise a local authorized Husqvarna Viking dealer will be glad to help you. Good luck.
Posted on Sep 25, 2009
  • 152 Answers
SOURCE: Sewing thick fabric and machine won't send it through
Sergers are not really meant to sew very thick material. The blades have a maximum amount of range, or thickness that they can reach to cut. If you go outside that range, get ready for a big repair bill! You can break loopers and even the needle plate when you "push" a serger. My advise would be to use you sewing machine for the, "pounding" work. The type of material matters too, A thick Quilt like fabric can be sewn becatuse it's not dense material. A thinner harder denim could max out at 3 layers because of it"s hard finish. If the fabric you're sewing isn't dense like, you could just need new knives.
Posted on Oct 14, 2009
My Husqvarna Prisma 990 does not stitch. I've re-threaded, checked the tensions, replaced the needle, checked the feed switch, and changed the bobbin. The machine runs and acts like it is stitching, BUT...
check the needle /hook timing
the hook should be at the needle just above the eye of the needle when the needle is fully down
take it to a service centre for adjustment and service.
Jul 06, 2015 | Husqvarna Sewing Machines
Hi , I bought a Husqvarna Prisma 990 , but I don't have the part on the right side (front) that can be used for different stitches , where could I get it ? Also , can the machine work without it ?
check with a Husqvarna dealer or a sewing machine shop in your area, and you can even try ebay,, sewvacdoctor.com, a1sewingmachines.com and see if they can help you.. as far a saying if the machine will sew with out it,, I really can't say for sure..
Dec 16, 2014 | Husqvarna Sewing Machines
Can you tell me the bulb specs on Prisma 990 opto-coupler bulb NO.411 83 87-02? It is no longer availlable and Husqvarna Viking said they can't give me the information other than the number and that it is...
try to find a very old sewing machine dealer or a family dealer - you would be amazed what you find in these old stores. just have the patience to go from one to another until you find something!
Jul 13, 2014 | Husqvarna Viking 1
could be something wrong with a part or a cam. if the machine keeps doing the same problem, it would be a good idea to have it checked.
Apr 05, 2014 | Sewing Machines
Feed Dogs wont move fabric on a Viking Prisma 990
the feed dogs need to be checked, they may need some type of adjustment.
May 03, 2013 | Sewing Machines
Is it possible to buy a handwheel for Husqvarna Prisma 990?
check with sewingpartsonline.com & see if they have one
if not check with a husqvarna dealer for one
Jun 07, 2012 | Sewing Machines
Hi, I own a Husqvarna Prisma 940. It has always
I will help you,
Pls give the Model number of your sewing machine.
Jan 09, 2011 | Husqvarna Huskystar 207 Sewing Machine
It is a Husqvarna Prisma 990 S, I got it handed down to me but no mannual. Dose anyone know where I can buy a mannual?
If you call 1-800-474-6437 Husqvarna can possibly make you a photo copy of the instruction book
Sep 11, 2009 | Husqvarna Huskylock Computerized 905
Problems with lower thread tension
Did you bend the throat plate? I have done that and it was a nightmare. I took it off and gently hit it from the backside with a towel over it to bend it back the way it was. It worked fine.
Jun 15, 2009 | Husqvarna Viking 1
Sewing Machines Logo
61 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
