Question about Video Cameras
Replacement of zoom switch assembly
Message for CLIVEBEARMAN: I, too have problems with the camera zooming without touching the zoom switch. You mentioned purchasing the zoom button assembly. Precisely where does one purchase this item? I have searched Canon's site in vain. Does Canon have a detailed breakdown diagram of the camera if I elect to replace this switch myself? If I wish to have a technician do it for me, would you know of any local ones in the Kingston, NY area or Mid Hudson Valley? Thanks in advance! Robert Ruggiero
  • 81 Answers
Is the auto zoom set. Anyways, too hard to answer without the camera model
Posted on Nov 26, 2014
SOURCE: Canon Elura 60 zooms by itself
Listen, I know it's a couple of years after this post but, try this: Remove cassette, push to close, close camera as if to use it, hold firmly in left hand, open hand slap it with your right hand once or twice, (I'm not joking) it worked the two times I had this problem. Problems with the zoom? Almost same process, push firmly on zoom button (to un-zoom) try doing this as your tapping it. These are last ditch efforts on an aging camera, it really has been a good one. I've put this poor thing through years of abuse, and it's held up pretty well. Good luck, Jeff S.
Posted on May 09, 2009
cpt100
  • 154 Answers
SOURCE: Canon XM2
You might have bad contact in zoom switch unit or a short in zoom switch. The switch assembly is replaced for the remedy.
Posted on Mar 14, 2007
SOURCE: Elura 70 problems: stuck on zoom in & won't load cassette
Yep, banging the bottom worked like a charm! Who would have thought? Thanks
Posted on Aug 15, 2008
SOURCE: Elura 60 Zoom Problem
Guys, so weird but on another site it offered this suggestion: banged the base of your camera against something hard and it will become unstuck. So bang the base of your camera against something hard and it will work again, at least it works like it did but not sure for how long. Good luck. I can't believe that worked. Give it a try. I didnt hit it too hard either.
Posted on Sep 21, 2008
SOURCE: Canon MVX250i Zoom
Change LI-ion battery (not main power battery) ...change it every 1 year if your camera in low-activity use.
Posted on Nov 28, 2009
My Coolpix L320 was working fine, then all of a sudden got stuck with the lens zoomed all the way out and a message on the screen that says, "Turn the camera off, remove the lens cap, and turn the cam
after changing the battery and gently push back on the lens it should automatically close if not then check around it it must be something stuck in between it
Jan 18, 2015 | Nikon Coolpix L320 Black Digital Camera...
I barely touch the surface of the zoom and it goes all the way in. when I try to zoom out it fights me, and it is almost like it has a mind of its own.
Sounds like the springs that are responsible for popping the zoom switch back to center are not where they are supposed to be. Easiest solution would be to open it up and look for obvious problems or buy a used zoom switch assembly online and switch it out. Don't know what model you have, so I don't know how hard it would be to do or how much it would cost, sorry.
Thomas Drayton
Owner, Darntoothysam.com Digital Camera Repair
Jul 11, 2011 | Cameras
Canon HF100 zoom by itself, without touching the zoom button
you have to whack it on the bottom this will fix the problem (seriously!) bang it down on a hard surface (not too hard!!!) and then see if its fixed. do it a couple of times and it should work fine.
May 07, 2010 | Canon VIXIA HF100 Flash Media Camcorder
Fujifilm finepix a820 zoom error ... i turn the camera on and it wont focus... message on lcd screen is zoom error. it will not take picture and when i turn it off agan the zoom bit wont go back inside
    This problem is related to the malfunctioning of zoom motor, Two possibilities are there,
1- If company provides technical help on component leve in your regionl then zoom motor may replace.
2- If component level support is not available then LENS ASSEMBLY must be replaced.
   Contact your nearest fuji service centre or contact any expert nearby for the specific part replacement.
    Thanks for using fixya.
Oct 28, 2009 | Fuji FinePix A820 Digital Camera
Zoom in/out power off message
While zooming in-out camera gives error message means lens mechanism is either defective or lens drive motor is bad. In both cases, lens assembly will be replaced.
Contact nearest camera repair shop for fix.
Thanks.
Sep 04, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Message on screen "turn power off and on again" when switching the camera on
this problem appears when the zoom motor starts malfuntion the remeady of its is to replace the zoom motor (if comopnent level repir is availble in ur area) other wise u have to scan complete lense block assembly. u didnt mention model no.
Jul 25, 2009 | Cameras
Won't take pictures when zoom
Most common problem in al the digital camera's. Slide motor start malfunction and the massage appears"Turn off the power and on again". In this situation you have to replace slide motor or lens block assembly, And your camera work fine again.
Jun 27, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
Top control touchpad not working plus zoom extending.
Its problem of that loading flap (technical name is control switch block) and requires replacement.
control switch block is included play-stop-rew-ff-eject etc switches including zoom-wide switch.
Jun 21, 2009 | Sony Handycam DCR-TRV320 Digital Camcorder
JVC GR-DX97 Zoom Control Button on top
You have a bad zoom unit/zoom controller. It is common on these units.
Oct 22, 2008 | JVC GR-DX97 Mini DV Digital Camcorder
Video Cameras Logo
89 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
