Question about Sony STR-DB930 Receiver
Sony receiver STR-DB930. child turned volume up all the way because of no volume then switched to correct input and speakers blasted. now they don't work at all. did the receiver get permanen
Turn off for a period of 20 minutes then retry sound. not working.
    New Friend:
    Problem Solver:
  • 17 Answers
First things first: determine if the speakers have failed or the power amplifiers. Try listening with headphones: if this works then the speakers were damaged. Your speakers may have a circuit breaker or fuse on the back or inside, please check that first. I think it unlikely that anything was damaged in the receiver because of the action of your child. There is a lot of protective circuitry in these mid to higher end units. But given the age of the unit it is not out of the question, either. I have found circuit diagrams and repair manuals for two other older Sony units on the Internet. Now, you may not be an electronics guru and so you possibly cannot repair this yourself, but if you are planning to junk the unit first study the repair manual, open up the unit and look around the power amp section for damage. The power amplifiers are transistors in relatively large metal cases attached to heat exchangers. I'm afraid this doesn't answer your question directly but maybe it will help you "self serve" and at the very least feel a little less bad about throwing it away.
Posted on Nov 26, 2014
gman63b
  • 9 Answers
SOURCE: Sony STR-DE635 Receiver-no sound at all
Turn your volume down,press the tape monitor button.then turn up?
Posted on Mar 21, 2008
  • 15 Answers
SOURCE: Sony amp str-db940 - protection
Somewhere in your speaker wiring, you have a shorted wire. This short can be as simple as a single strand of wire touching the other terminal on one of the speakers.
With a bright flashlight, look carefully at the back of the receiver and then the speakers for any loose strands.
Posted on May 27, 2008
  • 814 Answers
SOURCE: Sony str-de675 receiver has no sound at speakers when turned on.
This unit is having a problem with the preamplifier and power amplifier section. The reason to suspect this is that you can still hear sound, this is not likely if you ahd a failure in the power supply section. The unit may have had a failure in the amplifier areas of these sections, These are the signal amplifier sections that increase the power of the signal to drive the sound in the speakers .The Unit is probably in the protection mode reducing all power to prevent further damage to the rest of the receiver. You can go to the www.sony.com website support section and look in the frequently asked question and troubleshooting sections for problems like yours and see if they have any answers. On this website you can also find customer support. Ask them questions about the problem and see if they have any solutions.If all this fails to answer you problem, you can try opening the unit and looking for the problem yourself. Only work on the unit with it unpluged from the power source. Take off the top cover and look for any damaged areas, on the pc boards.They would be brown areas from excessive heat due to component overheating and possible failure.Look for capacitors that may have gone bad, they will be bulging from the top and bottom and may be leaking material from inside of them. Any component like this needs to be replaced. You may find burnt resistors and other failed components that will require a digital voltmeter to test.If you have expperience with this type of repair you might be able to isolate the problem and replace the parts. This may require the help of service information due to the complexity of the receiver's operations. Try to get a schematic or service manual from the web or a repair shop. This will have all the parts and a diagram of the all the different sections of the receiver. Usuall there is a power supply section, a tuner section, a preamplifier section, and a amplifier section. There also could be a equalizer section and other sections according the functions of the receiver. The failure most likely has occured in the preamplifier section or amplifier section. The problem in the preamplifier section could be a signal diode failure or a signal amplifier failure. in the amplifier section the problem could be in the output power devices which may be transistors or ic's depending on the type of output amplifier use in the unit. Usually not that hard to find with good service information and test eauipment.You may want to take this to a school that teaches electronic servicing and see if they will work on the unit for you for the cost of parts and a small labor fee. Call them first and see if they can help you out. I hope this helps you with your problem.
Posted on May 18, 2009
larry james
  • 287 Answers
SOURCE: No sound coming from Sony Receiver STR-DG510?
Sounds like you are pretty close with this one. If you select fm tuner do you get audio. If not you may have the speakers on the wrong a-b setting. Make sure the audio from your cable box is not muted or turned down.
Posted on Jul 15, 2009
dunnbiker
  • 8546 Answers
SOURCE: I have a Sony STR DB930. Something happend and it
The fuse blowing is a symptom of something seriously shorted internally. What preceded the initial problem? Smoke is bad. Fire would be soon to follow without the fuse blowing. Take it to a tech.
Posted on Feb 09, 2010
Why does picture go dark shortly after power on?
Along with your problem statement and request, it would have helped if you provided the brand. make and model of your TV as it need not generic to all TVs. I would start at looking for known errors against the brand.
Apr 08, 2016 | Televison & Video
Teac A R300 right speaker has s badly distorted sound after 20 minutes. When I turn it off nad turn it on again, Same problem after 20 minutes. Left channel working perfect.
Have you changed the speakers to see if it is a driver, or amplifier, issue? If it follows the speaker, get it reconed. If it follows the channel, look into that channel.
Aug 19, 2014 | Audio Players & Recorders
Prima Cineplus 50" Plasma PH-50R18C will not turn on
The ambient temperature might be high. Check whether the foolinf fans are working or not. If not, check out the reason for it. The TV must be placed at least 6cm away from wall, and should have sufficant ventilaation.
Nov 15, 2013 | Televison & Video
Sony DB930 Receiver goes into 'Protect Mode' when it is turned on
If the problem is going in and out, it sounds like it may be intermittent solder connections. This most often happens on the preamp IC's in Sony receivers.
Mar 25, 2013 | Sony STR-DB930 Receiver
Dryer stuck in 20 minute touch up cycle.
Clean the moisture sensing bars with windex and retry.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 30, 2012 | Kenmore Elite HE4 Electric Dryer
2002 mercury grand marquis wont start when engine at normal temperature must wait 15-20 minutes
I have exactly the same problem started last winter, ran fine all summer then as soon as it got below freezing again if I start it and run for 15 20 minutes wont restart I have to let it sit for 20 minutes or so and then it will start again. no codes and just turns over without starting. cant be fuel pump like i said had this problem last winter then ran fine all spring summer and fall! Anybody got the answer for this one??
Mar 09, 2012 | 2002 Mercury Grand Marquis
Sony STR-DB 930. Intermitent sound quality from front speakers ( low then loud ) with sharp clicking noises like relay switches clicking on and off. Thanks Dave.
I have had this problem which then developed into the unit going into PROTECT mode. This is typically caused by the relays and perhaps some other components developing dry joints over time. I had a professional refresh the solder joints and it works perfectly now
Mar 25, 2011 | Sony STR-DB930 Receiver
Sony STR-DB930 Receiver Logo
129 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
