Why does my sound skip on digital in
I went through all the settings on the audio menu and nothing worked
    Master:
  • 423 Answers
Need more info. Does it skip on all inputs? Is it on cable or antenna?
Posted on Nov 26, 2014
Hi I am trying to get this reciever to work connected via digtial optical cable to my PC, my sound card shows that it is working becuase when i play a song i can see the levels rising and lowering in the...
I imagine if you disconnected the optical audio cable you would still see sound settings varying on the PC, so it proves nothing.
You need to make sure the Sound Card Digital Output is at a correct sampling rate. Find its digital settings and try 44.1khz, PCM. Experiment wit hall settings.
Jan 21, 2011 | Kenwood VR-606 Receiver
Greetings- my denon avr2802 is connected to ps3 for blu ray movies, games and music. The ps3 image goes directly to tv with hdmi and sound from ps3 goes to the denon using digital audio cable. Sound for...
Set the receiver for auto audio input - I think that you are getting caught out between MPEG and DTS audio. If you have the wrong one for the audio source then you hear nothing.
Mar 07, 2010 | Denon AVR-2802
Show picture but no sound. went to the menu button to look for the audio but not successful.
Your audio source needs to match the signal you are receiving. On the menu go to audio and then setup My source is set to HDMI (like my video). Within that selection you have the choice of analog, digital or auto. Auto should work for all signals. Analog will not give you sound if you have a digital signal (I found out by accident).
Oct 10, 2009 | Toshiba 19AV600U LCD TV
No Sound
try accessing your tv settings menu and look for audio settings. usually there is an adjustment that you can make for external audio speakers such as when hooking up to a sound amplifier or internal audio that accesses your internal tv speakers.
Oct 03, 2009 | Apex Digital PF2020 20" TV
Sound skipping while playing Blu Ray
HI, make sure the audio out put on the ps3 is set to hdmi and set to stream dolby digital,aac, dts, etc,then set audio input on your 696 to hdmi,also check that audio out for hdmi is set to off in the hardware menu on your amp,if you still have problems use the optical out on the ps3 as the ps3 does not out put hd master audio or dolby true hd only pcm, you will still get dolby digital.
hope this helps.
CABLE GUY.
Feb 08, 2009 | Onkyo TX-DS696 Receiver
Audio recording function cannot be switched ON in menu
Check the recording mode you are using. This option is available on Auto, Scene and Macro modes only. To set this, press Menu/Set button to enter the REC mode menu and select the recording option to set.
Dec 25, 2008 | Panasonic Lumix DMC-FX01 Digital Camera
No sound Zenith DVB712
Try changing the audio setting from BITSTREAM to PCM. On the remote select SETUP, AUDIO, DOLBY DIGITAL, then change the setting. Once selected turn off the DVD player without exiting the Menu. Turn back on again.
Jul 16, 2008 | Zenith DVB712
Program channels
TV SETTING
1. Press the MENU button.
2. Use or button to select the TV setting menu, then press or button.
3. Use or button to select the Channel no. setting and use the or button
to change from AIR (over-the-air broadcasts) to CABLE (cable/satellite broadcasts).
4. Use or button to select the Tuning mode and use the or button.
5. Use or button to select the Auto tune and press or button to
confirm the selection. The unit will immediately search through all possible TV
channels and store those channels with signals in memory. After this is complete,
the unit will switch to the first channel found.
6. To exit the MAIN MENU and return to the normal screen, press the EXIT button.
Note : In DVD mode, this option is not available.
Remarks:
1. Channel no. : 2-69 channel for Air mode, 1-125 channel for Cable mode.
2. Tuning mode : Air or Cable mode are available.
3. Auto tune : Searches for usable stations and stores them in memory.
4. Skip : ON - Skip weak channels. OFF - No channel skip.
5. Fine tune : The frequency changes to allow fine tuning.
6. AFC : Auto frequency control.
7. MTS : Select the Mono sound/Stereo sound/Secondary Audio Program (SAP).
21
TV SETUP
MTS (Multi-channel Television Sound) SETTING
This feature allows reception of sound other than the main audio for the program.
3. Use or button to select MTS menu, and press or button to select the
options (Mono, Stereo, SAP)
4. To exit the MAIN MENU and return to the normal screen, press the EXIT button
on remote control.
Note:
• MTS only operates while in TV mode.
• The SAP (Secondary Audio Programs) feature allows a TV station to broadcast
other information, which could be audio in another language.
RESTORE SETTING
If you reset the TV to the factory settings, all your present settings on picture &
sound will be erased and replaced by the factory’s default settings. However, picture
setting in PC mode and parental setting will not be erased.
Jul 15, 2008 | TruTech PLV1615T 15 in. LCD Television
No sound
The Philips DVP5982 has an odd menu setup for the HDMI sound.
If you get sound from the analog outputs from the unit, but no sound when you use the HDMI output, use this procedure to see if you can restore it:
On the remote control, press Setup.
- Right cursor to the Audio Setup Page
- Go down to Digital Audio Setup
-Right cursor, to get to the screen that shows
Digital Output
LPCM Output
HDMI Audio Setup
Try to go up to the Digital Output setting- if you can't , and instead it shows only HDMI Audio Setup with the "On" highlighted in blue, this is the quirk:
Go into the HDMI Audio Setup, and select "Off", and press Enter, so it's highlighted in blue.
Now it should let you go into the Digital Output menu selection, where you may find it to be on the "Off" setting.
Select "All", and then you can go back to the HDMI Audio Setup and set it to On again, and it should now output sound from the HDMI again.
For some reason, they decided to lock out the Digital Output settings menu when the HDMI Audio is On- go figure.
So you need to turn off the HDMI sound before you turn the sound on.. ;)
Jan 12, 2008 | Philips DVP5982
Hooking up a sony playstation 3 with digital optical cable
Here's one solution, if you have an audio output from your tv, you can go from the audio output on your tv to the audio input on your receiver that way anything that is playing on your tv for example, playstation 3, dvd player etc. Anything playing on your tv will have audio on your onkyo home theater system. The other thing I would try if you want to hook ps3 directly to receiver is go to your connection settings on your ps3 menu and change your connection method to digital optical cable.
Dec 27, 2007 | Onkyo HT-S790S System
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
