Question about Daewoo FRG1820BRW White Top Mount Refrigerator FRG1820BRW
I need a wiring diagram for a Daewoo fridge/ freezer frg 1820brw, any idea where I can get one?
  • wakeywoo Nov 26, 2014
    Thanks
    I have managed to figure it out....I had to defrost it every two weeks. Turns out to be the defrost thermostat which is mounted on the evaporator.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 63 Answers
I think maybe if you googed
wiring diagram for a Daewoo fridge/ freezer frg 1820brw, it may help
Posted on Nov 26, 2014
Testimonial: "Thanks"
    Problem Solver:
  • 10 Answers
Check repairclinic.com - they have a lot of repair info, some online, as well as some repair videos.
Testimonial: "Thank you"
4 Suggested Answers
projdoc
  • 2237 Answers
SOURCE: My Daewoo FRS2021IAL has a warm fridge
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Posted on Aug 27, 2009
  • 2468 Answers
SOURCE: daewoo amerfcian fridge freezer does
the ptc overload relay on the compressors bad,replace this and it will again cool and freeze
Posted on Jul 07, 2011
richroth
  • 9472 Answers
SOURCE: is FRG-1820BRW frost free
Most of the newer models are all frost free.
Posted on Nov 22, 2012
Model 1820brw Daewoo refrigerator freezer not freezing
Is compressor running? Check start relay/capacitor? Defrost mechanism not working?
Check attached site for schematic/parts Search Over 2 1 Million Appliance Parts
Aug 29, 2017 | Daewoo Refrigerators
Mw Daewoo fridge freezer FRS-20321BE is leaking water copiously from the refrigerator I cannot see any source for this but puddles form and flow internally under the veg box. Help!
All depends on how much water is collecting. A lot of water indicated a leak from the ice maker. A small amount and it's probably a clogged condensate drain. Here's a YouTube video on a different brand showing a clogged drain, your may be similar (or not), but it might give you an idea as to where to look. Refrigerator dripping water inside FIX
Mar 07, 2016 | Daewoo Refrigerators
WATER LEAK
most likely the drain line is stopped up.it drains down to the back on the down to the comprssor area.u would have to remove the back wall of the freezer compatment to see if it has ice covering the drain.sometimes a real pain to defrost out.hair dryer and time
Apr 10, 2013 | Daewoo 18.0 CuFt Top-Freezer Refrigerator...
Is FRG-1820BRW frost free
Nov 22, 2012 | Daewoo FRG1820BRW White Top Mount...
Fridge light does not work.
Some appliances have electrical schematics on the back of the fridge, some are hidden behind rear cover. Wire,Switch or fuse..not much else it could be.
Aug 24, 2012 | GE Refrigerators
My Daewoo American Style Fridge Freezer is completely dead. Checked power and electricity supply ok. Any suggestions?
My Daewoo Fridge Freezer was dead the same as yours. I purchased a new Electronic Module, this is the main PCB board on the top of the fridge freezer. There is a 3 amp fuse on this board which was blown by a faulty voltage regulator. This will set you back 90 pounds + postage, it is fairly easy to change & hey presto, a working fridge freezer
Aug 25, 2011 | Daewoo Refrigerators
Daewoo FRG1820BRW White Top Mount Refrigerator FRG1820BRW Logo
243 people viewed this question
Top Daewoo Refrigerators Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
jasbo
jasbo
Are you a Daewoo Refrigerator Expert? Answer questions, earn points and help others
