Question about Kitchen Ranges
My wall oven will not heat up past 180 degrees
The fan and broiler still work too
  • Fred Blumberg Nov 26, 2014
    Hi Torri Powell, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
  • 3,961 Answers
It is likely that your temperature sensor in there has become faulty
Posted on Nov 26, 2014
jumptrout51
  • 3361 Answers
SOURCE: GE Profile oven won't heat up
Check the temperature sensor with a OHM meter.
It should read 1100 ohms. If not, replace it.
Otherwise make sure the glow bar ignitior is coming on.
Ignitors however can glow and still be bad.
Posted on Feb 21, 2009
SOURCE: Kenmore Propane Range won't bake
oven or broiler wont work stove top works fine
shinn8
  • 85 Answers
SOURCE: We have a Maytag Gas Range, Precision Touch
Likely your oven igniter is bad. Part number 74007498
Posted on May 18, 2009
FixinFax
  • 3085 Answers
SOURCE: GE profile oven will not heat up past 100 degrees.
You need a new control panel circuit board.
Easy to replace.
Search www.repairclinic.com
Posted on Sep 09, 2009
mindreader
  • 578 Answers
SOURCE: broiler works oven doesn't heat
Based on your description, the igniter is dead.
The broiler and the oven heat each have their own igniter. Look for the characteristic glow when the oven is turned on. If it is not visible, then you will need to replace the "OVEN" igniter...
Google the stove model for repair parts and locate the igniter. Not too hard to replace... directions are packed with the new igniter...
Posted on Jan 08, 2010
Used self cleaning and now wont heat past 180 degrees
Sounds like you burned out the oven ignitor. A simple fix with a few tools and common sense.
Dec 13, 2013 | Whirlpool GGG388LXS Stainless Steel Double...
Dacro Wall oven (electric) does not heat past 345 degrees on bake or convection bake but broiler works and bottom oven works fine (for bake, convection bake and broil).
it could be the oven temp sensor rod located near the top of the inside of the oven,or possibly the bake element has a hot spot on the element and can no longer pass enough current thru this spot to correctly heat to your settings a hot spot on the element will look discolored in this area
Jul 28, 2012 | Dacor Ovens
Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
Jul 28, 2012 | Hotpoint Ovens
Oven turns on, but w2ill only heat up to about 120 degrees, you can reset and increase temp, but will only go to 150 degrees. Broiler works, but oven anf d oven clean do not work
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jan 18, 2011 | Amana Ovens
My oven does not heat to the correct temperature. If I set it for 325 degrees it will heat to 390 or so degrees. It always seems to be about 70 degrees too high. Accross all ranges of temperatures from...
The thermostat is the cause of the problem, normally the the only cure is to replace the oven thermostat,completely, or alternatively, compensate by setting a lower temperature when cooking.
this will work o/k if it is always the same variation in temperature across the range .
Dec 25, 2010 | Electrolux 30" Built-In Single Electric...
Oven won't heat past 150 degrees.
you either have a bad bake element or control. also check wiring between
Mar 25, 2010 | Kitchen Ranges
Oven and Broiler coils do not heat. Control works okay. The burners heat okay. Set oven to 325 degrees. Drops to 100 degrees. There is a click. and nothing happens beyond that. Try broiler. Set to HI. Does...
There is a relay in the back panel of the stove, this is probably the problem, there is also a temp thermostat in the back leading to the inside oven this cold be bad
Nov 26, 2009 | Washing Machines
Bosch convection double oven,ovens won't heat,only broilers work
If it is fan assisted then check the fan element, it is located behind a panel at the rear of the oven compartment.
Plz rate my\solution.
Thanks.
Dec 17, 2008 | Bosch Ovens
Kitchen Ranges Logo
57 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
