Question about Vacuums
Find a part for my roller chair?
I have an ems.6 chair for bout 16 yrs, still works except the the band that goes around the bottom which makes the rollers go up and down pops off. (i took apart the back and whenever it put it back on, it just keeps popping off, when i use the rolling up and down feature. It stays on when i am only using the rollers. I think maybe i might need a new band. what do you guys think and if so, where can i find a new part to test out this theory?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 61 Answers
Your best best is to contact the manufacture for OEM parts. as this isn't going to be a universal part, you can't really just pick it up at the local parts store. specially with a 16 year old part.
Posted on Nov 26, 2014
Buffalo12980
  • 625 Answers
SOURCE: hoover windtunnel U6439900
please go to the hoover vac store using the following link. you will have your exploded diagram for the machine and any spare parts you might need. http://www.thehooverstore.com/U6425.html
Posted on Sep 15, 2007
Buffalo12980
  • 625 Answers
SOURCE: Hoover Wind Tunnel
what probably happened is you swapped end over end when you replaced the beater brush. anyway go to thehooverstore, find your machine and you'll see an exloded diagram of your machine.
Posted on Sep 22, 2007
SOURCE: brush roller stopped rolling
My daughters is doing the same thing and the plastic at the ends of the brush bar melted just enough for it not to turn properly. You might want to chech that.
Posted on Jan 01, 2008
  • 4 Answers
SOURCE: My Bissell Dirtlifter Powerbrush carpet cleaner will not roll. The back wheels roll fine, but when you put the machine down flat, the front part (where the roller is) sticks and will not roll.
I had the same problem. It would pull backwards but not go forward. A closer examination revealed the clear plastic part on the bottom in the very front of the machine had popped loose on one side.
If you look at the front of the machine, there is the clear plastic part on top where you see the dirty water being sucked up. The bottom half that creates the channel for the vacuum is where it came loose. It wouldn't create enough suction to draw the water up either. By taking out the two screws that hold the top part in place and removing it, I was able to snap the bottom back in. Works fine now. Hope this helps.
Posted on May 15, 2009
  • 183 Answers
SOURCE: the roller brush stop working
the fuse in the plug may have blow so replace it any ways
Posted on Jul 31, 2010
Where can i find a part for my chair, ems.6 get away chair
how is it connected to where is pops off does it need a new roller or bearing , I do not know anything about these chairs but if you look at it good and try to work it while watching it and see what makes it come off then you can pinpoint your problem ant take it from there you can prob fabricate something if you cannot fine the right part, good luck , post some Pics so I can see what is exactly happing ,
Nov 25, 2014 | Vacuums
How to fix series 3500 upright vac
With vacuum laying flat with back facing up, remove the 5-6 screws from the bottom of the nozzle, turn on it's side, and pry into 2 slots on either end of the bottom of the nozzle to release the top cover. Lay vac flat on the floor/bench face up, remove the 2 small screws on either end holding the roller brush in place. Pop the belt end of the brush roll out of place, place new belt in, and simply reverse all previous instructions. With 30 yrs. experience dealing almost exclusively with the original Electrolux, I have a legitimate store front business and do service by mail at a reasonable cost if interested. mickeymackmark1@yahoo.com
Hope that helps! Mick
Sep 24, 2014 | Electrolux Vacuums
I have a senteria about 4 yrs old. it bounbes
Check the wheels and axles for damage or bent shafts. Remove the bottom cover and inspect the brush roller for damage--breakage of the roller, bad or broken end bearings, missing brush sections, or something stuck to the roller like a wad of gum or something. Hope this helps!
Dec 26, 2009 | Kirby G4 Bagged Upright Vacuum
Anyone know why my Bissell Proheat 2X Turbo Model 9300's brushes won't turn anymore
If the Brushes don't rotate, & you have two brushes; 1). Turn unit on side. ( Make sure unit is up-pluged) 2). Rotate the front brush roller, if the second roller moves at same time, 3). Locate a small ribbed belt that goes from the further back roller, to a small ribbed pully. (Gates belt #177-3m5) ( on side under a clear cover) The belt may not be broken, but may have carpet fuzz / lint covering the belt ribs, causing the belt to slip. If that belt is OK and you find that the small pully doesn't turn the belt/rollers, the problem is with a small internal direct drive motor, that drives the brush rollers. At this point return the unit, as Bissell has a design defect & is using cheap parts.
Nov 04, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Installing roller brush for oreck XL 21
uh, probably not sure what the issue is, but
1. unplug unit.
2. Remove the multiple screws from the bottom of the unit.
3. remove the bottom baseplate (usually black)
4. the brush roll is now visible, and the belt should be around it.
5. Pull the brush roll away from the unit, and disengage the belt.
6. Replace in the opposite order. Make sure that baseplate fits properly to insure a good seal. Also watch the bumper (rubber part that is wrapped around the unit) to make sure it is properly seated.
7. Handroll the roller brush before plugging in. Make sure it moves freely.
8. Run unit, may get a slight burning smell, but if this continues for more than a minute - turn off and inspect the unit. Brush roll requires a short burn in time, on initial build, factory accomplishes this during test procedures.
Jun 30, 2009 | Oreck XL Ultra Bagged Upright Vacuum
My roomba tries to climb up my dining room chairs model 4110?
Roomba has a problem identifying colors under certain situations. I've seen them freak out on a perfectly flat black-and-white checkerboard pattern. Sometimes they become "blind" due to this condition.
I can't tell what your specific problem is but you might try a small band of tape around the bottom of the chair legs in a color opposite what the chairs are now. Electrical tape comes in a few colors and is easy enough to use. Hope that helps.
Jan 20, 2009 | Roomba Robotic Floor Bagless Vacuum
Stopped running
orecks have a plastic fan inside and everything you pick up hits it, sometimes things can get stuck in there or break the fan locking up the motor. With the machine off, poke around where the dirt goes into the motor, behind the roller and see if you can pull anything out.
Jan 12, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Installing a belt
1. Unplug the vacuum
2. Take the bottom cover over the brush off by removing the 3 screws
3. Switch the brush roll control lever to bare floor
4. Take the roller brush out
5. Put the belt around the small pulley from the motor
6. As you are putting the roller brush back in put the belt around the space on the roller brush - center the belt on that space - THE BELT WILL NOT BE TIGHT BUT THAT'S NORMAL
7. Reinstall the bottom cover with the 3 screws
THE BELT DOES NOT GO AROUND THE SILVER PULLEY CONNECTED TO THE BRUSH ROLL CONTROL LEVER
Dec 27, 2008 | Vacuums
Brush does not spin
definetley the belt if its the cannister vac like mine there is 2 screws on the bottom towards the back wheels take em out. on the side u have to pry open gently on the back side as well the top should come off and you should see a w plastic shroud around the roller there is a clip latch take the shroud off theres the belt
if not cannister vac on underneath the cover should have 4 or 5 little screws take em out under cover is the belt
hope that helps. gl
Dec 29, 2007 | Vacuums
Hoover windtunnel U6439900
Sep 15, 2007 | Hoover U6630-900 WindTunnel Bagless...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
