Question about Building Materials
I have roller door opener merlin430R. I can not find learn button!!! Is not the one with the green cover.... I have only 1 red button on 1 side that opens and close the door.. under lamp cover I can not find it still.... PLEASE HELP. .
This is with the green cover (button) .I don't have it! I have only 1 square red button that opens -closes the door.
Posted on Nov 26, 2014
    Problem Solver:
  • 26 Answers
Look at this video, it should answer your question. The learn button in under the green button. Remove the green button.
http://www.youtube.com/watch?v=7CqMy2UfG9k
Car garrage door opener
smart or learn button is located on the back of the garage door opener. (the machine that is over your head) on most units such as liftmaster, craftsman, chamberlin. its on back or side by the light bulb and is green, yellow, orange/red, purple. genie units are black button behind light cover. or external on old units. push and hold your cars homelink button will blink slow, at the same time push and hold the remote for the garage door. led light in car will blink fast. let both go. now go to the garage door head unit, (overhead) and push the learn button. button will blink and you have 30 sec. to go to car and push the cars garage door button. head unit should flash its light, letting you know that it is programed succesfully. genie units push 3 times
Dec 10, 2013 | Building Materials
A friend has a Genie model H6000A garage door opener. The previous owners don't have a remote and I cannot find either a smart button or the little tags to toggle. Please help!
they'll need a new Genie Master Remote for that opener, and the learn button should be under the light cover on the right hand side. You should be able to see a red light near it.
Sep 15, 2013 | Building Materials
GT3-R -can
This is a dual frequency transmitter. (315/390) You need to select one button to program the TYPE 1 frequency of 390 MHz. Here's how:
Backwards compatable programming instructions for GT3-R dual-band remote: This is a 3 button remote, which can be used to operate up to 3 garage doors using IntelliCode radio controls. This remote is defaulted to operate the new IntelliCode 2 Genie garage door openers, but you can also program individual buttons to operate other IntelliCode 1 (pre 2011) models of Genie garage door openers made from 1998 to present. To change a button to operate a pre 2011 IntelliCode opener, the default IntelliCode 2 setting must be changed to IntelliCode 1. An LED light on the remote displays which mode the remote button is in: Red = IntelliCode 1 / Green = IntelliCode 2 To set one of the 3 buttons to be IntelliCode 1 (red), follow the instructions below:
  1. Select a button on the remote that has not been programmed.
  2. Press and hold that button for 10 seconds. Both Red and Green LEDs come on and stay on.
  3. Press the same button twice to toggle IntelliCode selection from IntelliCode 2 to IntelliCode 1.
  4. Press the same button again to confirm toggle. the LED should be Red. The IntelliCode selection for this button is set to IntelliCode 1.
You are now ready to program the remote to your garage door. Follow accompanying instructions for "Programming to IntelliCode 1 Genie garage door opener," or see below instructions: Programming Instructions: Gently press the Receiver Learn Code button on the power head receiver of your Genie garage door opener (motor head on ceiling in garage). This small, black, unmarked button is located behind the light lens at the motor head and is nearest the floppy 6 inch antenna wire that protrudes from the motor head. When pressed, a radio signal indicator light will start blinking red for 30 seconds. After pressing the Learn Code Button, press your transmitter button twice for your system to grab the frequency and code it in. (Keep the transmitter you're tuning at least 2 feet away from the power head while tuning.) Press the transmitter button once more to test the system and start your door moving.
Jan 06, 2012 | Video Game Consoles & Games
I have a Merlin Powerlift model 430R roller door. The battery went flat in the remote and I replaced it. Now the door will not work via the remote.Works ok from red button on unit. I have tried to reset...
If the LED is flashing rapidly when the button on the remote is not pressed you have interference from something. Check for old remotes stored in a drawer somewhere or some new electric item nearby. Start unplugging things until that rapid flashing stops.
Apr 24, 2011 | Sears Craftsman LiftMaster Chamberlain...
Replaced battery and now remote doesn't work, do I have to reset the remote.
Yes. If the battery runs out, or you loose power to the opener for a period of time, you will have to reprogram the remote.
On the back of the opener motor you will find a 'learn button'. It may be under the plastic light cover, or in plain sight. It will either be green, orange, purple, or red. When you press the button an LED light just above the learn button will come on. Hold the remote near the opener and hold down the remote button. You should see the lights blink on and off a few times.
Try the remote. If this doesn't work try it again.
Good Luck!
Also, don't forget to check the balance of your garage door. This and other garage door maintenance tips can be found at www.spokanegaragerepair.com/tips_tricks.htm
Mar 07, 2011 | Chamberlain Liftmaster 81lm Remote...
I have a Merlin powerlift-model 2500L Garage door and cannot find the Learn Button to program my new remote. Please help...
This is a foreign design but here is what the instructions say to do.
Remove the light cover then remove the colored plastic rectangle strip located underneath. This will reveal a red Learn/Delete? button. 1. Push Learn/Delete button for 2 seconds the lamp will blink continuously to alert you that it is in Learn Mode. 2. Push the big button on your remote for 2 seconds 3.Push the little button on your remote for 2 seconds Minimum of 1 second is required between each action Your remote will now operate with your motor b) Overhead Doors Remove the coloured plastic rectangular strip located next to the Merlin label on the front of the motor. This will reveal a red Learn/Delete button. 1. Push Learn/Delete button for 2 seconds the lamp will blink continuously to alert you that it is in Learn Mode 2. Push the big button on your remote for 2 seconds 3. Push the little button on your remote for 2 seconds *Minimum of 1 second is required between each action Your remote will now operate your unit. Thanks BB
May 21, 2010 | Sears Craftsman LiftMaster Chamberlain...
Model 2000SDR - installed approx 1974 - button is
If you go to this website you will find the programming instructions under type 4. It lists the opener with the red smart/learn button.
http://www.chamberlain-diy.com/doityourself/pdfdocs/114A3484.pdf
Nov 04, 2009 | Sears Craftsman LiftMaster Chamberlain...
PROGRAM PRIUS GARAGE DOOR HOW DO I PROGRAM THE BUTTONS ON THE PRIUS' REAR VIEW MIRROR TO OPEN THE GARAGE DOOR
There was a minor change for mine to work.. see below..
- you must park your Prius close to the gate opener, leaving it running (obviously not in the way of the gate closing)
- Hold the button the the mirror and then push your garage door remote button and hold until the light on the mirror starts to flasyh fast. THIS programs the button on the mirror, but not the garage opener - yet (this was key for me)
- locate the "learning button" on the opener itself
- press the "learning button" on your gate opener and then get back into the Prius within 30 seconds (more time than it sounds) and press the SAME Homelink button you just programmed above. I don't recall how long I held the pre-programmed button, but the light will flash as I recall.
- Then, when working the garage door, you may need to hold the mirror button for a good second for it to work - but I had tried for months to get mine to work, and finally after reading many posts, the above sequence worked on my 2008 Prius with my Lift Master, Security + rolling codes garage opener.
Just - program the button on the mirror with your remote FIRST.. the garage opener will not work.. then use the Learn button on the garage opener and the SAME BUTTON you just programmed.. and it worked great for me. Not programming the mirror button first will not work. Using only the Learn button will not work. You must program the mirror first with the remote, then use the learn button and the SAME button on the mirror. Hope this helps.
Scott 2008 Prius with Lift Master Security + opener.
Oct 30, 2009 | 2007 Toyota Prius
Genie excelerator/
Check to see if the Vacation switch is locked on your wall console. It is a switch on the top of the black wall button. If that is not the problem it sounds like you need to program your remotes. Drop down the plastic cover towards the back of the unit There is a learn button push that and a red LED will come start flashing press and hold the button on your remote until the LED stops flashing (solid red) press the button on your remote again and the light will go off. This will program a remote
Here is a copy of your manual
www.geniecompany.com/docs/GENIE%20EXCELERATOR-ENG.pdf
Oct 12, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Lights
to morganjonesp
the big light that on it own by the red button is the power/ status
green- is on and ready to print
flashing green- printing
amber - fault
the other 4 in a line with a coloured label around them are the toner information
no lights toner- OK
light on- toner is low this will work along side the on screen display you get.
when the printer starts up it run a test and these light are check to see if they are working- watch next time you switch it on.
to myersk
does the printer run though its check and finish and then is ready?
if so then the problem is with what you are sending to the printer to be printed
if not then the problem could be a stuck printer part, a open cover, a bit of paper in the rollers or a major problem!
does the on screen control panel not tel you what is wrong?
Jun 18, 2008 | Samsung CLP 300 Laser Printer
Building Materials Logo
Top Building Materials Experts
hpgwva
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
